Battle of the platforms: socket 754!
Reply 640 of 927, by nd22
C. ULI
D. nforce4
Reply 641 of 927, by nd22
12. same 1280*1024 + sound:
A. nforce3
B. VIA
Reply 642 of 927, by nd22
C. ULI
D. nforce4
Reply 643 of 927, by nd22
The PCI-express platform remains on top!
13. For those with the ultimate retro monitors - either LCD or CRT: 1600*1200 sound disabled
A. nforce3
B. VIA
Reply 644 of 927, by nd22
C. ULI
D. nforce4
Reply 645 of 927, by nd22
14. Most demanding settings: 1600*1200 max details, sound enabled:
A. nforce3
B. VIA
Reply 646 of 927, by nd22
C. ULI
D. nforce4
Reply 647 of 927, by nd22
Aquamark3 is owned by the nforce4 as it leads across all resolutions and settings even if by tiny margins!
15. We begin testing 3dmark and the first version is 2000. Default settings first.
A. nforce3
B. VIA
C. ULI
D. nforce4
Reply 648 of 927, by nd22
I would like to point out that in directx7 and directx8 - 3dmark 2000 & 2001 - nforce4 leads by a large margin with both Clawhammer and Newcastle!
Also it is obvious if you have followed the topic that a CPU with a larger cache has a 6-8% advantage over the one with less, so for directx 7 & 8 games Clawhammer is highly preferable!
16. 3dmark 2000 - 1280*1024
A. nforce3
B. VIA
C. ULI
D. nforce4
Reply 649 of 927, by nd22
17. 3DMARK 2000 1600*1200:
A. nforce3
B. VIA
C. ULI
D. nforce4
Reply 650 of 927, by nd22
Again Abit NV8 is in the lead; the only outlier is KU8 - very poor performance due to BIOS settings and driver used.
18. The benchmark without which you can not have a retro comparison: 3dmark 2001 - loved by everyone, hated by no one!
Default settings first:
A. nforce3
B. VIA
C. ULI
D. nforce4
Reply 651 of 927, by nd22
19. 3dmark 2001 - 1280*1024
A. nforce3
B. VIA
C. ULI
D. nforce4
Reply 652 of 927, by nd22
20. 3DMARK 2001 - 1600*1200:
A. nforce3
B. VIA
C. ULI
D. nforce4
Reply 653 of 927, by nd22
No clear winner here as against all the odds ULI makes a comeback at 1280*1024 and 1600*1200 to win by a very small margin.
21. 3dmark 2003 is the final version to be tested! Default settings first:
A. nforce3
B. VIA
C. ULI
D. nforce4
Reply 654 of 927, by nd22
22. 3dmark 2003 - 1280*1024:
A. nforce3
B. VIA
C. ULI
D. nforce4
Reply 655 of 927, by nd22
23. 3DMARK 2003 - 1600*1200:
A. nforce3
B. VIA
C. ULI
D. nforce4
Reply 656 of 927, by nd22
With the exception of nforce3 that falls behind the other 3 systems perform so close to each other that it is impossible to pick a winner!
24 & 25. In the 2 sound tests of 3dmark - for the test with 60 sounds you need a hardware accelerated solution - Abit NV8 with nforce4 stays on top an manages and takes both the 24 sounds and the no sound test.
Reply 657 of 927, by nd22
26 & 27 & 28. synthetic 3d tests are over; time for system tests and we start with PCMARK 2002:
A. nforce3
B. VIA
C. ULI
D. nforce4
Reply 658 of 927, by nd22
nforce4 wins but again it's just a 2% difference so nothing out of the ordinary. Integrated memory controller is doing its job so CPU and RAM scores are practically equal!
29 & 30 & 31 & 32. PCMARK 2004 i s next:
A. nforce3
B. VIA
C. ULI
D. nforce4
Reply 659 of 927, by nd22
Again processor and memory perform the same on all 4 platforms; the radeon x1950 pro seems to perform the best with the via chipset while hard drive performance of the nforce3 is lacking!
33 & 34 & 35 & 36. PCMARK 2005 is the final version compatible with Windows XP.
A. nforce3
B. VIA
C. ULI
D. nforce4
