Reply 7580 of 32080, by derSammler
TheAbandonwareGuy wrote:
Apparently Opti ISA Chipset 82C931 aka "Opti Audio 16" isn't even a 16-bit card. It's a Soundblaster Pro 1.0 (not 2.0/Old) clone. Weird considering I was under the impression that it was a SB16 clone.
There are no SB16 clones apart from some ALS and CMI sound chips.
The 82C931 does 16 bit using WSS, just like most other cards from that time. Also, it's certainly NOT a SB Pro 1.0 clone, as then it would do stereo FM using two OPL2s.
Reply 7581 of 32080, by TheAbandonwareGuy
Well its detected, and running as a SB Pro 1. Stereo sound is working fine.
Cyb3rst0rm.com: Here There Be Screeds https://www.cyb3rst0rm.com
Reply 7582 of 32080, by derSammler
Try a game that uses dual OPL2, it won't work.
Anyway, repaired an ATX PSU today and desoldered lots of caps, piezo speakers, and USB ports from three old mainboard befor scapping them.
Reply 7583 of 32080, by oeuvre
Upgraded my Optiplex GX1 from Pentium II 350MHz to a 1GHz Celeron via slocket. Works like a charm! Just had to zip tie it all in there.
Reply 7584 of 32080, by luckybob
that blue heatsink though...
Reply 7585 of 32080, by bjwil1991
Windows NT 4.0 Workstation? I haven't used that OS in years.
Reply 7586 of 32080, by oeuvre
Bought the cheapest new socket 370 one I found on ebay a few weeks ago
Reply 7587 of 32080, by BeginnerGuy
That's awesome!
One of these days I'm going to invest in a slotket that can run a tualatin.. You know because reasons.. 😊
Sup. I like computers. Are you a computer?
Reply 7588 of 32080, by oeuvre
I might be using this machine for retina burning purposes.
Reply 7590 of 32080, by squiggly
You're going to hell.
Reply 7591 of 32080, by gdjacobs
Diagnostic for epilepsy?
Reply 7592 of 32080, by oeuvre
Believe me, I can make it worse.
Super trippy epilepsy warning. https://i.imgur.com/sAwdLKY.gif
Reply 7593 of 32080, by TheAbandonwareGuy
My head after watching that:
Reply 7594 of 32080, by luckybob
https://www.youtube.com/watch?v=3Eox1ogr3SE
But seriously, I finally got to use my cheap chinese hot-air rework station. I only lifted ONE pad!
huzzah!
it is the left one - i glued it back down, HOPEFULLY it sticks.
Reply 7595 of 32080, by derSammler
Restored an ASRock K7S41GX Socket A mainboard from the pile of scrap mainboards I got lately. Has a Duron 800 now, 512 MB DDR RAM, new coolers etc. May use it in the future for a ME/XP build.
The attachment IMG_20171222_134851763.jpg is no longer available
Reply 7596 of 32080, by TheAbandonwareGuy
Did any of the other mobo's survive?
Reply 7597 of 32080, by luckybob
I have the Pentium 4 version of that asrock board. It actually is a neat little board. I used it for a while as a hard drive sanitizer. Still have it, I just use a usb adapter now. 😜
Reply 7598 of 32080, by Ozzuneoj
I saved this pair from a scrap lot for $15 shipped. An Aureal Vortex 2 SQ2500 and a Diamond Monster Sound MX400. I'm quite happy about that. The MX400 has some scratches around the ports on the back from the back plate being removed, but the seller actually found the plates and reinstalled them for me before shipping these out (I had mentioned that I'm not a scrapper and intend to use or fix them if necessary). I'm honestly still amazed. They definitely have good feedback coming their way...
One SMD electrolytic missing from the MX400, but it is the same exact type that most Voodoo cards use from this era, so I have a bunch of them. They're easy to replace.
Reply 7599 of 32080, by derSammler
Seems so. I did not test all of them yet, for many I don't even have a fitting CPU. From 3 tested, 2 worked, which is a good rate so far. 5 were beyond repair (not even tested due to severe physical damage).
