Reply 720 of 723, by MikArt
Mamba wrote on 2026-10-05, 17:21:I see but this is 1mbyte, I mean just a pin to pin 4ns chip of 512kb.
I do not intend to do the 1mb mod.
W25P243AF-4A (4,5 ns) could try
bloodem wrote on 2026-10-05, 17:56:Mamba wrote on 2026-10-05, 17:21:I see but this is 1mbyte, I mean just a pin to pin 4ns chip of 512kb.
I do not intend to do the 1mb mod.If you simply replace the cache chip with a larger pin compatible version (like the aforementioned LP61L64128F-4), the board will work just fine and treat the chip as a 512kB SRAM (if you don't change the resistor configuration). I know I did this test on one of my P5A-B rev 1.04 boards and it worked fine.
Though, truthfully, you might as well just go all the way and increase the cache to 1 MB, changing the resistors takes a few minutes. 😀
Not sure I understood the process.
Mamba wrote on 2026-10-05, 18:25:Not sure I understood the process.
Basically, you can replace the original 512KB 5ns SRAM IC with a 1MB 4ns SRAM IC, and it will continue to be detected as 512KB (but will be faster), just like you wanted.
2 x PLCC-68 / 4 x PGA132 / 5 x Skt 3 / 1 x Skt 4 / 9 x Skt 7 / 12 x SS7 / 1 x Skt 8 / 21 x Slot 1 / 8 x Slot A
Current PC: Ryzen 7 9800X3D
Backup: Ryzen 7 5800X3D
bloodem wrote on 2026-10-05, 18:37:Mamba wrote on 2026-10-05, 18:25:Not sure I understood the process.
Yes this is clear, I meant the process to have 1mb
