First post, by Totempole
I'm trying to get a 512MB Geforce 6200 AGP card working in a VIA Apollo based Pentium 3 Machine with Windows 98SE. I'm doing it to replace a faulty Geforce 4 MX-440.
The problem in all likelihood is the amount of RAM on the card. Right from the outset Windows 98SE reports a display problem (resource conflict). The drivers install fine, but the display error remains. It looks like it's conflicting with ACPI. There doesn't seem to be a BIOS option which can help. It's not an IRQ issue, it's a conflicting memory range.
Is there a solution to this problem, or should I just try and get hold of another card with less RAM?
The PC itself has 256MB of RAM installed.
Any advice would be greatly appreciated.
Thanks.
My Retro Gaming PC:
Pentium III 450MHz Katmai Slot 1
Transcend 256MB PC133
Gigabyte GA-6BXC
MSI Geforce 2 MX400 AGP
Ensoniq ES1371 PCI
Sound Blaster AWE64 ISA
Reply 1 of 13, by The Serpent Rider
512mb VRAM video card with Win 98 is a recipe for disaster.
Reply 2 of 13, by Totempole
I am aware, but was hoping for a potential workaround?
My Retro Gaming PC:
Gigabyte GA-6BXC
Ensoniq ES1371 PCI
Reply 3 of 13, by The Serpent Rider
Probably none with 256mb RAM installed.
Reply 4 of 13, by Totempole
Well I could easily reduce the amount of RAM in the machine if that would make a difference.
My Retro Gaming PC:
Gigabyte GA-6BXC
Ensoniq ES1371 PCI
Reply 5 of 13, by agent_x007
Try decreasing AGP Aperture Size (to 4-16MB range).
Reply 6 of 13, by Totempole
Thanks, but I've already tried that. No luck.
Interesting thing is, I've tried the card in an Intel 815 chipset board with Windows 98SE, and it works without any issues.
So I'm guessing this is an issue which relates to VIA chipset motherboards.
My Retro Gaming PC:
Gigabyte GA-6BXC
Ensoniq ES1371 PCI
Reply 7 of 13, by Jorpho
If that's the case, ACPI can be disabled with a little registry edit. There should be a thread around here with details.
I would disagree about the amount of RAM on the card being inherently problematic.
There have been reports that using HIMEMX may be of use in achieving stability with NVidia cards, even if it's not being used to limit RAM. It's easy enough to try, anyway.
Reply 8 of 13, by Voset
There is a patch for 512mb Nvidia Cards under Windows 9x being sold at http://rloew.x10host.com/catalog2.htm. There is also a demo for the patch to try for free to see if it helps with your problem.
Reply 9 of 13, by chinny22
I had all sorts of problems with my 6800 Ultra AGP in a P4 with 4GB ram and trying the various free tweaks on the net.
Obviously 4GB Ram is the main issue so ended up getting rloew's RAM (not vram) patch, this also fixed blue screens after installing NVidia drivers as well.
Just mentioning it if you run out of other things to try, your system is obviously very different to mine
Reply 10 of 13, by asdf53
Voset wrote on 2017-06-09, 09:42:
This patch was made available for free, here's a link to it on Phil's site: https://www.philscomputerlab.com/rudolph-r-loew-patches.html (PTCHNVSZ.zip in the archive)
It worked great for me. I was trying a 7600 GT 512MB with the modded drivers 82.69 for Windows 98, but I got garbled graphics at the boot screen and then it stopped with a blinking cursor. Also the mouse cursor would freeze. Both of these issues are addressed with the patch. First the "driver patch" (patch nvcore.vxd in Windows/system), then install the FIXINTR patch to fix the mouse cursor. After installing the patch, I could only set a maximum resolution of 1024x768, but after a second reboot, the other resolutions became available as well.
Reply 11 of 13, by INPSLover69
Any updates? I'm having the same problem but NVCHECK says memory space is correctly allocated... I've also patched the 82.69 drivers with no luck. What should I do?
Reply 12 of 13, by Sphere478
Idk what processor OP has, but 6200 doesn’t work very well on 586 so that’s another thing.
Anyway, As posted above. There is now a patch for the memory thing.
Sphere's PCB projects.
Reply 13 of 13, by Disruptor
Oh, a necro.
With cards up to 128 MB there is no problem,
but with 256 MB a friend of mine (mkarcher) fixed ACPI by writing a little DOS program for that particular system.
So it is likey that turning off ACPI will help.
