Mini ISA ROM Card
Reply 60 of 88, by ia2115
hehe dexterff8 lets goooo 😉 btw do people choose gold fingers on the pcb, or just the cheapest options from where you order?
Reply 63 of 88, by smesgr
great thank you!
Reply 64 of 88, by gylu
hi, i build the mini card. with the provided 386_2DRV.BIN is working. but if i try to flash new bios from www.xtideuniversalbios.org its not booting (27c64, 27c128,27c256 burned with T48). what am I doing wrong?
Reply 65 of 88, by Jings
gylu wrote on 2024-10-04, 20:31:
Have you remembered to configure the downloaded BIOS with XTIDECFG.COM before flasing it, as per the instructions?
All BIOS binaries available here must be properly configured with the configuration tool XTIDECFG.COM before flashing/programming to ROM. In addition to configuring the BIOS file for use with your specific hardware you must also make sure the file is checksummed by saving the file to disk as that will create the padding and checksum required for installation in a computer.
Reply 66 of 88, by Xargon321
hey wiretap is there a way to buy a completed one from you? i just came across this and would like to get one of you're boards no one else seems to make them and i really dont want to spend $70 on a xt-ide for the 8 bit boards with stuff i won't use because i have 16bit/32bit ide onboard
Reply 67 of 88, by wiretap
Unfortunately I do not build these boards and sell them. I wish I had the time to though. Anyone else can build and sell them as they wish, so hopefully another member can build a few to sell. Otherwise, they're really cheap to order the PCBs from JLCPCB to build your own.
My Github
Circuit Board Repair Manuals
Reply 68 of 88, by douglar
Xargon321 wrote on 2025-02-28, 05:38:
I like the simplicity and elegance of the new built cards, but there's still a lot of used options.
If your system does 16 bit, there are still plenty of affordable ISA NIC cards. Maybe not the $10 price point so much any more, but there's a lot of options under $25.
If you have to have an 8 bit card, maybe you could hijack an old MFM controller and jumper it to disable the controller?
Reply 69 of 88, by Xargon321
Don't have a chip programmer and just getting the boards to me would be 20$ shipping i could use the one that you can flash in the pc maybe sell me a kit? I can build it just don't have all the stuff
Reply 70 of 88, by dexterff8
ia2115 wrote on 2024-09-12, 06:39:
I live in Brazil and here it is always the cheapest option, but I made 15 pieces of xtide with gold plated terminals
Reply 71 of 88, by dexterff8
dexterff8 wrote on 2024-09-06, 20:52:
here is a .ROM to put on the mini iza board and play PONG soon more tool for RAM testing ;) […]
dexterff8 wrote on 2024-09-06, 00:48:
Let's throw some peppers here at this project to see if people get excited, I'm creating a board with an options menu and some utilities, format tools, ram test, video, among others, I already have something functional but it's still progressing....
soon more tool for RAM testing 😉
https://drive.google.com/file/d/1KQrS3PsX2AVX … iew?usp=sharing
(((SUCCESS !!!!))) now running MSDOS and I made a menu with 17 options for you to put whatever you want in 7MB of FLASH NAND ROM
questions why 17 and why 7MB
17 so that it can be compatible with CGA and VGA and 7MB for this ROM is worth 2$, now we have our PC_XT GAME CARTRIDGE
soon PC_AT
https://drive.google.com/file/d/1swTgTTpLMAnJ … iew?usp=sharing
Reply 72 of 88, by dexterff8
dexterff8 wrote on 2025-03-06, 14:11:
(((SUCCESS !!!!))) now running MSDOS and I made a menu with 17 options for you to put whatever you want in 7MB of FLASH NAND ROM […]
soon PC_AT
https://drive.google.com/file/d/1F29UJLU73mYi … ?usp=drive_link
Reply 73 of 88, by douglar
soon PC_AT
I guess prince of Persia did fit on a floppy
At the risk of sounding greedy, is it possible to do a larger rom?
Reply 74 of 88, by wierd_w
If you add bank switching, you could have as large a rom as you want to expend page counters for.
Reply 75 of 88, by douglar
Ok, I think this would be fun to have with Speedsys, HWinfo, and Norton
Can you still have IDE drives in the system with the disk on chip? Does it take a drive letter?
Reply 76 of 88, by dexterff8
douglar wrote on 2025-03-08, 21:18:
Yes, you can add a driver letter and it works perfectly with other drivers. Regarding the size, I think 8MB is already a good size, 128 64K banks, since the HDDs were 10MB, but I think it would be possible to extend the 32MB limit of FAT 32 and DOS 3.1.
Reply 77 of 88, by douglar
dexterff8 wrote on 2025-03-12, 13:11:
Here is some reading I found helpful to get more history on the DOC-- https://www.os2museum.com/wp/diskonchip/
The best price I could find for a DOC was $10. I can live with that but finding a card that takes DIP32 ROMs seems like it might be more challenging.
Reply 78 of 88, by jmarsh
douglar wrote on 2025-03-12, 16:54:
IIRC there are 5V UV EPROMS that go up to 4MB, but they're 42-pin DIP. Obviously you'd need a GAL or similar (like what is shown on the DOC) to handle bank switching.
(The ROMs are also 16-bit so you need a couple of demultiplexers to turn them into 8-bit).
Reply 79 of 88, by wierd_w
A small sram and another eeprom can do the bankswitch dirty work.
Write your logic output as the byte values inside the eeprom, then catch the switch with mem-mapped sram. Use the sram's data lines to drive the address lines on your eeprom, and the eeprom's data lines to drive chip select lines.
Cheaper, but slower. In theory though, gives you many more outputs.
