MartyPC
Reply 600 of 606, by peterfirefly
BinaryDemon wrote on 2026-01-06, 15:04:
What workload/benchmark would you like tested? I always found I had to do a lot of DosBox testing because low end systems would mask performance issues by dropping video frames or audio. Not sure if MartyPC would do the same.
I have a celeron N3350 4gb ram with integrated graphics running Win10. I probably even have some dual core atom thin clients in my basement.
Just having MartyPC boot ordinary DOS with CGA might be a challenge for that machine. Just sitting at the A> prompt with a blinking cursor might be.
This is the microarchitecture:
https://en.wikipedia.org/wiki/Goldmont
It's the first Atom microarchitecture that has out-of-order execution but it isn't very wide or deeep.
This is Intel's page about that specific CPU:
https://www.intel.com/content/www/us/en/produ … ifications.html
Here are Geekbench's scores:
https://browser.geekbench.com/processors/intel-celeron-n3350
For comparison, here's my i3-7100U (Kaby Lake microarch) that used to be on the slower end for MartyPC (older versions):
https://browser.geekbench.com/processors/intel-core-i3-7100u
and my current AMD Ryzen 5 8640HS (Zen 4) that should be very nice (haven't tested MartyPC with it yet):
https://browser.geekbench.com/processors/amd-ryzen-5-8640hs
This is what a Raspberry Pi 5 can deliver:
https://browser.geekbench.com/v6/cpu/9919608
Reply 601 of 606, by BinaryDemon
So I was wrong about the cpu it’s - Celeron N3450 Quadcore 1.1 ghz that can turbo to 2.2ghz
The startup pc speaker beep sounds drawn out.
Alleycat is playable?
Trying to get a benchmark to run but having issues.
So this is probably what GloriousCow would want to see.. 3.55mhz would be a little on the slow side.
The attachment IMG_0741.jpeg is no longer available
Reply 602 of 606, by SoftCat
jal wrote on 2026-01-05, 10:27:
I have a fairly high-end laptop with a Intel Core i7-9750H CPU, which is from 2o19, with both integrated Intel graphics (630) as a discrete NVIDIA Quadra T1000, and MartyPC runs fine.
I see, thanks for the information.
Reply 603 of 606, by SoftCat
I'm interested in what the minimum CPU is for emulating a PC-XT with CGA.
Reply 604 of 606, by BinaryDemon
SoftCat wrote on 2026-01-06, 22:20:
I’ve run XT Emulators (not MartyPC obviously) on ESP VGA32 devices. Those are 240mhz dual core risc chips.
https://youtu.be/BfOZAfTfuOg?si=6IAEmfiUFy9Ul1oX
It evens runs fast (so I guess less accurate).
Reply 606 of 606, by BinaryDemon
SoftCat wrote on 2026-01-06, 22:52:
I'm interested in MartyPC for Windows 10.
Ah, I’d bet modern Celerons could handle it but might want to atleast go i3 to be sure.
