The Soundblaster DSP project
Reply 644 of 1053, by maxtherabbit
Maelgrum wrote on 2023-10-05, 16:24:
maxtherabbit wrote on 2023-10-05, 16:23:
No error this time it just freezes after passing the loopback check
Wait a liitle ))
I gave it like 45 seconds how long are you thinking?
Reply 645 of 1053, by Maelgrum
maxtherabbit wrote on 2023-10-05, 16:24:
Wait a liitle ))
Ok, its long enough.
Reply 647 of 1053, by S95Sedan
Maelgrum wrote on 2023-10-05, 16:19:
sb16dump V0.16 experimental support for 4.12
I hope it works ))
Here you go 😉
    v412.zip
    4.37 KiB
    30 downloads
Reply 651 of 1053, by S95Sedan
Content:
v404-8k_49fc3869
- Original Creative 4.04 Firmware
v405-8k_e51aff23:
- Original Creative 4.05 Firmware
v411-8k_4d75e821
- Original Creative 4.11 Firmware
v412-8k_f69d1672
- Original Creative 4.12 Firmware
v413-6k_9e1b22c6
v413-8k_e22e9001
- Original Creative 4.13 Firmwares
v413-8k_4ca3dca8_patch3
- Fixed hanging note bug
v413-8k_16a46526_patch4
- Fixed PSW bug in ExtInt0/ExtInt1 interrupt handlers
v416-6k_986e5cb9
v416-8k_b15514ef
- Original Creative 4.16 Firmwares
- Added D52 mappings;
( https://www.bipom.com/dis51.php )
    dsp_firmwares_v1.04.zip
    36.82 KiB
    33 downloads
    Fixed crc32 mismatch in v1.03
    d52_413_416_disassembly_mapping.zip
    2.85 KiB
    32 downloads
    D52 Disassembler mapping for v4.13(complete) and v4.16(incomplete)
Reply 652 of 1053, by Maelgrum
So far, we have ALL 4.xx fw (4.04, 4.05, 4.11, 4.12, 4.13, 4.16).
4.16 and 4.12 was not previously known as dumped. Great job done !
Мy sincere gratitude to everyone involved in the project.
Special thanks to main testers: @S95Sedan and @mattw !
Reply 655 of 1053, by georgel
Maelgrum wrote on 2023-10-05, 16:34:
sb16dump V0.17 support for v4.12
Now since no new firmware will be released by Creative, the fun with dumping can only continue with clone cards. On the other hand have you checked how 4.16 is fixed against hanging notes bugs? Looks the most proper way to improve the firmware is to make fixes on 4.13.
Reply 656 of 1053, by maxtherabbit
Maelgrum wrote on 2023-10-05, 16:49:
maxtherabbit wrote on 2023-10-05, 16:48:
Still doesn't work on my CT2760
May be NMI sensitive mb ?
Not sure it has anything to do with the NMI, once I masked it by writing 0x80 to port 0x70 the v0.16 dumper failed gracefully
Reply 657 of 1053, by S95Sedan
Maelgrum wrote on 2023-10-05, 16:47:
So far, we have ALL 4.xx fw (4.04, 4.05, 4.11, 4.12, 4.13, 4.16). 4.16 and 4.12 was not previously known as dumped. Great job […]
Nice job on the coding.
I changed my post a bit aswell and added d52 mappings i have so far, as only 4.05 was partially done.
Used https://github.com/schlae/sb-firmware/tree/master as reference.
Reply 659 of 1053, by Maelgrum
maxtherabbit wrote on 2023-10-05, 16:52:
Now, with known dump of 4.12, i can try to find other attack route. May be without NMI triggering in process ))
