50 to 133MHz FSB on a BX Mainboard
Reply 69 of 75, by gerwin
Ok. So you are at 600MHz currently. If you are not interested in the speed switching then the benefit is less. Depends on what you want to achieve. Getting a plain 8.0x100MHz CPU may be a lot easier, Whilst getting a tualatin+adapter gives even more speed.
I made a few benchmarks with Quake v1.08, it shows the average FPS.
From pure DOS: Video mode 640x480, timedemo 2, nosound, nojoy.
System: GA-6BXC with Tualeron QID2QS CPU. 128MB RAM. Voodoo3 video, either AGP or PCI variant. AGP divider=2/3.
With and without 'MTRRLFBE LFB WC' (write combining).
Speed MHz   PCI+WC  AGP+WC  PCI    AGP
4x_50=200 25,9 26,0 13,7 13,7
4x_66=266 34,3 34,4 18,2 18,2
4x100=400 50,5 50,9 25,0 27,0
4x133=533 66,4 67,5 27,0 35,8
8x_66=533 55,7 56,3 21,0 21,1
Edit: added missing benchmark entries
Reply 70 of 75, by d1stortion
gerwin wrote:
My Geforce MX440 does not like it either. Regarding the other problems, was the PCI bus at 33MHz?
Yes it was. The mobo in question is a CUBX-E, so certainly not some cheapskate board. When I bought it it had an 800EB in it, so I assume the previous owner ran it like that without problems. Or he just settled for 600 MHz, who knows? 🤣
Reply 71 of 75, by idspispopd
Nahkri wrote:
Actually it officialy supports the k6 3,and the k6 2+ beeing a k6 3 with 128mb cache,i guess it supports that 1 too 😜
The K6-2+ is a K6-3+ with 128kB cache, it needs a lower voltage than a K6-3 and BIOS support to enable all features.
Reply 72 of 75, by gerwin
Yesterday I wanted to see if I can undervolt the Pentium II and III processors. At least for the speeds up to 533 MHz.
The Pentium III Tualatin core (default 1,5V) was on 1,3V already and I have currently no means to lower it further. Works fine even up to 1000MHz. I remember Swaaye wrote about his Tualatin running fine with just 1,1V.
The Pentium III Coppermine core impressed me: SL3VA (default 1,65V) accepted all voltages, it ended up at the lowest setting: 1,3V (measured 1,325V). Let it run Quake for an hour without any problems. I tape-modded the other two coppermine core CPUs (in the picture on the right), as native slot-1 leaves me no jumpers. They behave similar, but need more testing.
The benefit is that they don't really need a fan at 1,3V at 533MHz or less. So up to 533 MHz the Coppermine core is practically the same as a Tualatin core. Making SL3VA, SL3XG and especially the ES more interesting for my use.
Next in line was a Pentium II Deschutes core (default 2,0V). 1,8V with 400MHz was not a reliable combination for the SL2QF. Raised it back to 1,9V which did not cause any problems yet. This processor was originally in the package on the left of it. I removed the package to read the L2 cache specs, and add L2 cache cooling and a new fan.
Also shown is the Pentium II Klamath core SL2HD with its heavy heatsink. Defaults to 2,8V. Maybe I will mess with it later.
Reply 73 of 75, by Gustl
Good day
Colleagues
It's an old article, but I would like to contribute my observations and ask if one or more people can check it and, if necessary, confirm or refute it.
Gigabyte ga-6bxc ver.1.7 450mhz cpu 256mb ram,
Geforce 6200 524MB ram
win98se and ME
only possible with 16 colors and a resolution of 640x480.
Error message:
Graphics card and motherboard use the same system resources.
My question is, are there any users who successfully use ATI cards on the system?
Because I only own Geforce cards and don't want to write off a working board.
Have a nice day.
Reply 74 of 75, by gerwin
Gustl wrote on 2023-10-05, 08:25:
It would have been better to start a new topic. The only resemblance to this topic is the motherboard series, but nothing else.
That graphics RAM size is oddly high. Look here instead:
512MB Geforce 6200 AGP in Windows 98SE?
As an addendum to that: Most BIOS'es for GA-6BXC cannot disable ACPI, there was a modded BIOS posted on Vogons, adjusted to allow for disabling ACPI. I have not tried it myself yet.
Link: Re: Powerleap PL-IP3/T and GA-6BXC MB
More Here: http://www.vogonsdrivers.com/getfile.php?fileid=727
Reply 75 of 75, by Gustl
Thanks
