Reply 720 of 735, by sdz
Duffman wrote on 2025-10-06, 10:31:@sdz […]
@sdz
Nicely done!
I'm sure there will be many ITX llama users delighted that they can use Nvidia cards on their builds now.On a topic of Nvidia cards - I have a Vortex86DX3 build of mine (using an ETX module and IP412 carier board), whenever I've tried to run an Nvidia Geforce FX 5500 PCI (no AGP on carrier board) and, even though I assign an IRQ to the card. I always got these strange artifacts when I tried to boot 98SE on it (after the nvidia driver install, the basic 16 color VGA driver still works).
Did you ever encounter this kind of visual artifacting during your testing?
I can't say I've encountered that kind of visual artifacting (but I also can't say I really tested Nvidia cards before patching the BIOS 😀 )
Dothan Burger wrote on 2025-10-06, 10:40:sdz wrote on 2025-10-06, 09:24:However, it did fix it for other cards. Here is an unmodified AGP Nvidia Geforce FX5200 plugged into the Llama: […]
Both VGA and HDMI outputs work, as well as OpenGL and D3D:
Of course, more testing is needed (also need to ensure it doesn't break other things).
WOW! what a huge breakthrough SDZ. I'm huge nvidiot and was a little disappointed when the Llama wouldn't work with my GeForces.
They may work now 😀 I have only tested the FX5200, as I don't have other AGP Nvidia cards (maybe a TNT2 somwhere? ), but I expect other cards to work now (maybe not all of them).
Some updates regarding the S3 cards.
I have tried VBE9x with the S3 with Llama and the vanilla BIOS. It resulted in a garbled screen/frozen system.
With the patched BIOS VBE9x now works with the S3 Savage4 Pro:
Higher resolutions supported by VGA:
Now, VBE9x isn't ideal (compared to the S3 drivers) but it still beats 640x480@4 colors.
