UniPCemu progress
Reply 760 of 781, by superfury
And trying to run the Windows 3.1 setup.exe under MS-DOS 6.22 running a CD-ROM driver (OAKCDROM) and EMM386 loaded, I see the CPU get into the hang condition trying to #GP(0) fault for a IN AL,DX instruction. Though this should have worked properly.
Edit: Managed to fix the issue.
Windows 3.x's EMM386 somehow doesn't detect all RAM? It only shows 256KB of EMS memory available, unlike MS-DOS EMM386's 50ish MB (all HIMEM extended memory).
Edit: Checked Windows 3.1 EMM386.SYS without parameters. It only reports 256K (262144 bytes) of EMS memory? That's of 640K EMS memory total, as reported by the driver to MEM.EXE.
So there's definitely going something wrong with it's execution.
UniPCemu Git repository
Reply 761 of 781, by superfury
I do notice something interesting with Windows 3.1.
Running it in Standard mode, even with EMM386 loaded, runs fine. I can run apps fine.
But when in calc.exe I try to perform any of the buttons, it gives a beep and does nothing (except give a beep).
Only the C (clear) button works, which causes the text "Invalid value for this" to flash a few times before resetting to 0.
Opening the app also gives said value inside the current output box. Using the Edit and View menu items gives a beep also, doing nothing.
So does 'Search for help on...'. The other help menu items function as they should (opening the help, which seems fully functional).
Reply 762 of 781, by superfury
Just found an issue with the segment write function detecting if it's active or not. It increments a variable to indicate it's active and is supposed to decrease it when it terminates (keeping track of if it's recursively called or not executing for internal state reset purposes). When it was executing a stack access that was pending or faulting, it would mistakenly increase the counter before returning to the calling function (the opcode handler) instead of properly decreasing the counter.
So that would cause future segment (and descriptor) handling to correctly increase it, where the level of the handler was always 1 (or for multiple calls) even higher. A bit like Windows' IRQL getting stuck on a higher level instead of properly decreasing, with some calls increasing the level even further (which isn't supposed to happen).
So in that case, even handling that isn't using said function is behaving as if it's called by the recursive handler, resetting instruction state (changed registers, changed descriptor caches etc.) upon being handled, instead of handling it like a non-resetting instruction (or task switch-specific behaviour failing becauseo of this, as it runs some things without said resetting behaviour (which is required for it to function properly)).
Reply 763 of 781, by superfury
Fixed some issues with the latest TSS reads/writes in protected mode. The accesses were using the privilege level of the running application instead of being performed at proper privilege level 0 (causing TLB misses due to the accesses when being done at privilege level 3 context to not translate the memory accesses, effectively accessing unmapped RAM locations for higher half kernels, for example linear memory location past the amount of physical memory or BIOS ROM accesses at FFFF0000+).
Reply 764 of 781, by superfury
Improved the logging of the memory transactions a bit.
It now uses various text lookup tables to determine how to log the data of a bus transaction, which depend on the type of bus transaction being logged as well as various other settings.
It will now also log 64-bit addresses on the memory bus itself (new behaviour), while only using 32-bit addresses for paged or segmented (actually offset) addresses (called Normal in the logs) and log the IO addresses using 16-bit numbers (4 hexadecimal digits) like it did before.
Thus the complexity of the function has increased a bit due to the extra text strings being used, but reduced due to the many duplicate code being merged into one common case (just various text values change depending on the logging mode after all).
Reply 765 of 781, by superfury
Ok. Windows still crashes in 386 mode and calc still fails in all CPU/windows modes(real, standard and even 386 enhanced mode before the paging and protected mode through BIU changes). But somehow the diagnostics from hiren's bootcd 7.1 don't fail (the troubleshooter tested as well as pc doctor), both reporting no errors on the cpu somehow? Perhaps protected mode through BIU-with-paging only issues somehow? But EMM386+standard mode runs, so it at least works partially? Why would win.exe terminate itself to MS-DOS prompt? I don't see any page faults (that happen when the GUI starts)? So paging probably isn't the issue itself somehow?
Checked the BIU using my simple testbiu test program (aligned and unaligned reads and writes are checked), but it checks out without errors. Perhaps another fault is occurring?
According to AI it's probably memory read/write issues, seeing as either calc.exe or the FPU emulation driver is failing (with 10 byte data somehow)?
Reply 766 of 781, by superfury
Tried all known testsuites I have for validating the CPU (except the 386 tests by GloriousCow).
All say they pass.
But Windows still crashes in the 386+ modes and the calc.exe issue is still there?
The main thing I changed that causes Windows to crash is seemingly routing the protected mode mechanics through the BIU (paging implemented first, followed by the other protected mode handling).
The main thing that changed there is some restart logic and some caching for all memory reads and stepping through interrupting the function just like with the normal x86 opcodes. Only the x86 registers and descriptor caches that need re-applying for the instruction are reset to their start-of-instruction state, applied again and again until a fault occurs or the 'instruction' finishes (the next instruction is ready to execute). This effectively runs the instructions till their breakpoint (which aborts it). And said breakpoint reverses all changes it did and makes it re-execute effectively. The counters for the current iteration are reset, while the progress counters increase as more of an instruction is executed.
Said breakpoints happen on all and any memory access, which causes the instruction to abort by returning to the main loop until the BIU is ready again with the results of the memory transaction.
Reply 767 of 781, by superfury
OK. Interesting. Various 386+ software runs fine (Doom, CPU diagnostic software, Simcity 2000).
But Windows 3.x (3.0, 3.1, 3.11, as well as for workgroups) all crash in 386 enhanced mode (just quits without any error message), while calc.exe fails in all modes and I get a runtime error 200 with stuff like WhatVGA even (even though the CPU is only at 3M cycles per second in cycle-accurate mode, happening after it listing an empty list of PCI devices). Standard mode runs without visible issues other than calc.exe's button and calculation issue.
Reply 768 of 781, by superfury
Just found a very old x86 bug in my emulator.
When returning from an interrupt using IRET, it checks the NT flag. But in Virtual 8086 mode, it doesn't (as it will fault or handle it internally).
So the only way to get it to trigger is during an IRET in protected mode, in the V86 monitor to be specific.
The issue here was that when the V86 monitor is called through the interrupt, it cleared the NT flag (just as it does for all protected mode interrupts, which are documented for all those other interrupt cases). What my emulator thus didn't implement is specifically leaving the NT flag alone when executing a V86 monitor interrupt or exception. Thus allowing the monitor's IRET to instead of returning back to the V86 mode, return to the task that CALLed the specified task. Thus allowing this case to work properly.
Although that means that any interrupt or exception in V86 mode will actually terminate the V86 task in the V86 monitor, even when you might not want that? Or the monitor itself would need to take care of handling that flag.
Edit: But that crashes EMM386? Bochs also agrees it should clear said flag during interrupts from V86 mode?
Reply 769 of 781, by superfury
Hmmm... Executing Windows 3.0 in 386 enhanced mode (/3 switch), I see it executing an IRETD to Virtual 8086 mode, but EFLAGS is loaded with 0x20000? So most sensitive instructions (interrupt flag, pushf/popf, STI, CLI etc.) are faulting to the V86 monitor.
Eventually it hits a POPF instruction in there, which causes a #GP(0) fault, which causes the OS to crash the VM it seems? I see the "crash VM" request from the int 20h (although it has bit 15 set, which is cleared before looking it up it seems) being called in the kernel.
Reply 770 of 781, by superfury
Hmmm... Various programs seem to incorrectly execute an "INT 00h" instruction, crashing said program? For example CheckIt diagnostics, various pascal programs etc.?
For example:
BIU -- I
BIU -- -
BIU -- S
BIU -- - 373b:00002e0f 75 10 jnz 00002e21
Registers:
EAX: 80000000 EBX: 0000f866 ECX: 000012a6 EDX: 0000373b
ESP: 0000f870 EBP: 0000f87a ESI: 00000082 EDI: 00fff94d
CS: 373b DS: 4deb ES: 4deb FS: 0000 GS: 0000 SS: 4deb TR: 0000 LDTR: 0000
EIP: 00002e0f EFLAGS: 00007246
CR0: 00000010 CR2: 00000000 CR3: 00000000 CR4: 00000000
DR0: 00000000 DR1: 00000000 DR2: 00000000 DR3: 00000000
DR6: 00000000 DR7: 00000000
GDTR: 00000008f466ffff IDTR: 00000000000003ff
CS descriptor: 0000930373B0FFFF
SS descriptor: 00009304DEB0FFFF
DS descriptor: 00009304DEB0FFFF
ES descriptor: 00009304DEB0FFFF
FS descriptor: 000093000000FFFF
GS descriptor: 000093000000FFFF
TR descriptor: 000082000000FFFF
LDTR descriptor: 000082000000FFFF
Previous CS:EIP: 373b:00002e09
FLAGSINFO: 0000000000ipfavr0N11odItsZ0a0P1c
BIU -- -
BIU -- -
BIU -- I
BIU T1 - Paged(p):0003a1fe=08(◘); Normal(p):00002e4e=08(◘); Paged(p):0003a1ff=26(&); Normal(p):00002e4f=26(&); MemoryBus(p):000000000003a200=01203e80(☺ >Ç); Paged(p):0003a200=80(Ç); Normal(p):00002e50=80(Ç); Paged(p):0003a201=3e(>); Normal(p):00002e51=3e(>)
BIU -- S
BIU -- - 373b:00002e11 2B C0 sub ax,ax
Registers:
EIP: 00002e11 EFLAGS: 00007246
Previous CS:EIP: 373b:00002e0f
BIU -- -
BIU -- I
BIU -- - 373b:00002e13
BIU T1 - 373b:00002e13 MemoryBus(w):000000000005d71e=00( ); RAM(w):000000000005d71e=0000( ); RealRAM(w):000000000005d71e=0000( ); Paged(w):0005d71e=0000( )
BIU -- - 373b:00002e13 50 push ax
Registers:
Show last 4385 lines
EIP: 00002e13 EFLAGS: 00007246
Previous CS:EIP: 373b:00002e11
BIU -- -
BIU -- I
BIU -- - 373b:00002e14
BIU T1 - 373b:00002e14 MemoryBus(w):000000000005d71c=00( ); RAM(w):000000000005d71c=0000( ); RealRAM(w):000000000005d71c=0000( ); Paged(w):0005d71c=0000( )
BIU -- - 373b:00002e14 50 push ax
Registers:
ESP: 0000f86e EBP: 0000f87a ESI: 00000082 EDI: 00fff94d
EIP: 00002e14 EFLAGS: 00007246
Previous CS:EIP: 373b:00002e13
BIU -- -
BIU -- I
BIU T1 - 373b:00002e15 Paged(p):0003a202=20( ); Normal(p):00002e52=20( ); Paged(p):0003a203=01(☺); Normal(p):00002e53=01(☺); Paged(p):0003a204=07(•); Normal(p):00002e54=07(•); Paged(p):0003a205=75(u); Normal(p):00002e55=75(u)
BIU -- - 373b:00002e15
BIU T1 - 373b:00002e15 MemoryBus(w):000000000005d71a=00( ); RAM(w):000000000005d71a=0000( ); RealRAM(w):000000000005d71a=0000( ); Paged(w):0005d71a=0000( )
BIU -- - 373b:00002e15 50 push ax
Registers:
ESP: 0000f86c EBP: 0000f87a ESI: 00000082 EDI: 00fff94d
EIP: 00002e15 EFLAGS: 00007246
Previous CS:EIP: 373b:00002e14
BIU -- -
BIU -- I
BIU -- - 373b:00002e16
BIU T1 - 373b:00002e16 MemoryBus(w):000000000005d718=00( ); RAM(w):000000000005d718=0000( ); RealRAM(w):000000000005d718=0000( ); Paged(w):0005d718=0000( )
BIU -- - 373b:00002e16 50 push ax
Registers:
ESP: 0000f86a EBP: 0000f87a ESI: 00000082 EDI: 00fff94d
EIP: 00002e16 EFLAGS: 00007246
Previous CS:EIP: 373b:00002e15
BIU -- -
BIU -- I
BIU -- - 373b:00002e17
BIU T1 - 373b:00002e17 MemoryBus(w):000000000005d716=00( ); RAM(w):000000000005d716=0000( ); RealRAM(w):000000000005d716=0000( ); Paged(w):0005d716=0000( )
BIU -- - 373b:00002e17 50 push ax
Registers:
ESP: 0000f868 EBP: 0000f87a ESI: 00000082 EDI: 00fff94d
EIP: 00002e17 EFLAGS: 00007246
Previous CS:EIP: 373b:00002e16
BIU -- -
BIU -- I
BIU -- - 373b:00002e18
BIU T1 - 373b:00002e18 MemoryBus(w):000000000005d714=00( ); RAM(w):000000000005d714=0000( ); RealRAM(w):000000000005d714=0000( ); Paged(w):0005d714=0000( )
BIU -- - 373b:00002e18 50 push ax
Registers:
ESP: 0000f866 EBP: 0000f87a ESI: 00000082 EDI: 00fff94d
EIP: 00002e18 EFLAGS: 00007246
Previous CS:EIP: 373b:00002e17
BIU -- -
BIU -- I
BIU T1 - Paged(p):0003a206=07(•); Normal(p):00002e56=07(•); Paged(p):0003a207=c7(╟); Normal(p):00002e57=c7(╟); Paged(p):0003a208=46(F); Normal(p):00002e58=46(F); Paged(p):0003a209=f6(÷); Normal(p):00002e59=f6(÷)
BIU T1 S Paged(p):0003a20a=00( ); Normal(p):00002e5a=00( ); Paged(p):0003a20b=00( ); Normal(p):00002e5b=00( ); Paged(p):0003a20c=eb(δ); Normal(p):00002e5c=eb(δ); Paged(p):0003a20d=05(♣); Normal(p):00002e5d=05(♣)
BIU -- - 373b:00002e19
BIU T1 - 373b:00002e19 MemoryBus(w):000000000005d712=3b(;); RAM(w):000000000005d712=373b(7;); RealRAM(w):000000000005d712=373b(7;); Paged(w):0005d712=373b(7;)
BIU T1 - 373b:00002e19 MemoryBus(w):000000000005d710=1e(▲); RAM(w):000000000005d710=2e1e(.▲); RealRAM(w):000000000005d710=2e1e(.▲); Paged(w):0005d710=2e1e(.▲)
BIU -- E 373b:00002e19 9A DE 4E 3B 37 call 373b:00004ede
Registers:
ESP: 0000f864 EBP: 0000f87a ESI: 00000082 EDI: 00fff94d
EIP: 00002e19 EFLAGS: 00007246
Previous CS:EIP: 373b:00002e18
BIU T1 - RealRAM(p):000000000003c28e=8b55(ïU); RAM(p):000000000003c28e=8b55(ïU); MemoryBus(p):000000000003c28e=8b55(ïU); Paged(p):0003c28e=55(U); Normal(p):00004ede=55(U); Paged(p):0003c28f=8b(ï); Normal(p):00004edf=8b(ï); MemoryBus(p):000000000003c290=065657ec(♠VW∞); Paged(p):0003c290=ec(∞); Normal(p):00004ee0=ec(∞); Paged(p):0003c291=57(W); Normal(p):00004ee1=57(W)
BIU T1 - Paged(p):0003c292=56(V); Normal(p):00004ee2=56(V); Paged(p):0003c293=06(♠); Normal(p):00004ee3=06(♠); Paged(p):0003c294=1e(▲); Normal(p):00004ee4=1e(▲); Paged(p):0003c295=8e(Ä); Normal(p):00004ee5=8e(Ä)
BIU T1 - Paged(p):0003c296=06(♠); Normal(p):00004ee6=06(♠); Paged(p):0003c297=60(`); Normal(p):00004ee7=60(`); Paged(p):0003c298=ce(╬); Normal(p):00004ee8=ce(╬); Paged(p):0003c299=26(&); Normal(p):00004ee9=26(&)
BIU T1 - Paged(p):0003c29a=a1(í); Normal(p):00004eea=a1(í); Paged(p):0003c29b=38(8); Normal(p):00004eeb=38(8); Paged(p):0003c29c=01(☺); Normal(p):00004eec=01(☺); Paged(p):0003c29d=3d(=); Normal(p):00004eed=3d(=)
BIU T1 - Paged(p):0003c29e=00( ); Normal(p):00004eee=00( ); Paged(p):0003c29f=00( ); Normal(p):00004eef=00( ); MemoryBus(p):000000000003c2a0=00b81a77( ╕→w); Paged(p):0003c2a0=77(w); Normal(p):00004ef0=77(w); Paged(p):0003c2a1=1a(→); Normal(p):00004ef1=1a(→)
BIU T1 - Paged(p):0003c2a2=b8(╕); Normal(p):00004ef2=b8(╕); Paged(p):0003c2a3=00( ); Normal(p):00004ef3=00( ); Paged(p):0003c2a4=00( ); Normal(p):00004ef4=00( ); Paged(p):0003c2a5=8e(Ä); Normal(p):00004ef5=8e(Ä)
BIU T1 - Paged(p):0003c2a6=06(♠); Normal(p):00004ef6=06(♠); Paged(p):0003c2a7=5e(^); Normal(p):00004ef7=5e(^); Paged(p):0003c2a8=ce(╬); Normal(p):00004ef8=ce(╬); Paged(p):0003c2a9=26(&); Normal(p):00004ef9=26(&)
BIU T1 - Paged(p):0003c2aa=c7(╟); Normal(p):00004efa=c7(╟); Paged(p):0003c2ab=06(♠); Normal(p):00004efb=06(♠); Paged(p):0003c2ac=36(6); Normal(p):00004efc=36(6); Paged(p):0003c2ad=01(☺); Normal(p):00004efd=01(☺)
BIU T1 - Paged(p):0003c2ae=01(☺); Normal(p):00004efe=01(☺); Paged(p):0003c2af=00( ); Normal(p):00004eff=00( ); MemoryBus(p):000000000003c2b0=ce60068e(╬`♠Ä); Paged(p):0003c2b0=8e(Ä); Normal(p):00004f00=8e(Ä); Paged(p):0003c2b1=06(♠); Normal(p):00004f01=06(♠)
BIU T1 - Paged(p):0003c2b2=60(`); Normal(p):00004f02=60(`); Paged(p):0003c2b3=ce(╬); Normal(p):00004f03=ce(╬); Paged(p):0003c2b4=26(&); Normal(p):00004f04=26(&); Paged(p):0003c2b5=8c(î); Normal(p):00004f05=8c(î)
BIU T1 - Paged(p):0003c2b6=1e(▲); Normal(p):00004f06=1e(▲); Paged(p):0003c2b7=38(8); Normal(p):00004f07=38(8); Paged(p):0003c2b8=01(☺); Normal(p):00004f08=01(☺); Paged(p):0003c2b9=e9(Θ); Normal(p):00004f09=e9(Θ)
BIU T1 - Paged(p):0003c2ba=c6(╞); Normal(p):00004f0a=c6(╞); Paged(p):0003c2bb=00( ); Normal(p):00004f0b=00( ); Paged(p):0003c2bc=8e(Ä); Normal(p):00004f0c=8e(Ä); Paged(p):0003c2bd=06(♠); Normal(p):00004f0d=06(♠)
BIU T1 - Paged(p):0003c2be=5c(\); Normal(p):00004f0e=5c(\); Paged(p):0003c2bf=ce(╬); Normal(p):00004f0f=ce(╬); MemoryBus(p):000000000003c2c0=2a368a26(*6è&); Paged(p):0003c2c0=26(&); Normal(p):00004f10=26(&); Paged(p):0003c2c1=8a(è); Normal(p):00004f11=8a(è)
BIU T1 - Paged(p):0003c2c2=36(6); Normal(p):00004f12=36(6); Paged(p):0003c2c3=2a(*); Normal(p):00004f13=2a(*); Paged(p):0003c2c4=01(☺); Normal(p):00004f14=01(☺); Paged(p):0003c2c5=8b(ï); Normal(p):00004f15=8b(ï)
BIU T1 - Paged(p):0003c2c6=76(v); Normal(p):00004f16=76(v); Paged(p):0003c2c7=0a( ); Normal(p):00004f17=0a( ); Paged(p):0003c2c8=8e(Ä); Normal(p):00004f18=8e(Ä); Paged(p):0003c2c9=5e(^); Normal(p):00004f19=5e(^)
BIU T1 - Paged(p):0003c2ca=0c(♀); Normal(p):00004f1a=0c(♀); Paged(p):0003c2cb=8b(ï); Normal(p):00004f1b=8b(ï); Paged(p):0003c2cc=7e(~); Normal(p):00004f1c=7e(~); Paged(p):0003c2cd=0e(♫); Normal(p):00004f1d=0e(♫)
BIU -- I
BIU -- - 373b:00004ede
BIU T1 - 373b:00004ede MemoryBus(w):000000000005d70e=7a(z); RAM(w):000000000005d70e=f87a(°z); RealRAM(w):000000000005d70e=f87a(°z); Paged(w):0005d70e=f87a(°z)
BIU -- - 373b:00004ede 55 push bp
Registers:
ESP: 0000f860 EBP: 0000f87a ESI: 00000082 EDI: 00fff94d
EIP: 00004ede EFLAGS: 00007246
Previous CS:EIP: 373b:00002e19
BIU -- -
BIU -- I
BIU -- -
BIU -- S
BIU -- - 373b:00004edf 8B EC mov bp,sp
Registers:
ESP: 0000f85e EBP: 0000f87a ESI: 00000082 EDI: 00fff94d
EIP: 00004edf EFLAGS: 00007246
Previous CS:EIP: 373b:00004ede
BIU -- -
BIU -- I
BIU T1 - 373b:00004ee1 Paged(p):0003c2ce=8e(Ä); Normal(p):00004f1e=8e(Ä); Paged(p):0003c2cf=46(F); Normal(p):00004f1f=46(F); MemoryBus(p):000000000003c2d0=084e8b10(◘Nï►); Paged(p):0003c2d0=10(►); Normal(p):00004f20=10(►); Paged(p):0003c2d1=8b(ï); Normal(p):00004f21=8b(ï)
BIU -- - 373b:00004ee1
BIU T1 - 373b:00004ee1 MemoryBus(w):000000000005d70c=4d(M); RAM(w):000000000005d70c=f94d(∙M); RealRAM(w):000000000005d70c=f94d(∙M); Paged(w):0005d70c=f94d(∙M)
BIU -- - 373b:00004ee1 57 push di
Registers:
ESP: 0000f85e EBP: 0000f85e ESI: 00000082 EDI: 00fff94d
EIP: 00004ee1 EFLAGS: 00007246
Previous CS:EIP: 373b:00004edf
BIU -- -
BIU -- I
BIU -- - 373b:00004ee2
BIU T1 - 373b:00004ee2 MemoryBus(w):000000000005d70a=82(é); RAM(w):000000000005d70a=0082( é); RealRAM(w):000000000005d70a=0082( é); Paged(w):0005d70a=0082( é)
BIU -- - 373b:00004ee2 56 push si
Registers:
ESP: 0000f85c EBP: 0000f85e ESI: 00000082 EDI: 00fff94d
EIP: 00004ee2 EFLAGS: 00007246
Previous CS:EIP: 373b:00004ee1
BIU -- -
BIU -- I
BIU -- - 373b:00004ee3
BIU T1 - 373b:00004ee3 MemoryBus(w):000000000005d708=eb(δ); RAM(w):000000000005d708=4deb(Mδ); RealRAM(w):000000000005d708=4deb(Mδ); Paged(w):0005d708=4deb(Mδ)
BIU -- - 373b:00004ee3 06 push es
Registers:
ESP: 0000f85a EBP: 0000f85e ESI: 00000082 EDI: 00fff94d
EIP: 00004ee3 EFLAGS: 00007246
Previous CS:EIP: 373b:00004ee2
BIU -- -
BIU -- I
BIU -- - 373b:00004ee4
BIU T1 - 373b:00004ee4 MemoryBus(w):000000000005d706=eb(δ); RAM(w):000000000005d706=4deb(Mδ); RealRAM(w):000000000005d706=4deb(Mδ); Paged(w):0005d706=4deb(Mδ)
BIU -- - 373b:00004ee4 1E push ds
Registers:
ESP: 0000f858 EBP: 0000f85e ESI: 00000082 EDI: 00fff94d
EIP: 00004ee4 EFLAGS: 00007246
Previous CS:EIP: 373b:00004ee3
BIU -- -
BIU -- I
BIU T1 - Paged(p):0003c2d2=4e(N); Normal(p):00004f22=4e(N); Paged(p):0003c2d3=08(◘); Normal(p):00004f23=08(◘); Paged(p):0003c2d4=83(â); Normal(p):00004f24=83(â); Paged(p):0003c2d5=f9(∙); Normal(p):00004f25=f9(∙)
BIU -- S
BIU -- -
BIU -- - 373b:00004ee5
BIU T1 - 373b:00004ee5 MemoryBus(r):000000000005ad10=4deb4deb(MδMδ); Paged(r):0005ad10=eb(δ); Paged(r):0005ad11=4d(M)
BIU -- - 373b:00004ee5 8E 06 60 CE mov es,word ds:[ce60]
Registers:
ESP: 0000f856 EBP: 0000f85e ESI: 00000082 EDI: 00fff94d
EIP: 00004ee5 EFLAGS: 00007246
Previous CS:EIP: 373b:00004ee4
BIU -- -
BIU -- -
BIU -- I
BIU T1 - Paged(p):0003c2d6=00( ); Normal(p):00004f26=00( ); Paged(p):0003c2d7=7f(⌂); Normal(p):00004f27=7f(⌂); Paged(p):0003c2d8=03(♥); Normal(p):00004f28=03(♥); Paged(p):0003c2d9=e9(Θ); Normal(p):00004f29=e9(Θ)
BIU -- -
BIU -- S
BIU -- -
BIU -- - 373b:00004ee9
BIU T1 - 373b:00004ee9 Paged(r):0004dfe8=00( ); Paged(r):0004dfe9=00( )
BIU -- - 373b:00004ee9 26 A1 38 01 mov ax,word es:[0138]
Registers:
EIP: 00004ee9 EFLAGS: 00007246
Previous CS:EIP: 373b:00004ee5
BIU -- -
BIU -- I
BIU T1 - Paged(p):0003c2da=a6(ª); Normal(p):00004f2a=a6(ª); Paged(p):0003c2db=00( ); Normal(p):00004f2b=00( ); Paged(p):0003c2dc=8c(î); Normal(p):00004f2c=8c(î); Paged(p):0003c2dd=c0(└); Normal(p):00004f2d=c0(└)
BIU -- S
BIU -- - 373b:00004eed 3D 00 00 cmp ax,0000
Registers:
EIP: 00004eed EFLAGS: 00007246
Previous CS:EIP: 373b:00004ee9
BIU -- -
BIU -- I
BIU -- -
BIU -- S
BIU T1 - 373b:00004ef0 77 1A jnbe 00004f0c Paged(p):0003c2de=3b(;); Normal(p):00004f2e=3b(;); Paged(p):0003c2df=46(F); Normal(p):00004f2f=46(F); MemoryBus(p):000000000003c2e0=3b04750c(;♦u♀); Paged(p):0003c2e0=0c(♀); Normal(p):00004f30=0c(♀); Paged(p):0003c2e1=75(u); Normal(p):00004f31=75(u)
Registers:
EIP: 00004ef0 EFLAGS: 00007246
Previous CS:EIP: 373b:00004eed
BIU -- -
BIU -- -
BIU -- I
BIU -- -
BIU -- S
BIU -- - 373b:00004ef2 B8 00 00 mov ax,0000
Registers:
EIP: 00004ef2 EFLAGS: 00007246
Previous CS:EIP: 373b:00004ef0
BIU -- -
BIU -- I
BIU T1 - Paged(p):0003c2e2=04(♦); Normal(p):00004f32=04(♦); Paged(p):0003c2e3=3b(;); Normal(p):00004f33=3b(;); Paged(p):0003c2e4=fe(■); Normal(p):00004f34=fe(■); Paged(p):0003c2e5=7f(⌂); Normal(p):00004f35=7f(⌂)
BIU -- S
BIU -- -
BIU -- - 373b:00004ef5
BIU T1 - 373b:00004ef5 RealRAM(r):000000000005ad0e=4deb(Mδ); RAM(r):000000000005ad0e=4deb(Mδ); MemoryBus(r):000000000005ad0e=4deb(Mδ); Paged(r):0005ad0e=eb(δ); Paged(r):0005ad0f=4d(M)
BIU -- - 373b:00004ef5 8E 06 5E CE mov es,word ds:[ce5e]
Registers:
EIP: 00004ef5 EFLAGS: 00007246
Previous CS:EIP: 373b:00004ef2
BIU -- -
BIU -- -
BIU -- I
BIU T1 - Paged(p):0003c2e6=03(♥); Normal(p):00004f36=03(♥); Paged(p):0003c2e7=fc(ⁿ); Normal(p):00004f37=fc(ⁿ); Paged(p):0003c2e8=eb(δ); Normal(p):00004f38=eb(δ); Paged(p):0003c2e9=0a( ); Normal(p):00004f39=0a( )
BIU -- -
BIU -- S
BIU T1 - Paged(p):0003c2ea=fd(²); Normal(p):00004f3a=fd(²); Paged(p):0003c2eb=8b(ï); Normal(p):00004f3b=8b(ï); Paged(p):0003c2ec=d9(┘); Normal(p):00004f3c=d9(┘); Paged(p):0003c2ed=4b(K); Normal(p):00004f3d=4b(K)
BIU -- -
BIU -- -
BIU -- - 373b:00004ef9
BIU T1 - 373b:00004ef9 MemoryBus(w):000000000004dfe6=01(☺); RAM(w):000000000004dfe6=0001( ☺); RealRAM(w):000000000004dfe6=0001( ☺); Paged(w):0004dfe6=0001( ☺)
Registers:
EIP: 00004ef9 EFLAGS: 00007246
Previous CS:EIP: 373b:00004ef5
BIU -- I ^ 26 C7 06 36 01 01 00 mov word es:[0136],0001
BIU -- -
BIU -- S
BIU T1 - Paged(p):0003c2ee=d1(╤); Normal(p):00004f3e=d1(╤); Paged(p):0003c2ef=e3(π); Normal(p):00004f3f=e3(π); MemoryBus(p):000000000003c2f0=f303fb03(≤♥√♥); Paged(p):0003c2f0=03(♥); Normal(p):00004f40=03(♥); Paged(p):0003c2f1=fb(√); Normal(p):00004f41=fb(√)
BIU -- - 373b:00004f00
BIU T1 - 373b:00004f00 Paged(r):0005ad10=eb(δ); Paged(r):0005ad11=4d(M)
BIU -- - 373b:00004f00 8E 06 60 CE mov es,word ds:[ce60]
Registers:
EIP: 00004f00 EFLAGS: 00007246
Previous CS:EIP: 373b:00004ef9
BIU -- -
BIU -- -
BIU -- I
BIU -- -
BIU -- -
BIU -- S
BIU T1 - Paged(p):0003c2f2=03(♥); Normal(p):00004f42=03(♥); Paged(p):0003c2f3=f3(≤); Normal(p):00004f43=f3(≤); Paged(p):0003c2f4=80(Ç); Normal(p):00004f44=80(Ç); Paged(p):0003c2f5=fe(■); Normal(p):00004f45=fe(■)
BIU -- -
BIU -- - 373b:00004f04
BIU T1 - 373b:00004f04 MemoryBus(w):000000000004dfe8=eb(δ); RAM(w):000000000004dfe8=4deb(Mδ); RealRAM(w):000000000004dfe8=4deb(Mδ); Paged(w):0004dfe8=4deb(Mδ)
Registers:
EIP: 00004f04 EFLAGS: 00007246
Previous CS:EIP: 373b:00004f00
BIU -- I ^ 26 8C 1E 38 01 mov word es:[0138],ds
BIU T1 - Paged(p):0003c2f6=00( ); Normal(p):00004f46=00( ); Paged(p):0003c2f7=8b(ï); Normal(p):00004f47=8b(ï); Paged(p):0003c2f8=5e(^); Normal(p):00004f48=5e(^); Paged(p):0003c2f9=06(♠); Normal(p):00004f49=06(♠)
BIU -- S
BIU -- E 373b:00004f09 E9 C6 00 jmp 00004fd2
Registers:
EIP: 00004f09 EFLAGS: 00007246
Previous CS:EIP: 373b:00004f04
BIU T1 - RealRAM(p):000000000003c382=071f(•▼); RAM(p):000000000003c382=071f(•▼); MemoryBus(p):000000000003c382=071f(•▼); Paged(p):0003c382=1f(▼); Normal(p):00004fd2=1f(▼); Paged(p):0003c383=07(•); Normal(p):00004fd3=07(•); RealRAM(p):000000000003c384=8b5f5efc(ï_^ⁿ); RAM(p):000000000003c384=8b5f5efc(ï_^ⁿ); MemoryBus(p):000000000003c384=8b5f5efc(ï_^ⁿ); Paged(p):0003c384=fc(ⁿ); Normal(p):00004fd4=fc(ⁿ); Paged(p):0003c385=5e(^); Normal(p):00004fd5=5e(^)
BIU T1 - Paged(p):0003c386=5f(_); Normal(p):00004fd6=5f(_); Paged(p):0003c387=8b(ï); Normal(p):00004fd7=8b(ï); RealRAM(p):000000000003c388=00000000bacb5de5(☺┤♥┌║╦]σ); RAM(p):000000000003c388=00000000bacb5de5(☺┤♥┌║╦]σ); MemoryBus(p):000000000003c388=bacb5de5(║╦]σ); Paged(p):0003c388=e5(σ); Normal(p):00004fd8=e5(σ); Paged(p):0003c389=5d(]); Normal(p):00004fd9=5d(])
BIU T1 - Paged(p):0003c38a=cb(╦); Normal(p):00004fda=cb(╦); Paged(p):0003c38b=ba(║); Normal(p):00004fdb=ba(║); Paged(p):0003c38c=da(┌); Normal(p):00004fdc=da(┌); Paged(p):0003c38d=03(♥); Normal(p):00004fdd=03(♥)
BIU T1 - Paged(p):0003c38e=b4(┤); Normal(p):00004fde=b4(┤); Paged(p):0003c38f=01(☺); Normal(p):00004fdf=01(☺); MemoryBus(p):000000000003c390=75c484ec(u─ä∞); Paged(p):0003c390=ec(∞); Normal(p):00004fe0=ec(∞); Paged(p):0003c391=84(ä); Normal(p):00004fe1=84(ä)
BIU T1 - Paged(p):0003c392=c4(─); Normal(p):00004fe2=c4(─); Paged(p):0003c393=75(u); Normal(p):00004fe3=75(u); Paged(p):0003c394=fb(√); Normal(p):00004fe4=fb(√); Paged(p):0003c395=fa(·); Normal(p):00004fe5=fa(·)
BIU T1 - Paged(p):0003c396=ec(∞); Normal(p):00004fe6=ec(∞); Paged(p):0003c397=84(ä); Normal(p):00004fe7=84(ä); Paged(p):0003c398=c4(─); Normal(p):00004fe8=c4(─); Paged(p):0003c399=74(t); Normal(p):00004fe9=74(t)
BIU T1 I Paged(p):0003c39a=fb(√); Normal(p):00004fea=fb(√); Paged(p):0003c39b=ad(¡); Normal(p):00004feb=ad(¡); Paged(p):0003c39c=fb(√); Normal(p):00004fec=fb(√); Paged(p):0003c39d=c3(├); Normal(p):00004fed=c3(├)
BIU T1 - 373b:00004fd2 Paged(p):0003c39e=8b(ï); Normal(p):00004fee=8b(ï); Paged(p):0003c39f=d8(╪); Normal(p):00004fef=d8(╪); MemoryBus(p):000000000003c3a0=b403daba(┤♥┌║); Paged(p):0003c3a0=ba(║); Normal(p):00004ff0=ba(║); Paged(p):0003c3a1=da(┌); Normal(p):00004ff1=da(┌)
BIU T1 - 373b:00004fd2 Paged(p):0003c3a2=03(♥); Normal(p):00004ff2=03(♥); Paged(p):0003c3a3=b4(┤); Normal(p):00004ff3=b4(┤); Paged(p):0003c3a4=01(☺); Normal(p):00004ff4=01(☺); Paged(p):0003c3a5=ec(∞); Normal(p):00004ff5=ec(∞)
BIU T1 - 373b:00004fd2 Paged(p):0003c3a6=84(ä); Normal(p):00004ff6=84(ä); Paged(p):0003c3a7=c4(─); Normal(p):00004ff7=c4(─); Paged(p):0003c3a8=75(u); Normal(p):00004ff8=75(u); Paged(p):0003c3a9=fb(√); Normal(p):00004ff9=fb(√)
BIU T1 - 373b:00004fd2 RealRAM(r):000000000005d706=4deb(Mδ); RAM(r):000000000005d706=4deb(Mδ); MemoryBus(r):000000000005d706=4deb(Mδ); Paged(r):0005d706=eb(δ); Paged(r):0005d707=4d(M)
BIU -- - 373b:00004fd2 1F pop ds
Registers:
EIP: 00004fd2 EFLAGS: 00007246
Previous CS:EIP: 373b:00004f09
BIU T1 - Paged(p):0003c3aa=fa(·); Normal(p):00004ffa=fa(·); Paged(p):0003c3ab=ec(∞); Normal(p):00004ffb=ec(∞); Paged(p):0003c3ac=84(ä); Normal(p):00004ffc=84(ä); Paged(p):0003c3ad=c4(─); Normal(p):00004ffd=c4(─)
BIU T1 - Paged(p):0003c3ae=74(t); Normal(p):00004ffe=74(t); Paged(p):0003c3af=fb(√); Normal(p):00004fff=fb(√); MemoryBus(p):000000000003c3b0=fbabc38b(√½├ï); Paged(p):0003c3b0=8b(ï); Normal(p):00005000=8b(ï); Paged(p):0003c3b1=c3(├); Normal(p):00005001=c3(├)
BIU T1 - Paged(p):0003c3b2=ab(½); Normal(p):00005002=ab(½); Paged(p):0003c3b3=fb(√); Normal(p):00005003=fb(√); Paged(p):0003c3b4=c3(├); Normal(p):00005004=c3(├); Paged(p):0003c3b5=00( ); Normal(p):00005005=00( )
BIU T1 - Paged(p):0003c3b6=55(U); Normal(p):00005006=55(U); Paged(p):0003c3b7=8b(ï); Normal(p):00005007=8b(ï); Paged(p):0003c3b8=ec(∞); Normal(p):00005008=ec(∞); Paged(p):0003c3b9=b8(╕); Normal(p):00005009=b8(╕)
BIU T1 I Paged(p):0003c3ba=34(4); Normal(p):0000500a=34(4); Paged(p):0003c3bb=00( ); Normal(p):0000500b=00( ); Paged(p):0003c3bc=9a(Ü); Normal(p):0000500c=9a(Ü); Paged(p):0003c3bd=be(╛); Normal(p):0000500d=be(╛)
BIU T1 - 373b:00004fd3 Paged(p):0003c3be=1e(▲); Normal(p):0000500e=1e(▲); Paged(p):0003c3bf=57(W); Normal(p):0000500f=57(W); MemoryBus(p):000000000003c3c0=cc46c73c(╠F╟<); Paged(p):0003c3c0=3c(<); Normal(p):00005010=3c(<); Paged(p):0003c3c1=c7(╟); Normal(p):00005011=c7(╟)
BIU -- - 373b:00004fd3
BIU T1 - 373b:00004fd3 RealRAM(r):000000000005d708=0000000000824deb(°z∙M éMδ); RAM(r):000000000005d708=0000000000824deb(°z∙M éMδ); MemoryBus(r):000000000005d708=00824deb( éMδ); Paged(r):0005d708=eb(δ); Paged(r):0005d709=4d(M)
BIU -- - 373b:00004fd3 07 pop es
Registers:
EIP: 00004fd3 EFLAGS: 00007246
Previous CS:EIP: 373b:00004fd2
BIU -- -
BIU -- -
BIU -- -
BIU -- -
BIU -- I
BIU -- - 373b:00004fd4 FC cld
Registers:
EIP: 00004fd4 EFLAGS: 00007246
Previous CS:EIP: 373b:00004fd3
BIU -- -
BIU -- I
BIU T1 - 373b:00004fd5 Paged(p):0003c3c2=46(F); Normal(p):00005012=46(F); Paged(p):0003c3c3=cc(╠); Normal(p):00005013=cc(╠); Paged(p):0003c3c4=00( ); Normal(p):00005014=00( ); Paged(p):0003c3c5=00( ); Normal(p):00005015=00( )
BIU -- - 373b:00004fd5
BIU T1 - 373b:00004fd5 Paged(r):0005d70a=82(é); Paged(r):0005d70b=00( )
BIU -- - 373b:00004fd5 5E pop si
Registers:
EIP: 00004fd5 EFLAGS: 00007246
Previous CS:EIP: 373b:00004fd4
BIU -- -
BIU -- I
BIU -- - 373b:00004fd6
BIU T1 - 373b:00004fd6 Paged(r):0005d70c=4d(M); Paged(r):0005d70d=f9(∙)
BIU -- - 373b:00004fd6 5F pop di
Registers:
EIP: 00004fd6 EFLAGS: 00007246
Previous CS:EIP: 373b:00004fd5
BIU -- -
BIU -- I
BIU -- -
BIU -- S
BIU -- - 373b:00004fd7 8B E5 mov sp,bp
Registers:
EIP: 00004fd7 EFLAGS: 00007246
Previous CS:EIP: 373b:00004fd6
BIU -- -
BIU -- I
BIU T1 - 373b:00004fd9 Paged(p):0003c3c6=b8(╕); Normal(p):00005016=b8(╕); Paged(p):0003c3c7=64(d); Normal(p):00005017=64(d); Paged(p):0003c3c8=ce(╬); Normal(p):00005018=ce(╬); Paged(p):0003c3c9=89(ë); Normal(p):00005019=89(ë)
BIU -- - 373b:00004fd9
BIU T1 - 373b:00004fd9 Paged(r):0005d70e=7a(z); Paged(r):0005d70f=f8(°)
BIU -- - 373b:00004fd9 5D pop bp
Registers:
EIP: 00004fd9 EFLAGS: 00007246
Previous CS:EIP: 373b:00004fd7
BIU -- -
BIU -- I
BIU -- - 373b:00004fda
BIU T1 - 373b:00004fda MemoryBus(r):000000000005d710=373b2e1e(7;.▲); Paged(r):0005d710=1e(▲); Paged(r):0005d711=2e(.)
BIU T1 - 373b:00004fda Paged(r):0005d712=3b(;); Paged(r):0005d713=37(7)
BIU -- E 373b:00004fda CB retf
Registers:
EIP: 00004fda EFLAGS: 00007246
Previous CS:EIP: 373b:00004fd9
BIU T1 - RealRAM(p):000000000003a1ce=c483(─â); RAM(p):000000000003a1ce=c483(─â); MemoryBus(p):000000000003a1ce=c483(─â); Paged(p):0003a1ce=83(â); Normal(p):00002e1e=83(â); Paged(p):0003a1cf=c4(─); Normal(p):00002e1f=c4(─); MemoryBus(p):000000000003a1d0=517e9a0c(Q~Ü♀); Paged(p):0003a1d0=0c(♀); Normal(p):00002e20=0c(♀); Paged(p):0003a1d1=9a(Ü); Normal(p):00002e21=9a(Ü)
BIU T1 - Paged(p):0003a1d2=7e(~); Normal(p):00002e22=7e(~); Paged(p):0003a1d3=51(Q); Normal(p):00002e23=51(Q); Paged(p):0003a1d4=3b(;); Normal(p):00002e24=3b(;); Paged(p):0003a1d5=37(7); Normal(p):00002e25=37(7)
BIU T1 - Paged(p):0003a1d6=8e(Ä); Normal(p):00002e26=8e(Ä); Paged(p):0003a1d7=06(♠); Normal(p):00002e27=06(♠); Paged(p):0003a1d8=70(p); Normal(p):00002e28=70(p); Paged(p):0003a1d9=cb(╦); Normal(p):00002e29=cb(╦)
BIU T1 - Paged(p):0003a1da=26(&); Normal(p):00002e2a=26(&); Paged(p):0003a1db=a2(ó); Normal(p):00002e2b=a2(ó); Paged(p):0003a1dc=20( ); Normal(p):00002e2c=20( ); Paged(p):0003a1dd=01(☺); Normal(p):00002e2d=01(☺)
BIU T1 - Paged(p):0003a1de=9a(Ü); Normal(p):00002e2e=9a(Ü); Paged(p):0003a1df=06(♠); Normal(p):00002e2f=06(♠); MemoryBus(p):000000000003a1e0=8e373b50(Ä7;P); Paged(p):0003a1e0=50(P); Normal(p):00002e30=50(P); Paged(p):0003a1e1=3b(;); Normal(p):00002e31=3b(;)
BIU T1 - Paged(p):0003a1e2=37(7); Normal(p):00002e32=37(7); Paged(p):0003a1e3=8e(Ä); Normal(p):00002e33=8e(Ä); Paged(p):0003a1e4=06(♠); Normal(p):00002e34=06(♠); Paged(p):0003a1e5=72(r); Normal(p):00002e35=72(r)
BIU T1 - Paged(p):0003a1e6=cb(╦); Normal(p):00002e36=cb(╦); Paged(p):0003a1e7=26(&); Normal(p):00002e37=26(&); Paged(p):0003a1e8=a3(ú); Normal(p):00002e38=a3(ú); Paged(p):0003a1e9=2c(,); Normal(p):00002e39=2c(,)
BIU T1 - Paged(p):0003a1ea=01(☺); Normal(p):00002e3a=01(☺); Paged(p):0003a1eb=8e(Ä); Normal(p):00002e3b=8e(Ä); Paged(p):0003a1ec=06(♠); Normal(p):00002e3c=06(♠); Paged(p):0003a1ed=70(p); Normal(p):00002e3d=70(p)
BIU T1 - Paged(p):0003a1ee=cb(╦); Normal(p):00002e3e=cb(╦); Paged(p):0003a1ef=26(&); Normal(p):00002e3f=26(&); MemoryBus(p):000000000003a1f0=01203e80(☺ >Ç); Paged(p):0003a1f0=80(Ç); Normal(p):00002e40=80(Ç); Paged(p):0003a1f1=3e(>); Normal(p):00002e41=3e(>)
BIU T1 - Paged(p):0003a1f2=20( ); Normal(p):00002e42=20( ); Paged(p):0003a1f3=01(☺); Normal(p):00002e43=01(☺); Paged(p):0003a1f4=00( ); Normal(p):00002e44=00( ); Paged(p):0003a1f5=74(t); Normal(p):00002e45=74(t)
BIU T1 - Paged(p):0003a1f6=10(►); Normal(p):00002e46=10(►); Paged(p):0003a1f7=26(&); Normal(p):00002e47=26(&); Paged(p):0003a1f8=80(Ç); Normal(p):00002e48=80(Ç); Paged(p):0003a1f9=3e(>); Normal(p):00002e49=3e(>)
BIU T1 - Paged(p):0003a1fa=20( ); Normal(p):00002e4a=20( ); Paged(p):0003a1fb=01(☺); Normal(p):00002e4b=01(☺); Paged(p):0003a1fc=02(☻); Normal(p):00002e4c=02(☻); Paged(p):0003a1fd=74(t); Normal(p):00002e4d=74(t)
BIU T1 I Paged(p):0003a202=20( ); Normal(p):00002e52=20( ); Paged(p):0003a203=01(☺); Normal(p):00002e53=01(☺); Paged(p):0003a204=07(•); Normal(p):00002e54=07(•); Paged(p):0003a205=75(u); Normal(p):00002e55=75(u)
BIU -- -
BIU -- - 373b:00002e1e 83 C4 0C add sp,000c
Registers:
EIP: 00002e1e EFLAGS: 00007246
Previous CS:EIP: 373b:00004fda
BIU -- -
BIU -- -
BIU -- I
BIU T1 - Paged(p):0003a20e=c7(╟); Normal(p):00002e5e=c7(╟); Paged(p):0003a20f=46(F); Normal(p):00002e5f=46(F); MemoryBus(p):000000000003a210=8e0001f6(Ä ☺÷); Paged(p):0003a210=f6(÷); Normal(p):00002e60=f6(÷); Paged(p):0003a211=01(☺); Normal(p):00002e61=01(☺)
BIU T1 S Paged(p):0003a212=00( ); Normal(p):00002e62=00( ); Paged(p):0003a213=8e(Ä); Normal(p):00002e63=8e(Ä); Paged(p):0003a214=06(♠); Normal(p):00002e64=06(♠); Paged(p):0003a215=74(t); Normal(p):00002e65=74(t)
BIU -- - 373b:00002e21
BIU T1 - 373b:00002e21 MemoryBus(w):000000000005d71e=3b(;); RAM(w):000000000005d71e=373b(7;); RealRAM(w):000000000005d71e=373b(7;); Paged(w):0005d71e=373b(7;)
BIU T1 - 373b:00002e21 MemoryBus(w):000000000005d71c=26(&); RAM(w):000000000005d71c=2e26(.&); RealRAM(w):000000000005d71c=2e26(.&); Paged(w):0005d71c=2e26(.&)
BIU -- E 373b:00002e21 9A 7E 51 3B 37 call 373b:0000517e
Registers:
EIP: 00002e21 EFLAGS: 00007292
Previous CS:EIP: 373b:00002e1e
FLAGSINFO: 0000000000ipfavr0N11odItSz0A0p1c
BIU T1 - RealRAM(p):000000000003c52e=8b55(ïU); RAM(p):000000000003c52e=8b55(ïU); MemoryBus(p):000000000003c52e=8b55(ïU); Paged(p):0003c52e=55(U); Normal(p):0000517e=55(U); Paged(p):0003c52f=8b(ï); Normal(p):0000517f=8b(ï); MemoryBus(p):000000000003c530=0026b8ec( &╕∞); Paged(p):0003c530=ec(∞); Normal(p):00005180=ec(∞); Paged(p):0003c531=b8(╕); Normal(p):00005181=b8(╕)
BIU T1 - Paged(p):0003c532=26(&); Normal(p):00005182=26(&); Paged(p):0003c533=00( ); Normal(p):00005183=00( ); Paged(p):0003c534=9a(Ü); Normal(p):00005184=9a(Ü); Paged(p):0003c535=be(╛); Normal(p):00005185=be(╛)
BIU T1 - Paged(p):0003c536=1e(▲); Normal(p):00005186=1e(▲); Paged(p):0003c537=57(W); Normal(p):00005187=57(W); Paged(p):0003c538=3c(<); Normal(p):00005188=3c(<); Paged(p):0003c539=b8(╕); Normal(p):00005189=b8(╕)
BIU T1 - Paged(p):0003c53a=7e(~); Normal(p):0000518a=7e(~); Paged(p):0003c53b=ce(╬); Normal(p):0000518b=ce(╬); Paged(p):0003c53c=89(ë); Normal(p):0000518c=89(ë); Paged(p):0003c53d=46(F); Normal(p):0000518d=46(F)
BIU T1 - Paged(p):0003c53e=ec(∞); Normal(p):0000518e=ec(∞); Paged(p):0003c53f=8c(î); Normal(p):0000518f=8c(î); MemoryBus(p):000000000003c540=501eee5e(P▲ε^); Paged(p):0003c540=5e(^); Normal(p):00005190=5e(^); Paged(p):0003c541=ee(ε); Normal(p):00005191=ee(ε)
BIU T1 - Paged(p):0003c542=1e(▲); Normal(p):00005192=1e(▲); Paged(p):0003c543=50(P); Normal(p):00005193=50(P); Paged(p):0003c544=9a(Ü); Normal(p):00005194=9a(Ü); Paged(p):0003c545=9c(£); Normal(p):00005195=9c(£)
BIU T1 - Paged(p):0003c546=12(↕); Normal(p):00005196=12(↕); Paged(p):0003c547=3b(;); Normal(p):00005197=3b(;); Paged(p):0003c548=37(7); Normal(p):00005198=37(7); Paged(p):0003c549=83(â); Normal(p):00005199=83(â)
BIU T1 - Paged(p):0003c54a=c4(─); Normal(p):0000519a=c4(─); Paged(p):0003c54b=04(♦); Normal(p):0000519b=04(♦); Paged(p):0003c54c=c7(╟); Normal(p):0000519c=c7(╟); Paged(p):0003c54d=46(F); Normal(p):0000519d=46(F)
BIU T1 - Paged(p):0003c54e=f0(≡); Normal(p):0000519e=f0(≡); Paged(p):0003c54f=00( ); Normal(p):0000519f=00( ); MemoryBus(p):000000000003c550=dc468d0f(▄Fì☼); Paged(p):0003c550=0f(☼); Normal(p):000051a0=0f(☼); Paged(p):0003c551=8d(ì); Normal(p):000051a1=8d(ì)
BIU T1 - Paged(p):0003c552=46(F); Normal(p):000051a2=46(F); Paged(p):0003c553=dc(▄); Normal(p):000051a3=dc(▄); Paged(p):0003c554=16(▬); Normal(p):000051a4=16(▬); Paged(p):0003c555=50(P); Normal(p):000051a5=50(P)
BIU T1 - Paged(p):0003c556=8d(ì); Normal(p):000051a6=8d(ì); Paged(p):0003c557=46(F); Normal(p):000051a7=46(F); Paged(p):0003c558=f0(≡); Normal(p):000051a8=f0(≡); Paged(p):0003c559=16(▬); Normal(p):000051a9=16(▬)
BIU T1 - Paged(p):0003c55a=50(P); Normal(p):000051aa=50(P); Paged(p):0003c55b=9a(Ü); Normal(p):000051ab=9a(Ü); Paged(p):0003c55c=d6(╓); Normal(p):000051ac=d6(╓); Paged(p):0003c55d=44(D); Normal(p):000051ad=44(D)
BIU T1 - Paged(p):0003c55e=3b(;); Normal(p):000051ae=3b(;); Paged(p):0003c55f=37(7); Normal(p):000051af=37(7); MemoryBus(p):000000000003c560=8a08c483(è◘─â); Paged(p):0003c560=83(â); Normal(p):000051b0=83(â); Paged(p):0003c561=c4(─); Normal(p):000051b1=c4(─)
BIU T1 - Paged(p):0003c562=08(◘); Normal(p):000051b2=08(◘); Paged(p):0003c563=8a(è); Normal(p):000051b3=8a(è); Paged(p):0003c564=46(F); Normal(p):000051b4=46(F); Paged(p):0003c565=dc(▄); Normal(p):000051b5=dc(▄)
BIU T1 - Paged(p):0003c566=2a(*); Normal(p):000051b6=2a(*); Paged(p):0003c567=e4(Σ); Normal(p):000051b7=e4(Σ); Paged(p):0003c568=89(ë); Normal(p):000051b8=89(ë); Paged(p):0003c569=46(F); Normal(p):000051b9=46(F)
BIU T1 - Paged(p):0003c56a=da(┌); Normal(p):000051ba=da(┌); Paged(p):0003c56b=ff( ); Normal(p):000051bb=ff( ); Paged(p):0003c56c=76(v); Normal(p):000051bc=76(v); Paged(p):0003c56d=ee(ε); Normal(p):000051bd=ee(ε)
BIU -- I
BIU -- - 373b:0000517e
BIU T1 - 373b:0000517e MemoryBus(w):000000000005d71a=7a(z); RAM(w):000000000005d71a=f87a(°z); RealRAM(w):000000000005d71a=f87a(°z); Paged(w):0005d71a=f87a(°z)
BIU -- - 373b:0000517e 55 push bp
Registers:
EIP: 0000517e EFLAGS: 00007292
Previous CS:EIP: 373b:00002e21
BIU -- -
BIU -- I
BIU -- -
BIU -- S
BIU -- - 373b:0000517f 8B EC mov bp,sp
Registers:
EIP: 0000517f EFLAGS: 00007292
Previous CS:EIP: 373b:0000517e
BIU -- -
BIU -- I
BIU T1 - Paged(p):0003c56e=ff( ); Normal(p):000051be=ff( ); Paged(p):0003c56f=76(v); Normal(p):000051bf=76(v); MemoryBus(p):000000000003c570=12c69aec(↕╞Ü∞); Paged(p):0003c570=ec(∞); Normal(p):000051c0=ec(∞); Paged(p):0003c571=9a(Ü); Normal(p):000051c1=9a(Ü)
BIU -- S
BIU -- - 373b:00005181 B8 26 00 mov ax,0026
Registers:
ESP: 0000f86a EBP: 0000f86a ESI: 00000082 EDI: 00fff94d
EIP: 00005181 EFLAGS: 00007292
Previous CS:EIP: 373b:0000517f
BIU -- -
BIU -- I
BIU -- -
BIU -- S
BIU T1 - 373b:00005184 Paged(p):0003c572=c6(╞); Normal(p):000051c2=c6(╞); Paged(p):0003c573=12(↕); Normal(p):000051c3=12(↕); Paged(p):0003c574=3b(;); Normal(p):000051c4=3b(;); Paged(p):0003c575=37(7); Normal(p):000051c5=37(7)
BIU T1 - 373b:00005184 MemoryBus(w):000000000005d718=3b(;); RAM(w):000000000005d718=373b(7;); RealRAM(w):000000000005d718=373b(7;); Paged(w):0005d718=373b(7;)
BIU T1 - 373b:00005184 MemoryBus(w):000000000005d716=89(ë); RAM(w):000000000005d716=5189(Që); RealRAM(w):000000000005d716=5189(Që); Paged(w):0005d716=5189(Që)
BIU -- - 373b:00005184
BIU -- E 373b:00005184 9A BE 1E 57 3C call 3c57:00001ebe
Registers:
EAX: 80000026 EBX: 0000f866 ECX: 000012a6 EDX: 0000373b
EIP: 00005184 EFLAGS: 00007292
Previous CS:EIP: 373b:00005181
BIU T1 - RealRAM(p):000000000003e42e=5a59(ZY); RAM(p):000000000003e42e=5a59(ZY); MemoryBus(p):000000000003e42e=5a59(ZY); Paged(p):0003e42e=59(Y); Normal(p):00001ebe=59(Y); Paged(p):0003e42f=5a(Z); Normal(p):00001ebf=5a(Z); MemoryBus(p):000000000003e430=d82bdc8b(╪+▄ï); Paged(p):0003e430=8b(ï); Normal(p):00001ec0=8b(ï); Paged(p):0003e431=dc(▄); Normal(p):00001ec1=dc(▄)
BIU T1 - Paged(p):0003e432=2b(+); Normal(p):00001ec2=2b(+); Paged(p):0003e433=d8(╪); Normal(p):00001ec3=d8(╪); Paged(p):0003e434=72(r); Normal(p):00001ec4=72(r); Paged(p):0003e435=0b(♂); Normal(p):00001ec5=0b(♂)
BIU T1 - Paged(p):0003e436=3b(;); Normal(p):00001ec6=3b(;); Paged(p):0003e437=1e(▲); Normal(p):00001ec7=1e(▲); Paged(p):0003e438=58(X); Normal(p):00001ec8=58(X); Paged(p):0003e439=ae(«); Normal(p):00001ec9=ae(«)
BIU T1 - Paged(p):0003e43a=72(r); Normal(p):00001eca=72(r); Paged(p):0003e43b=05(♣); Normal(p):00001ecb=05(♣); Paged(p):0003e43c=8b(ï); Normal(p):00001ecc=8b(ï); Paged(p):0003e43d=e3(π); Normal(p):00001ecd=e3(π)
BIU T1 - Paged(p):0003e43e=52(R); Normal(p):00001ece=52(R); Paged(p):0003e43f=51(Q); Normal(p):00001ecf=51(Q); MemoryBus(p):000000000003e440=ae54a1cb(«Tí╦); Paged(p):0003e440=cb(╦); Normal(p):00001ed0=cb(╦); Paged(p):0003e441=a1(í); Normal(p):00001ed1=a1(í)
BIU T1 - Paged(p):0003e442=54(T); Normal(p):00001ed2=54(T); Paged(p):0003e443=ae(«); Normal(p):00001ed3=ae(«); Paged(p):0003e444=40(@); Normal(p):00001ed4=40(@); Paged(p):0003e445=75(u); Normal(p):00001ed5=75(u)
BIU T1 - Paged(p):0003e446=05(♣); Normal(p):00001ed6=05(♣); Paged(p):0003e447=33(3); Normal(p):00001ed7=33(3); Paged(p):0003e448=c0(└); Normal(p):00001ed8=c0(└); Paged(p):0003e449=e9(Θ); Normal(p):00001ed9=e9(Θ)
BIU T1 - Paged(p):0003e44a=ff( ); Normal(p):00001eda=ff( ); Paged(p):0003e44b=e1(ß); Normal(p):00001edb=e1(ß); Paged(p):0003e44c=52(R); Normal(p):00001edc=52(R); Paged(p):0003e44d=51(Q); Normal(p):00001edd=51(Q)
BIU T1 - Paged(p):0003e44e=ff( ); Normal(p):00001ede=ff( ); Paged(p):0003e44f=2e(.); Normal(p):00001edf=2e(.); MemoryBus(p):000000000003e450=8b55ae54(ïU«T); Paged(p):0003e450=54(T); Normal(p):00001ee0=54(T); Paged(p):0003e451=ae(«); Normal(p):00001ee1=ae(«)
BIU T1 - Paged(p):0003e452=55(U); Normal(p):00001ee2=55(U); Paged(p):0003e453=8b(ï); Normal(p):00001ee3=8b(ï); Paged(p):0003e454=ec(∞); Normal(p):00001ee4=ec(∞); Paged(p):0003e455=83(â); Normal(p):00001ee5=83(â)
BIU T1 - Paged(p):0003e456=ec(∞); Normal(p):00001ee6=ec(∞); Paged(p):0003e457=0a( ); Normal(p):00001ee7=0a( ); Paged(p):0003e458=57(W); Normal(p):00001ee8=57(W); Paged(p):0003e459=56(V); Normal(p):00001ee9=56(V)
BIU T1 - Paged(p):0003e45a=b8(╕); Normal(p):00001eea=b8(╕); Paged(p):0003e45b=8c(î); Normal(p):00001eeb=8c(î); Paged(p):0003e45c=ab(½); Normal(p):00001eec=ab(½); Paged(p):0003e45d=89(ë); Normal(p):00001eed=89(ë)
BIU T1 - Paged(p):0003e45e=46(F); Normal(p):00001eee=46(F); Paged(p):0003e45f=f6(÷); Normal(p):00001eef=f6(÷); MemoryBus(p):000000000003e460=fff85e8c( °^î); Paged(p):0003e460=8c(î); Normal(p):00001ef0=8c(î); Paged(p):0003e461=5e(^); Normal(p):00001ef1=5e(^)
BIU T1 - Paged(p):0003e462=f8(°); Normal(p):00001ef2=f8(°); Paged(p):0003e463=ff( ); Normal(p):00001ef3=ff( ); Paged(p):0003e464=76(v); Normal(p):00001ef4=76(v); Paged(p):0003e465=08(◘); Normal(p):00001ef5=08(◘)
BIU T1 - Paged(p):0003e466=ff( ); Normal(p):00001ef6=ff( ); Paged(p):0003e467=76(v); Normal(p):00001ef7=76(v); Paged(p):0003e468=06(♠); Normal(p):00001ef8=06(♠); Paged(p):0003e469=9a(Ü); Normal(p):00001ef9=9a(Ü)
BIU T1 - Paged(p):0003e46a=1c(∟); Normal(p):00001efa=1c(∟); Paged(p):0003e46b=05(♣); Normal(p):00001efb=05(♣); Paged(p):0003e46c=57(W); Normal(p):00001efc=57(W); Paged(p):0003e46d=3c(<); Normal(p):00001efd=3c(<)
BIU -- I
BIU -- - 3c57:00001ebe
BIU T1 - 3c57:00001ebe RealRAM(r):000000000005d716=5189(Që); RAM(r):000000000005d716=5189(Që); MemoryBus(r):000000000005d716=5189(Që); Paged(r):0005d716=89(ë); Paged(r):0005d717=51(Q)
BIU -- - 3c57:00001ebe 59 pop cx
Registers:
ESP: 0000f866 EBP: 0000f86a ESI: 00000082 EDI: 00fff94d
CS: 3c57 DS: 4deb ES: 4deb FS: 0000 GS: 0000 SS: 4deb TR: 0000 LDTR: 0000
EIP: 00001ebe EFLAGS: 00007292
CS descriptor: 00009303C570FFFF
Previous CS:EIP: 373b:00005184
BIU -- -
BIU -- I
BIU -- - 3c57:00001ebf
BIU T1 - 3c57:00001ebf RealRAM(r):000000000005d718=00000000f87a373b(7;.&°z7;); RAM(r):000000000005d718=00000000f87a373b(7;.&°z7;); MemoryBus(r):000000000005d718=f87a373b(°z7;); Paged(r):0005d718=3b(;); Paged(r):0005d719=37(7)
BIU -- - 3c57:00001ebf 5A pop dx
Registers:
EAX: 80000026 EBX: 0000f866 ECX: 00005189 EDX: 0000373b
ESP: 0000f868 EBP: 0000f86a ESI: 00000082 EDI: 00fff94d
EIP: 00001ebf EFLAGS: 00007292
Previous CS:EIP: 3c57:00001ebe
BIU -- -
BIU -- I
BIU -- -
BIU -- S
BIU T1 - 3c57:00001ec0 8B DC mov bx,sp Paged(p):0003e46e=83(â); Normal(p):00001efe=83(â); Paged(p):0003e46f=c4(─); Normal(p):00001eff=c4(─); MemoryBus(p):000000000003e470=fff08b04( ≡ï♦); Paged(p):0003e470=04(♦); Normal(p):00001f00=04(♦); Paged(p):0003e471=8b(ï); Normal(p):00001f01=8b(ï)
Registers:
EIP: 00001ec0 EFLAGS: 00007292
Previous CS:EIP: 3c57:00001ebf
BIU -- -
BIU -- I
BIU -- -
BIU -- S
BIU -- - 3c57:00001ec2 2B D8 sub bx,ax
Registers:
EAX: 80000026 EBX: 0000f86a ECX: 00005189 EDX: 0000373b
EIP: 00001ec2 EFLAGS: 00007292
Previous CS:EIP: 3c57:00001ec0
BIU -- -
BIU -- I
BIU -- -
BIU -- S
BIU T1 - 3c57:00001ec4 72 0B jc 00001ed1 Paged(p):0003e472=f0(≡); Normal(p):00001f02=f0(≡); Paged(p):0003e473=ff( ); Normal(p):00001f03=ff( ); Paged(p):0003e474=76(v); Normal(p):00001f04=76(v); Paged(p):0003e475=f8(°); Normal(p):00001f05=f8(°)
Registers:
EAX: 80000026 EBX: 0000f844 ECX: 00005189 EDX: 0000373b
EIP: 00001ec4 EFLAGS: 00007286
Previous CS:EIP: 3c57:00001ec2
FLAGSINFO: 0000000000ipfavr0N11odItSz0a0P1c
BIU -- -
BIU -- -
BIU -- I
BIU -- -
BIU -- S
BIU T1 - Paged(p):0003e476=ff( ); Normal(p):00001f06=ff( ); Paged(p):0003e477=76(v); Normal(p):00001f07=76(v); Paged(p):0003e478=f6(÷); Normal(p):00001f08=f6(÷); Paged(p):0003e479=9a(Ü); Normal(p):00001f09=9a(Ü)
BIU -- - 3c57:00001ec6
BIU T1 - 3c57:00001ec6 RealRAM(r):0000000000058d08=000000002b65da50( 000+e┌P); RAM(r):0000000000058d08=000000002b65da50( 000+e┌P); MemoryBus(r):0000000000058d08=2b65da50(+e┌P); Paged(r):00058d08=50(P); Paged(r):00058d09=da(┌)
Registers:
EIP: 00001ec6 EFLAGS: 00007286
Previous CS:EIP: 3c57:00001ec4
BIU -- I ^ 3B 1E 58 AE cmp bx,word ds:[ae58]
BIU -- -
BIU -- S
BIU -- - 3c57:00001eca 72 05 jc 00001ed1
Registers:
EIP: 00001eca EFLAGS: 00007202
Previous CS:EIP: 3c57:00001ec6
FLAGSINFO: 0000000000ipfavr0N11odItsz0a0p1c
BIU -- -
BIU -- -
BIU -- I
BIU -- -
BIU -- S
BIU T1 - 3c57:00001ecc 8B E3 mov sp,bx Paged(p):0003e47a=5a(Z); Normal(p):00001f0a=5a(Z); Paged(p):0003e47b=29()); Normal(p):00001f0b=29()); Paged(p):0003e47c=57(W); Normal(p):00001f0c=57(W); Paged(p):0003e47d=3c(<); Normal(p):00001f0d=3c(<)
Registers:
EIP: 00001ecc EFLAGS: 00007202
Previous CS:EIP: 3c57:00001eca
BIU -- -
BIU -- I
BIU -- - 3c57:00001ece
BIU T1 - 3c57:00001ece MemoryBus(w):000000000005d6f2=3b(;); RAM(w):000000000005d6f2=373b(7;); RealRAM(w):000000000005d6f2=373b(7;); Paged(w):0005d6f2=373b(7;)
BIU -- - 3c57:00001ece 52 push dx
Registers:
ESP: 0000f844 EBP: 0000f86a ESI: 00000082 EDI: 00fff94d
EIP: 00001ece EFLAGS: 00007202
Previous CS:EIP: 3c57:00001ecc
BIU -- -
BIU -- I
BIU -- - 3c57:00001ecf
BIU T1 - 3c57:00001ecf MemoryBus(w):000000000005d6f0=89(ë); RAM(w):000000000005d6f0=5189(Që); RealRAM(w):000000000005d6f0=5189(Që); Paged(w):0005d6f0=5189(Që)
BIU -- - 3c57:00001ecf 51 push cx
Registers:
ESP: 0000f842 EBP: 0000f86a ESI: 00000082 EDI: 00fff94d
EIP: 00001ecf EFLAGS: 00007202
Previous CS:EIP: 3c57:00001ece
BIU -- -
BIU -- I
BIU -- - 3c57:00001ed0
BIU T1 - 3c57:00001ed0 MemoryBus(r):000000000005d6f0=373b5189(7;Që); Paged(r):0005d6f0=89(ë); Paged(r):0005d6f1=51(Q)
BIU T1 - 3c57:00001ed0 Paged(r):0005d6f2=3b(;); Paged(r):0005d6f3=37(7)
BIU -- E 3c57:00001ed0 CB retf
Registers:
ESP: 0000f840 EBP: 0000f86a ESI: 00000082 EDI: 00fff94d
EIP: 00001ed0 EFLAGS: 00007202
Previous CS:EIP: 3c57:00001ecf
BIU T1 - RealRAM(p):000000000003c539=b8(╕); RAM(p):000000000003c539=b8(╕); MemoryBus(p):000000000003c539=b8(╕); Paged(p):0003c539=b8(╕); Normal(p):00005189=b8(╕); RealRAM(p):000000000003c53a=ce7e(╬~); RAM(p):000000000003c53a=ce7e(╬~); MemoryBus(p):000000000003c53a=ce7e(╬~); Paged(p):0003c53a=7e(~); Normal(p):0000518a=7e(~); Paged(p):0003c53b=ce(╬); Normal(p):0000518b=ce(╬); RealRAM(p):000000000003c53c=8cec4689(î∞Fë); RAM(p):000000000003c53c=8cec4689(î∞Fë); MemoryBus(p):000000000003c53c=8cec4689(î∞Fë); Paged(p):0003c53c=89(ë); Normal(p):0000518c=89(ë)
BIU T1 - Paged(p):0003c53d=46(F); Normal(p):0000518d=46(F); Paged(p):0003c53e=ec(∞); Normal(p):0000518e=ec(∞); Paged(p):0003c53f=8c(î); Normal(p):0000518f=8c(î); MemoryBus(p):000000000003c540=501eee5e(P▲ε^); Paged(p):0003c540=5e(^); Normal(p):00005190=5e(^)
BIU T1 - Paged(p):0003c541=ee(ε); Normal(p):00005191=ee(ε); Paged(p):0003c542=1e(▲); Normal(p):00005192=1e(▲); Paged(p):0003c543=50(P); Normal(p):00005193=50(P); Paged(p):0003c544=9a(Ü); Normal(p):00005194=9a(Ü)
BIU T1 - Paged(p):0003c545=9c(£); Normal(p):00005195=9c(£); Paged(p):0003c546=12(↕); Normal(p):00005196=12(↕); Paged(p):0003c547=3b(;); Normal(p):00005197=3b(;); Paged(p):0003c548=37(7); Normal(p):00005198=37(7)
BIU T1 - Paged(p):0003c549=83(â); Normal(p):00005199=83(â); Paged(p):0003c54a=c4(─); Normal(p):0000519a=c4(─); Paged(p):0003c54b=04(♦); Normal(p):0000519b=04(♦); Paged(p):0003c54c=c7(╟); Normal(p):0000519c=c7(╟)
BIU T1 - Paged(p):0003c54d=46(F); Normal(p):0000519d=46(F); Paged(p):0003c54e=f0(≡); Normal(p):0000519e=f0(≡); Paged(p):0003c54f=00( ); Normal(p):0000519f=00( ); MemoryBus(p):000000000003c550=dc468d0f(▄Fì☼); Paged(p):0003c550=0f(☼); Normal(p):000051a0=0f(☼)
BIU T1 - Paged(p):0003c551=8d(ì); Normal(p):000051a1=8d(ì); Paged(p):0003c552=46(F); Normal(p):000051a2=46(F); Paged(p):0003c553=dc(▄); Normal(p):000051a3=dc(▄); Paged(p):0003c554=16(▬); Normal(p):000051a4=16(▬)
BIU T1 - Paged(p):0003c555=50(P); Normal(p):000051a5=50(P); Paged(p):0003c556=8d(ì); Normal(p):000051a6=8d(ì); Paged(p):0003c557=46(F); Normal(p):000051a7=46(F); Paged(p):0003c558=f0(≡); Normal(p):000051a8=f0(≡)
BIU T1 - Paged(p):0003c559=16(▬); Normal(p):000051a9=16(▬); Paged(p):0003c55a=50(P); Normal(p):000051aa=50(P); Paged(p):0003c55b=9a(Ü); Normal(p):000051ab=9a(Ü); Paged(p):0003c55c=d6(╓); Normal(p):000051ac=d6(╓)
BIU T1 - Paged(p):0003c55d=44(D); Normal(p):000051ad=44(D); Paged(p):0003c55e=3b(;); Normal(p):000051ae=3b(;); Paged(p):0003c55f=37(7); Normal(p):000051af=37(7); MemoryBus(p):000000000003c560=8a08c483(è◘─â); Paged(p):0003c560=83(â); Normal(p):000051b0=83(â)
BIU T1 - Paged(p):0003c561=c4(─); Normal(p):000051b1=c4(─); Paged(p):0003c562=08(◘); Normal(p):000051b2=08(◘); Paged(p):0003c563=8a(è); Normal(p):000051b3=8a(è); Paged(p):0003c564=46(F); Normal(p):000051b4=46(F)
BIU T1 - Paged(p):0003c565=dc(▄); Normal(p):000051b5=dc(▄); Paged(p):0003c566=2a(*); Normal(p):000051b6=2a(*); Paged(p):0003c567=e4(Σ); Normal(p):000051b7=e4(Σ); Paged(p):0003c568=89(ë); Normal(p):000051b8=89(ë)
BIU T1 - Paged(p):0003c569=46(F); Normal(p):000051b9=46(F); Paged(p):0003c56a=da(┌); Normal(p):000051ba=da(┌); Paged(p):0003c56b=ff( ); Normal(p):000051bb=ff( ); Paged(p):0003c56c=76(v); Normal(p):000051bc=76(v)
BIU T1 I Paged(p):0003c56d=ee(ε); Normal(p):000051bd=ee(ε); Paged(p):0003c56e=ff( ); Normal(p):000051be=ff( ); Paged(p):0003c56f=76(v); Normal(p):000051bf=76(v); MemoryBus(p):000000000003c570=12c69aec(↕╞Ü∞); Paged(p):0003c570=ec(∞); Normal(p):000051c0=ec(∞)
BIU T1 - Paged(p):0003c571=9a(Ü); Normal(p):000051c1=9a(Ü); Paged(p):0003c572=c6(╞); Normal(p):000051c2=c6(╞); Paged(p):0003c573=12(↕); Normal(p):000051c3=12(↕); Paged(p):0003c574=3b(;); Normal(p):000051c4=3b(;)
BIU T1 S Paged(p):0003c575=37(7); Normal(p):000051c5=37(7); Paged(p):0003c576=8b(ï); Normal(p):000051c6=8b(ï); Paged(p):0003c577=46(F); Normal(p):000051c7=46(F); Paged(p):0003c578=da(┌); Normal(p):000051c8=da(┌)
BIU -- - 373b:00005189 B8 7E CE mov ax,ce7e
Registers:
EIP: 00005189 EFLAGS: 00007202
Previous CS:EIP: 3c57:00001ed0
BIU -- -
BIU -- I
BIU T1 - Paged(p):0003c579=8b(ï); Normal(p):000051c9=8b(ï); Paged(p):0003c57a=e5(σ); Normal(p):000051ca=e5(σ); Paged(p):0003c57b=5d(]); Normal(p):000051cb=5d(]); Paged(p):0003c57c=cb(╦); Normal(p):000051cc=cb(╦)
BIU -- S
BIU -- -
BIU -- - 373b:0000518c
BIU T1 - 373b:0000518c MemoryBus(w):000000000005d706=7e(~); RAM(w):000000000005d706=ce7e(╬~); RealRAM(w):000000000005d706=ce7e(╬~); Paged(w):0005d706=ce7e(╬~)
Registers:
EAX: 8000ce7e EBX: 0000f844 ECX: 00005189 EDX: 0000373b
EIP: 0000518c EFLAGS: 00007202
Previous CS:EIP: 373b:00005189
BIU -- I ^ 89 46 EC mov word ss:[bp-14],ax
BIU -- -
BIU -- S
BIU T1 - Paged(p):0003c57d=90(É); Normal(p):000051cd=90(É); Paged(p):0003c57e=56(V); Normal(p):000051ce=56(V); Paged(p):0003c57f=57(W); Normal(p):000051cf=57(W); MemoryBus(p):000000000003c580=c08ed88c(└Ä╪î); Paged(p):0003c580=8c(î); Normal(p):000051d0=8c(î)
BIU -- - 373b:0000518f
BIU T1 - 373b:0000518f MemoryBus(w):000000000005d708=eb(δ); RAM(w):000000000005d708=4deb(Mδ); RealRAM(w):000000000005d708=4deb(Mδ); Paged(w):0005d708=4deb(Mδ)
Registers:
EIP: 0000518f EFLAGS: 00007202
Previous CS:EIP: 373b:0000518c
BIU -- I ^ 8C 5E EE mov word ss:[bp-12],ds
BIU -- - 373b:00005192
BIU T1 - 373b:00005192 MemoryBus(w):000000000005d6f2=eb(δ); RAM(w):000000000005d6f2=4deb(Mδ); RealRAM(w):000000000005d6f2=4deb(Mδ); Paged(w):0005d6f2=4deb(Mδ)
Registers:
EIP: 00005192 EFLAGS: 00007202
Previous CS:EIP: 373b:0000518f
BIU -- I ^ 1E push ds
BIU -- - 373b:00005193
BIU T1 - 373b:00005193 MemoryBus(w):000000000005d6f0=7e(~); RAM(w):000000000005d6f0=ce7e(╬~); RealRAM(w):000000000005d6f0=ce7e(╬~); Paged(w):0005d6f0=ce7e(╬~)
Registers:
EIP: 00005193 EFLAGS: 00007202
Previous CS:EIP: 373b:00005192
BIU -- I ^ 50 push ax
BIU T1 - Paged(p):0003c581=d8(╪); Normal(p):000051d1=d8(╪); Paged(p):0003c582=8e(Ä); Normal(p):000051d2=8e(Ä); Paged(p):0003c583=c0(└); Normal(p):000051d3=c0(└); Paged(p):0003c584=be(╛); Normal(p):000051d4=be(╛)
BIU T1 S Paged(p):0003c585=14(¶); Normal(p):000051d5=14(¶); Paged(p):0003c586=a5(Ñ); Normal(p):000051d6=a5(Ñ); Paged(p):0003c587=bf(┐); Normal(p):000051d7=bf(┐); Paged(p):0003c588=66(f); Normal(p):000051d8=66(f)
BIU -- - 373b:00005194
BIU T1 - 373b:00005194 MemoryBus(w):000000000005d6ee=3b(;); RAM(w):000000000005d6ee=373b(7;); RealRAM(w):000000000005d6ee=373b(7;); Paged(w):0005d6ee=373b(7;)
BIU T1 - 373b:00005194 MemoryBus(w):000000000005d6ec=99(Ö); RAM(w):000000000005d6ec=5199(QÖ); RealRAM(w):000000000005d6ec=5199(QÖ); Paged(w):0005d6ec=5199(QÖ)
BIU -- E 373b:00005194 9A 9C 12 3B 37 call 373b:0000129c
Registers:
EIP: 00005194 EFLAGS: 00007202
Previous CS:EIP: 373b:00005193
BIU T1 - RealRAM(p):000000000003864c=33ec8b55(3∞ïU); RAM(p):000000000003864c=33ec8b55(3∞ïU); MemoryBus(p):000000000003864c=33ec8b55(3∞ïU); Paged(p):0003864c=55(U); Normal(p):0000129c=55(U); Paged(p):0003864d=8b(ï); Normal(p):0000129d=8b(ï); Paged(p):0003864e=ec(∞); Normal(p):0000129e=ec(∞); Paged(p):0003864f=33(3); Normal(p):0000129f=33(3)
BIU T1 - MemoryBus(p):0000000000038650=1ebe9ac0(▲╛Ü└); Paged(p):00038650=c0(└); Normal(p):000012a0=c0(└); Paged(p):00038651=9a(Ü); Normal(p):000012a1=9a(Ü); Paged(p):00038652=be(╛); Normal(p):000012a2=be(╛); Paged(p):00038653=1e(▲); Normal(p):000012a3=1e(▲)
BIU T1 - Paged(p):00038654=57(W); Normal(p):000012a4=57(W); Paged(p):00038655=3c(<); Normal(p):000012a5=3c(<); Paged(p):00038656=8e(Ä); Normal(p):000012a6=8e(Ä); Paged(p):00038657=06(♠); Normal(p):000012a7=06(♠)
BIU T1 - Paged(p):00038658=04(♦); Normal(p):000012a8=04(♦); Paged(p):00038659=ca(╩); Normal(p):000012a9=ca(╩); Paged(p):0003865a=26(&); Normal(p):000012aa=26(&); Paged(p):0003865b=83(â); Normal(p):000012ab=83(â)
BIU T1 - Paged(p):0003865c=3e(>); Normal(p):000012ac=3e(>); Paged(p):0003865d=46(F); Normal(p):000012ad=46(F); Paged(p):0003865e=01(☺); Normal(p):000012ae=01(☺); Paged(p):0003865f=01(☺); Normal(p):000012af=01(☺)
BIU T1 - MemoryBus(p):0000000000038660=76ff1275(v ↕u); Paged(p):00038660=75(u); Normal(p):000012b0=75(u); Paged(p):00038661=12(↕); Normal(p):000012b1=12(↕); Paged(p):00038662=ff( ); Normal(p):000012b2=ff( ); Paged(p):00038663=76(v); Normal(p):000012b3=76(v)
BIU T1 - Paged(p):00038664=08(◘); Normal(p):000012b4=08(◘); Paged(p):00038665=ff( ); Normal(p):000012b5=ff( ); Paged(p):00038666=76(v); Normal(p):000012b6=76(v); Paged(p):00038667=06(♠); Normal(p):000012b7=06(♠)
BIU T1 - Paged(p):00038668=8e(Ä); Normal(p):000012b8=8e(Ä); Paged(p):00038669=06(♠); Normal(p):000012b9=06(♠); Paged(p):0003866a=06(♠); Normal(p):000012ba=06(♠); Paged(p):0003866b=ca(╩); Normal(p):000012bb=ca(╩)
BIU T1 - Paged(p):0003866c=26(&); Normal(p):000012bc=26(&); Paged(p):0003866d=ff( ); Normal(p):000012bd=ff( ); Paged(p):0003866e=1e(▲); Normal(p):000012be=1e(▲); Paged(p):0003866f=3c(<); Normal(p):000012bf=3c(<)
BIU T1 - MemoryBus(p):0000000000038670=04c48301(♦─â☺); Paged(p):00038670=01(☺); Normal(p):000012c0=01(☺); Paged(p):00038671=83(â); Normal(p):000012c1=83(â); Paged(p):00038672=c4(─); Normal(p):000012c2=c4(─); Paged(p):00038673=04(♦); Normal(p):000012c3=04(♦)
BIU T1 - Paged(p):00038674=5d(]); Normal(p):000012c4=5d(]); Paged(p):00038675=cb(╦); Normal(p):000012c5=cb(╦); Paged(p):00038676=55(U); Normal(p):000012c6=55(U); Paged(p):00038677=8b(ï); Normal(p):000012c7=8b(ï)
BIU T1 - Paged(p):00038678=ec(∞); Normal(p):000012c8=ec(∞); Paged(p):00038679=33(3); Normal(p):000012c9=33(3); Paged(p):0003867a=c0(└); Normal(p):000012ca=c0(└); Paged(p):0003867b=9a(Ü); Normal(p):000012cb=9a(Ü)
BIU T1 - Paged(p):0003867c=be(╛); Normal(p):000012cc=be(╛); Paged(p):0003867d=1e(▲); Normal(p):000012cd=1e(▲); Paged(p):0003867e=57(W); Normal(p):000012ce=57(W); Paged(p):0003867f=3c(<); Normal(p):000012cf=3c(<)
BIU T1 - MemoryBus(p):0000000000038680=ca04068e(╩♦♠Ä); Paged(p):00038680=8e(Ä); Normal(p):000012d0=8e(Ä); Paged(p):00038681=06(♠); Normal(p):000012d1=06(♠); Paged(p):00038682=04(♦); Normal(p):000012d2=04(♦); Paged(p):00038683=ca(╩); Normal(p):000012d3=ca(╩)
BIU T1 - Paged(p):00038684=26(&); Normal(p):000012d4=26(&); Paged(p):00038685=83(â); Normal(p):000012d5=83(â); Paged(p):00038686=3e(>); Normal(p):000012d6=3e(>); Paged(p):00038687=46(F); Normal(p):000012d7=46(F)
BIU T1 - Paged(p):00038688=01(☺); Normal(p):000012d8=01(☺); Paged(p):00038689=01(☺); Normal(p):000012d9=01(☺); Paged(p):0003868a=75(u); Normal(p):000012da=75(u); Paged(p):0003868b=12(↕); Normal(p):000012db=12(↕)
BIU -- I
BIU -- - 373b:0000129c
BIU T1 - 373b:0000129c MemoryBus(w):000000000005d6ea=6a(j); RAM(w):000000000005d6ea=f86a(°j); RealRAM(w):000000000005d6ea=f86a(°j); Paged(w):0005d6ea=f86a(°j)
Registers:
ESP: 0000f83c EBP: 0000f86a ESI: 00000082 EDI: 00fff94d
EIP: 0000129c EFLAGS: 00007202
Previous CS:EIP: 373b:00005194
BIU -- I ^ 55 push bp
BIU -- -
BIU -- S
BIU -- - 373b:0000129d 8B EC mov bp,sp
Registers:
ESP: 0000f83a EBP: 0000f86a ESI: 00000082 EDI: 00fff94d
EIP: 0000129d EFLAGS: 00007202
Previous CS:EIP: 373b:0000129c
BIU -- -
BIU -- I
BIU T1 - Paged(p):0003868c=ff( ); Normal(p):000012dc=ff( ); Paged(p):0003868d=76(v); Normal(p):000012dd=76(v); Paged(p):0003868e=08(◘); Normal(p):000012de=08(◘); Paged(p):0003868f=ff( ); Normal(p):000012df=ff( )
BIU -- S
BIU -- - 373b:0000129f 33 C0 xor ax,ax
Registers:
ESP: 0000f83a EBP: 0000f83a ESI: 00000082 EDI: 00fff94d
EIP: 0000129f EFLAGS: 00007202
Previous CS:EIP: 373b:0000129d
BIU -- -
BIU -- I
BIU -- -
BIU -- S
BIU T1 - 373b:000012a1 MemoryBus(p):0000000000038690=068e0676(♠Ä♠v); Paged(p):00038690=76(v); Normal(p):000012e0=76(v); Paged(p):00038691=06(♠); Normal(p):000012e1=06(♠); Paged(p):00038692=8e(Ä); Normal(p):000012e2=8e(Ä); Paged(p):00038693=06(♠); Normal(p):000012e3=06(♠)
BIU T1 - 373b:000012a1 MemoryBus(w):000000000005d6e8=3b(;); RAM(w):000000000005d6e8=373b(7;); RealRAM(w):000000000005d6e8=373b(7;); Paged(w):0005d6e8=373b(7;)
BIU T1 - 373b:000012a1 MemoryBus(w):000000000005d6e6=a6(ª); RAM(w):000000000005d6e6=12a6(↕ª); RealRAM(w):000000000005d6e6=12a6(↕ª); Paged(w):0005d6e6=12a6(↕ª)
BIU -- - 373b:000012a1
BIU -- E 373b:000012a1 9A BE 1E 57 3C call 3c57:00001ebe
Registers:
EAX: 80000000 EBX: 0000f844 ECX: 00005189 EDX: 0000373b
EIP: 000012a1 EFLAGS: 00007246
Previous CS:EIP: 373b:0000129f
BIU T1 - Paged(p):0003e42e=59(Y); Normal(p):00001ebe=59(Y); Paged(p):0003e42f=5a(Z); Normal(p):00001ebf=5a(Z); MemoryBus(p):000000000003e430=d82bdc8b(╪+▄ï); Paged(p):0003e430=8b(ï); Normal(p):00001ec0=8b(ï); Paged(p):0003e431=dc(▄); Normal(p):00001ec1=dc(▄)
BIU -- I
BIU T1 - 3c57:00001ebe RealRAM(r):000000000005d6e6=12a6(↕ª); RAM(r):000000000005d6e6=12a6(↕ª); MemoryBus(r):000000000005d6e6=12a6(↕ª); Paged(r):0005d6e6=a6(ª); Paged(r):0005d6e7=12(↕)
Registers:
ESP: 0000f836 EBP: 0000f83a ESI: 00000082 EDI: 00fff94d
EIP: 00001ebe EFLAGS: 00007246
Previous CS:EIP: 373b:000012a1
BIU -- -
BIU -- I
BIU T1 - 3c57:00001ebf RealRAM(r):000000000005d6e8=00000000f86a373b(7;QÖ°j7;); RAM(r):000000000005d6e8=00000000f86a373b(7;QÖ°j7;); MemoryBus(r):000000000005d6e8=f86a373b(°j7;); Paged(r):0005d6e8=3b(;); Paged(r):0005d6e9=37(7)
Registers:
EAX: 80000000 EBX: 0000f844 ECX: 000012a6 EDX: 0000373b
ESP: 0000f838 EBP: 0000f83a ESI: 00000082 EDI: 00fff94d
EIP: 00001ebf EFLAGS: 00007246
BIU -- -
BIU -- I
BIU -- -
BIU -- S
Registers:
EIP: 00001ec0 EFLAGS: 00007246
BIU -- -
BIU -- I
BIU -- -
BIU -- S
Registers:
EAX: 80000000 EBX: 0000f83a ECX: 000012a6 EDX: 0000373b
EIP: 00001ec2 EFLAGS: 00007246
BIU -- -
BIU -- I
BIU -- -
BIU -- S
Registers:
BIU -- -
BIU -- -
BIU -- I
BIU -- -
BIU -- S
BIU T1 - 3c57:00001ec6 Paged(r):00058d08=50(P); Paged(r):00058d09=da(┌)
Registers:
BIU -- -
BIU -- S
Registers:
BIU -- -
BIU -- -
BIU -- I
BIU -- -
BIU -- S
Registers:
BIU -- -
BIU -- I
BIU T1 - 3c57:00001ece MemoryBus(w):000000000005d6e8=3b(;); RAM(w):000000000005d6e8=373b(7;); RealRAM(w):000000000005d6e8=373b(7;); Paged(w):0005d6e8=373b(7;)
Registers:
BIU -- -
BIU -- I
BIU T1 - 3c57:00001ecf MemoryBus(w):000000000005d6e6=a6(ª); RAM(w):000000000005d6e6=12a6(↕ª); RealRAM(w):000000000005d6e6=12a6(↕ª); Paged(w):0005d6e6=12a6(↕ª)
Registers:
BIU -- -
BIU -- I
BIU T1 - 3c57:00001ed0 RealRAM(r):000000000005d6e6=12a6(↕ª); RAM(r):000000000005d6e6=12a6(↕ª); MemoryBus(r):000000000005d6e6=12a6(↕ª); Paged(r):0005d6e6=a6(ª); Paged(r):0005d6e7=12(↕)
BIU T1 - 3c57:00001ed0 RealRAM(r):000000000005d6e8=00000000f86a373b(7;QÖ°j7;); RAM(r):000000000005d6e8=00000000f86a373b(7;QÖ°j7;); MemoryBus(r):000000000005d6e8=f86a373b(°j7;); Paged(r):0005d6e8=3b(;); Paged(r):0005d6e9=37(7)
Registers:
BIU T1 - RealRAM(p):0000000000038656=068e(♠Ä); RAM(p):0000000000038656=068e(♠Ä); MemoryBus(p):0000000000038656=068e(♠Ä); Paged(p):00038656=8e(Ä); Normal(p):000012a6=8e(Ä); Paged(p):00038657=06(♠); Normal(p):000012a7=06(♠); RealRAM(p):0000000000038658=000000008326ca04(☺☺F>â&╩♦); RAM(p):0000000000038658=000000008326ca04(☺☺F>â&╩♦); MemoryBus(p):0000000000038658=8326ca04(â&╩♦); Paged(p):00038658=04(♦); Normal(p):000012a8=04(♦); Paged(p):00038659=ca(╩); Normal(p):000012a9=ca(╩)
BIU T1 - Paged(p):0003865a=26(&); Normal(p):000012aa=26(&); Paged(p):0003865b=83(â); Normal(p):000012ab=83(â); Paged(p):0003865c=3e(>); Normal(p):000012ac=3e(>); Paged(p):0003865d=46(F); Normal(p):000012ad=46(F)
BIU T1 - Paged(p):0003865e=01(☺); Normal(p):000012ae=01(☺); Paged(p):0003865f=01(☺); Normal(p):000012af=01(☺); MemoryBus(p):0000000000038660=76ff1275(v ↕u); Paged(p):00038660=75(u); Normal(p):000012b0=75(u); Paged(p):00038661=12(↕); Normal(p):000012b1=12(↕)
BIU T1 - Paged(p):00038662=ff( ); Normal(p):000012b2=ff( ); Paged(p):00038663=76(v); Normal(p):000012b3=76(v); Paged(p):00038664=08(◘); Normal(p):000012b4=08(◘); Paged(p):00038665=ff( ); Normal(p):000012b5=ff( )
BIU T1 - Paged(p):00038666=76(v); Normal(p):000012b6=76(v); Paged(p):00038667=06(♠); Normal(p):000012b7=06(♠); Paged(p):00038668=8e(Ä); Normal(p):000012b8=8e(Ä); Paged(p):00038669=06(♠); Normal(p):000012b9=06(♠)
BIU T1 - Paged(p):0003866a=06(♠); Normal(p):000012ba=06(♠); Paged(p):0003866b=ca(╩); Normal(p):000012bb=ca(╩); Paged(p):0003866c=26(&); Normal(p):000012bc=26(&); Paged(p):0003866d=ff( ); Normal(p):000012bd=ff( )
BIU T1 - Paged(p):0003866e=1e(▲); Normal(p):000012be=1e(▲); Paged(p):0003866f=3c(<); Normal(p):000012bf=3c(<); MemoryBus(p):0000000000038670=04c48301(♦─â☺); Paged(p):00038670=01(☺); Normal(p):000012c0=01(☺); Paged(p):00038671=83(â); Normal(p):000012c1=83(â)
BIU T1 - Paged(p):00038672=c4(─); Normal(p):000012c2=c4(─); Paged(p):00038673=04(♦); Normal(p):000012c3=04(♦); Paged(p):00038674=5d(]); Normal(p):000012c4=5d(]); Paged(p):00038675=cb(╦); Normal(p):000012c5=cb(╦)
BIU T1 - Paged(p):00038676=55(U); Normal(p):000012c6=55(U); Paged(p):00038677=8b(ï); Normal(p):000012c7=8b(ï); Paged(p):00038678=ec(∞); Normal(p):000012c8=ec(∞); Paged(p):00038679=33(3); Normal(p):000012c9=33(3)
BIU T1 - Paged(p):0003867a=c0(└); Normal(p):000012ca=c0(└); Paged(p):0003867b=9a(Ü); Normal(p):000012cb=9a(Ü); Paged(p):0003867c=be(╛); Normal(p):000012cc=be(╛); Paged(p):0003867d=1e(▲); Normal(p):000012cd=1e(▲)
BIU T1 - Paged(p):0003867e=57(W); Normal(p):000012ce=57(W); Paged(p):0003867f=3c(<); Normal(p):000012cf=3c(<); Paged(p):00038680=8e(Ä); Normal(p):000012d0=8e(Ä); Paged(p):00038681=06(♠); Normal(p):000012d1=06(♠)
BIU T1 - Paged(p):00038682=04(♦); Normal(p):000012d2=04(♦); Paged(p):00038683=ca(╩); Normal(p):000012d3=ca(╩); Paged(p):00038684=26(&); Normal(p):000012d4=26(&); Paged(p):00038685=83(â); Normal(p):000012d5=83(â)
BIU T1 - Paged(p):00038686=3e(>); Normal(p):000012d6=3e(>); Paged(p):00038687=46(F); Normal(p):000012d7=46(F); Paged(p):00038688=01(☺); Normal(p):000012d8=01(☺); Paged(p):00038689=01(☺); Normal(p):000012d9=01(☺)
BIU T1 I Paged(p):0003868a=75(u); Normal(p):000012da=75(u); Paged(p):0003868b=12(↕); Normal(p):000012db=12(↕); Paged(p):0003868c=ff( ); Normal(p):000012dc=ff( ); Paged(p):0003868d=76(v); Normal(p):000012dd=76(v)
BIU T1 - Paged(p):0003868e=08(◘); Normal(p):000012de=08(◘); Paged(p):0003868f=ff( ); Normal(p):000012df=ff( ); Paged(p):00038690=76(v); Normal(p):000012e0=76(v); Paged(p):00038691=06(♠); Normal(p):000012e1=06(♠)
BIU T1 S Paged(p):00038692=8e(Ä); Normal(p):000012e2=8e(Ä); Paged(p):00038693=06(♠); Normal(p):000012e3=06(♠); Paged(p):00038694=08(◘); Normal(p):000012e4=08(◘); Paged(p):00038695=ca(╩); Normal(p):000012e5=ca(╩)
BIU T1 - Paged(p):00038696=26(&); Normal(p):000012e6=26(&); Paged(p):00038697=ff( ); Normal(p):000012e7=ff( ); Paged(p):00038698=1e(▲); Normal(p):000012e8=1e(▲); Paged(p):00038699=40(@); Normal(p):000012e9=40(@)
BIU -- - 373b:000012a6
BIU T1 - 373b:000012a6 Paged(r):0005a8b4=eb(δ); Paged(r):0005a8b5=4d(M)
BIU -- - 373b:000012a6 8E 06 04 CA mov es,word ds:[ca04]
Registers:
EIP: 000012a6 EFLAGS: 00007202
BIU -- -
BIU -- -
BIU -- I
BIU -- -
BIU -- -
BIU -- S
BIU T1 - Paged(p):0003869a=01(☺); Normal(p):000012ea=01(☺); Paged(p):0003869b=83(â); Normal(p):000012eb=83(â); Paged(p):0003869c=c4(─); Normal(p):000012ec=c4(─); Paged(p):0003869d=04(♦); Normal(p):000012ed=04(♦)
BIU -- -
BIU -- -
BIU -- - 373b:000012aa
BIU T1 - 373b:000012aa RealRAM(r):000000000004dff6=0000( ); RAM(r):000000000004dff6=0000( ); MemoryBus(r):000000000004dff6=0000( ); Paged(r):0004dff6=00( ); Paged(r):0004dff7=00( )
BIU -- - 373b:000012aa 26 83 3E 46 01 01 cmp word es:[0146],0001
Registers:
EIP: 000012aa EFLAGS: 00007202
Previous CS:EIP: 373b:000012a6
BIU -- -
BIU -- -
BIU -- -
BIU -- I
BIU -- -
BIU -- S
BIU T1 E 373b:000012b0 75 12 jnz 000012c4 Paged(p):00038674=5d(]); Normal(p):000012c4=5d(]); Paged(p):00038675=cb(╦); Normal(p):000012c5=cb(╦); Paged(p):00038676=55(U); Normal(p):000012c6=55(U); Paged(p):00038677=8b(ï); Normal(p):000012c7=8b(ï)
Registers:
EIP: 000012b0 EFLAGS: 00007297
Previous CS:EIP: 373b:000012aa
FLAGSINFO: 0000000000ipfavr0N11odItSz0A0P1C
BIU T1 - Paged(p):00038680=8e(Ä); Normal(p):000012d0=8e(Ä); Paged(p):00038681=06(♠); Normal(p):000012d1=06(♠); Paged(p):00038682=04(♦); Normal(p):000012d2=04(♦); Paged(p):00038683=ca(╩); Normal(p):000012d3=ca(╩)
BIU T1 I Paged(p):00038684=26(&); Normal(p):000012d4=26(&); Paged(p):00038685=83(â); Normal(p):000012d5=83(â); Paged(p):00038686=3e(>); Normal(p):000012d6=3e(>); Paged(p):00038687=46(F); Normal(p):000012d7=46(F)
BIU T1 - 373b:000012c4 Paged(p):00038688=01(☺); Normal(p):000012d8=01(☺); Paged(p):00038689=01(☺); Normal(p):000012d9=01(☺); Paged(p):0003868a=75(u); Normal(p):000012da=75(u); Paged(p):0003868b=12(↕); Normal(p):000012db=12(↕)
BIU T1 - 373b:000012c4 Paged(p):0003868c=ff( ); Normal(p):000012dc=ff( ); Paged(p):0003868d=76(v); Normal(p):000012dd=76(v); Paged(p):0003868e=08(◘); Normal(p):000012de=08(◘); Paged(p):0003868f=ff( ); Normal(p):000012df=ff( )
BIU T1 - 373b:000012c4 Paged(p):00038690=76(v); Normal(p):000012e0=76(v); Paged(p):00038691=06(♠); Normal(p):000012e1=06(♠); Paged(p):00038692=8e(Ä); Normal(p):000012e2=8e(Ä); Paged(p):00038693=06(♠); Normal(p):000012e3=06(♠)
BIU T1 - 373b:000012c4 Paged(r):0005d6ea=6a(j); Paged(r):0005d6eb=f8(°)
BIU -- - 373b:000012c4 5D pop bp
Registers:
EIP: 000012c4 EFLAGS: 00007297
Previous CS:EIP: 373b:000012b0
BIU T1 - Paged(p):00038694=08(◘); Normal(p):000012e4=08(◘); Paged(p):00038695=ca(╩); Normal(p):000012e5=ca(╩); Paged(p):00038696=26(&); Normal(p):000012e6=26(&); Paged(p):00038697=ff( ); Normal(p):000012e7=ff( )
BIU T1 I Paged(p):00038698=1e(▲); Normal(p):000012e8=1e(▲); Paged(p):00038699=40(@); Normal(p):000012e9=40(@); Paged(p):0003869a=01(☺); Normal(p):000012ea=01(☺); Paged(p):0003869b=83(â); Normal(p):000012eb=83(â)
BIU T1 - 373b:000012c5 Paged(p):0003869c=c4(─); Normal(p):000012ec=c4(─); Paged(p):0003869d=04(♦); Normal(p):000012ed=04(♦); Paged(p):0003869e=8e(Ä); Normal(p):000012ee=8e(Ä); Paged(p):0003869f=06(♠); Normal(p):000012ef=06(♠)
BIU T1 - 373b:000012c5 Paged(r):0005d6ec=99(Ö); Paged(r):0005d6ed=51(Q)
BIU T1 - 373b:000012c5 Paged(r):0005d6ee=3b(;); Paged(r):0005d6ef=37(7)
BIU -- E 373b:000012c5 CB retf
Registers:
CS: 373b DS: 4deb ES: 4deb FS: 0000 GS: 0000 SS: 4deb TR: 0000 LDTR: 0000
EIP: 000012c5 EFLAGS: 00007297
CR0: 00000010 CR2: 00000000 CR3: 00000000 CR4: 00000000
DR0: 00000000 DR1: 00000000 DR2: 00000000 DR3: 00000000
DR6: 00000000 DR7: 00000000
GDTR: 00000008f466ffff IDTR: 00000000000003ff
CS descriptor: 0000930373B0FFFF
SS descriptor: 00009304DEB0FFFF
DS descriptor: 00009304DEB0FFFF
ES descriptor: 00009304DEB0FFFF
FS descriptor: 000093000000FFFF
GS descriptor: 000093000000FFFF
TR descriptor: 000082000000FFFF
LDTR descriptor: 000082000000FFFF
Previous CS:EIP: 373b:000012c4
BIU T1 - RealRAM(p):000000000003c549=83(â); RAM(p):000000000003c549=83(â); MemoryBus(p):000000000003c549=83(â); Paged(p):0003c549=83(â); Normal(p):00005199=83(â); RealRAM(p):000000000003c54a=04c4(♦─); RAM(p):000000000003c54a=04c4(♦─); MemoryBus(p):000000000003c54a=04c4(♦─); Paged(p):0003c54a=c4(─); Normal(p):0000519a=c4(─); Paged(p):0003c54b=04(♦); Normal(p):0000519b=04(♦); RealRAM(p):000000000003c54c=00f046c7( ≡F╟); RAM(p):000000000003c54c=00f046c7( ≡F╟); MemoryBus(p):000000000003c54c=00f046c7( ≡F╟); Paged(p):0003c54c=c7(╟); Normal(p):0000519c=c7(╟)
BIU T1 - Paged(p):0003c56d=ee(ε); Normal(p):000051bd=ee(ε); Paged(p):0003c56e=ff( ); Normal(p):000051be=ff( ); Paged(p):0003c56f=76(v); Normal(p):000051bf=76(v); MemoryBus(p):000000000003c570=12c69aec(↕╞Ü∞); Paged(p):0003c570=ec(∞); Normal(p):000051c0=ec(∞)
BIU T1 - Paged(p):0003c575=37(7); Normal(p):000051c5=37(7); Paged(p):0003c576=8b(ï); Normal(p):000051c6=8b(ï); Paged(p):0003c577=46(F); Normal(p):000051c7=46(F); Paged(p):0003c578=da(┌); Normal(p):000051c8=da(┌)
BIU T1 I Paged(p):0003c57d=90(É); Normal(p):000051cd=90(É); Paged(p):0003c57e=56(V); Normal(p):000051ce=56(V); Paged(p):0003c57f=57(W); Normal(p):000051cf=57(W); MemoryBus(p):000000000003c580=c08ed88c(└Ä╪î); Paged(p):0003c580=8c(î); Normal(p):000051d0=8c(î)
BIU -- -
BIU -- - 373b:00005199 83 C4 04 add sp,0004
Registers:
EIP: 00005199 EFLAGS: 00007297
Previous CS:EIP: 373b:000012c5
BIU -- -
BIU -- -
BIU -- I
BIU T1 - Paged(p):0003c589=ae(«); Normal(p):000051d9=ae(«); Paged(p):0003c58a=b9(╣); Normal(p):000051da=b9(╣); Paged(p):0003c58b=0a( ); Normal(p):000051db=0a( ); Paged(p):0003c58c=00( ); Normal(p):000051dc=00( )
BIU T1 S Paged(p):0003c58d=f3(≤); Normal(p):000051dd=f3(≤); Paged(p):0003c58e=a5(Ñ); Normal(p):000051de=a5(Ñ); Paged(p):0003c58f=5f(_); Normal(p):000051df=5f(_); MemoryBus(p):000000000003c590=30b4cb5e(0┤╦^); Paged(p):0003c590=5e(^); Normal(p):000051e0=5e(^)
BIU -- -
BIU -- -
BIU -- - 373b:0000519c
BIU T1 - 373b:0000519c MemoryBus(w):000000000005d70a=00( ); RAM(w):000000000005d70a=0f00(☼ ); RealRAM(w):000000000005d70a=0f00(☼ ); Paged(w):0005d70a=0f00(☼ )
Registers:
EIP: 0000519c EFLAGS: 00007286
Previous CS:EIP: 373b:00005199
BIU -- I ^ C7 46 F0 00 0F mov word ss:[bp-10],0f00
BIU -- -
BIU -- S
BIU -- -
BIU -- - 373b:000051a1 8D 46 DC lea ax,word ss:[bp-24]
Registers:
EIP: 000051a1 EFLAGS: 00007286
Previous CS:EIP: 373b:0000519c
BIU -- -
BIU -- -
BIU -- -
BIU -- I
BIU T1 - 373b:000051a4 Paged(p):0003c591=cb(╦); Normal(p):000051e1=cb(╦); Paged(p):0003c592=b4(┤); Normal(p):000051e2=b4(┤); Paged(p):0003c593=30(0); Normal(p):000051e3=30(0); Paged(p):0003c594=cd(═); Normal(p):000051e4=cd(═)
BIU -- - 373b:000051a4
BIU T1 - 373b:000051a4 MemoryBus(w):000000000005d6f2=eb(δ); RAM(w):000000000005d6f2=4deb(Mδ); RealRAM(w):000000000005d6f2=4deb(Mδ); Paged(w):0005d6f2=4deb(Mδ)
Registers:
EAX: 8000f846 EBX: 0000f83a ECX: 000012a6 EDX: 0000373b
EIP: 000051a4 EFLAGS: 00007286
Previous CS:EIP: 373b:000051a1
BIU -- I ^ 16 push ss
BIU -- - 373b:000051a5
BIU T1 - 373b:000051a5 MemoryBus(w):000000000005d6f0=46(F); RAM(w):000000000005d6f0=f846(°F); RealRAM(w):000000000005d6f0=f846(°F); Paged(w):0005d6f0=f846(°F)
Registers:
EIP: 000051a5 EFLAGS: 00007286
Previous CS:EIP: 373b:000051a4
BIU -- -
BIU -- S
BIU T1 - Paged(p):0003c595=21(!); Normal(p):000051e5=21(!); Paged(p):0003c596=3c(<); Normal(p):000051e6=3c(<); Paged(p):0003c597=02(☻); Normal(p):000051e7=02(☻); Paged(p):0003c598=73(s); Normal(p):000051e8=73(s)
BIU -- - 373b:000051a6 8D 46 F0 lea ax,word ss:[bp-10]
Registers:
EIP: 000051a6 EFLAGS: 00007286
Previous CS:EIP: 373b:000051a5
BIU -- -
BIU -- -
BIU -- -
BIU -- I
BIU -- - 373b:000051a9
BIU T1 - 373b:000051a9 MemoryBus(w):000000000005d6ee=eb(δ); RAM(w):000000000005d6ee=4deb(Mδ); RealRAM(w):000000000005d6ee=4deb(Mδ); Paged(w):0005d6ee=4deb(Mδ)
Registers:
EAX: 8000f85a EBX: 0000f83a ECX: 000012a6 EDX: 0000373b
EIP: 000051a9 EFLAGS: 00007286
Previous CS:EIP: 373b:000051a6
BIU -- - 373b:000051aa
BIU T1 - 373b:000051aa MemoryBus(w):000000000005d6ec=5a(Z); RAM(w):000000000005d6ec=f85a(°Z); RealRAM(w):000000000005d6ec=f85a(°Z); Paged(w):0005d6ec=f85a(°Z)
Registers:
ESP: 0000f83e EBP: 0000f86a ESI: 00000082 EDI: 00fff94d
EIP: 000051aa EFLAGS: 00007286
Previous CS:EIP: 373b:000051a9
BIU -- -
BIU -- S
BIU T1 - 373b:000051ab Paged(p):0003c599=02(☻); Normal(p):000051e9=02(☻); Paged(p):0003c59a=cd(═); Normal(p):000051ea=cd(═); Paged(p):0003c59b=20( ); Normal(p):000051eb=20( ); Paged(p):0003c59c=bf(┐); Normal(p):000051ec=bf(┐)
BIU T1 - 373b:000051ab MemoryBus(w):000000000005d6ea=3b(;); RAM(w):000000000005d6ea=373b(7;); RealRAM(w):000000000005d6ea=373b(7;); Paged(w):0005d6ea=373b(7;)
BIU T1 - 373b:000051ab MemoryBus(w):000000000005d6e8=b0(░); RAM(w):000000000005d6e8=51b0(Q░); RealRAM(w):000000000005d6e8=51b0(Q░); Paged(w):0005d6e8=51b0(Q░)
BIU -- - 373b:000051ab
BIU -- E 373b:000051ab 9A D6 44 3B 37 call 373b:000044d6
Registers:
EIP: 000051ab EFLAGS: 00007286
Previous CS:EIP: 373b:000051aa
BIU T1 - RealRAM(p):000000000003b886=8b55(ïU); RAM(p):000000000003b886=8b55(ïU); MemoryBus(p):000000000003b886=8b55(ïU); Paged(p):0003b886=55(U); Normal(p):000044d6=55(U); Paged(p):0003b887=8b(ï); Normal(p):000044d7=8b(ï); RealRAM(p):000000000003b888=000000000004b8ec(W▲╛Ü ♦╕∞); RAM(p):000000000003b888=000000000004b8ec(W▲╛Ü ♦╕∞); MemoryBus(p):000000000003b888=0004b8ec( ♦╕∞); Paged(p):0003b888=ec(∞); Normal(p):000044d8=ec(∞); Paged(p):0003b889=b8(╕); Normal(p):000044d9=b8(╕)
BIU T1 - Paged(p):0003b88a=04(♦); Normal(p):000044da=04(♦); Paged(p):0003b88b=00( ); Normal(p):000044db=00( ); Paged(p):0003b88c=9a(Ü); Normal(p):000044dc=9a(Ü); Paged(p):0003b88d=be(╛); Normal(p):000044dd=be(╛)
BIU T1 - Paged(p):0003b88e=1e(▲); Normal(p):000044de=1e(▲); Paged(p):0003b88f=57(W); Normal(p):000044df=57(W); MemoryBus(p):000000000003b890=ccbcb83c(╠╝╕<); Paged(p):0003b890=3c(<); Normal(p):000044e0=3c(<); Paged(p):0003b891=b8(╕); Normal(p):000044e1=b8(╕)
BIU T1 - Paged(p):0003b892=bc(╝); Normal(p):000044e2=bc(╝); Paged(p):0003b893=cc(╠); Normal(p):000044e3=cc(╠); Paged(p):0003b894=89(ë); Normal(p):000044e4=89(ë); Paged(p):0003b895=46(F); Normal(p):000044e5=46(F)
BIU T1 - Paged(p):0003b896=fc(ⁿ); Normal(p):000044e6=fc(ⁿ); Paged(p):0003b897=8c(î); Normal(p):000044e7=8c(î); Paged(p):0003b898=5e(^); Normal(p):000044e8=5e(^); Paged(p):0003b899=fe(■); Normal(p):000044e9=fe(■)
BIU T1 - Paged(p):0003b89a=1e(▲); Normal(p):000044ea=1e(▲); Paged(p):0003b89b=50(P); Normal(p):000044eb=50(P); Paged(p):0003b89c=9a(Ü); Normal(p):000044ec=9a(Ü); Paged(p):0003b89d=9c(£); Normal(p):000044ed=9c(£)
BIU T1 - Paged(p):0003b89e=12(↕); Normal(p):000044ee=12(↕); Paged(p):0003b89f=3b(;); Normal(p):000044ef=3b(;); MemoryBus(p):000000000003b8a0=04c48337(♦─â7); Paged(p):0003b8a0=37(7); Normal(p):000044f0=37(7); Paged(p):0003b8a1=83(â); Normal(p):000044f1=83(â)
BIU T1 - Paged(p):0003b8a2=c4(─); Normal(p):000044f2=c4(─); Paged(p):0003b8a3=04(♦); Normal(p):000044f3=04(♦); Paged(p):0003b8a4=ff( ); Normal(p):000044f4=ff( ); Paged(p):0003b8a5=76(v); Normal(p):000044f5=76(v)
BIU T1 - Paged(p):0003b8a6=0c(♀); Normal(p):000044f6=0c(♀); Paged(p):0003b8a7=ff( ); Normal(p):000044f7=ff( ); Paged(p):0003b8a8=76(v); Normal(p):000044f8=76(v); Paged(p):0003b8a9=0a( ); Normal(p):000044f9=0a( )
BIU T1 - Paged(p):0003b8aa=ff( ); Normal(p):000044fa=ff( ); Paged(p):0003b8ab=76(v); Normal(p):000044fb=76(v); Paged(p):0003b8ac=08(◘); Normal(p):000044fc=08(◘); Paged(p):0003b8ad=ff( ); Normal(p):000044fd=ff( )
BIU T1 - Paged(p):0003b8ae=76(v); Normal(p):000044fe=76(v); Paged(p):0003b8af=06(♠); Normal(p):000044ff=06(♠); MemoryBus(p):000000000003b8b0=500010b8(P ►╕); Paged(p):0003b8b0=b8(╕); Normal(p):00004500=b8(╕); Paged(p):0003b8b1=10(►); Normal(p):00004501=10(►)
BIU T1 - Paged(p):0003b8b2=00( ); Normal(p):00004502=00( ); Paged(p):0003b8b3=50(P); Normal(p):00004503=50(P); Paged(p):0003b8b4=9a(Ü); Normal(p):00004504=9a(Ü); Paged(p):0003b8b5=8e(Ä); Normal(p):00004505=8e(Ä)
BIU T1 - Paged(p):0003b8b6=43(C); Normal(p):00004506=43(C); Paged(p):0003b8b7=3b(;); Normal(p):00004507=3b(;); Paged(p):0003b8b8=37(7); Normal(p):00004508=37(7); Paged(p):0003b8b9=83(â); Normal(p):00004509=83(â)
BIU T1 - Paged(p):0003b8ba=c4(─); Normal(p):0000450a=c4(─); Paged(p):0003b8bb=0a( ); Normal(p):0000450b=0a( ); Paged(p):0003b8bc=ff( ); Normal(p):0000450c=ff( ); Paged(p):0003b8bd=76(v); Normal(p):0000450d=76(v)
BIU T1 - Paged(p):0003b8be=fe(■); Normal(p):0000450e=fe(■); Paged(p):0003b8bf=ff( ); Normal(p):0000450f=ff( ); MemoryBus(p):000000000003b8c0=c69afc76(╞Üⁿv); Paged(p):0003b8c0=76(v); Normal(p):00004510=76(v); Paged(p):0003b8c1=fc(ⁿ); Normal(p):00004511=fc(ⁿ)
BIU T1 - Paged(p):0003b8c2=9a(Ü); Normal(p):00004512=9a(Ü); Paged(p):0003b8c3=c6(╞); Normal(p):00004513=c6(╞); Paged(p):0003b8c4=12(↕); Normal(p):00004514=12(↕); Paged(p):0003b8c5=3b(;); Normal(p):00004515=3b(;)
BIU -- I
BIU -- - 373b:000044d6
BIU T1 - 373b:000044d6 MemoryBus(w):000000000005d6e6=6a(j); RAM(w):000000000005d6e6=f86a(°j); RealRAM(w):000000000005d6e6=f86a(°j); Paged(w):0005d6e6=f86a(°j)
Registers:
ESP: 0000f838 EBP: 0000f86a ESI: 00000082 EDI: 00fff94d
EIP: 000044d6 EFLAGS: 00007286
Previous CS:EIP: 373b:000051ab
BIU -- -
BIU -- S
BIU -- - 373b:000044d7 8B EC mov bp,sp
Registers:
ESP: 0000f836 EBP: 0000f86a ESI: 00000082 EDI: 00fff94d
EIP: 000044d7 EFLAGS: 00007286
Previous CS:EIP: 373b:000044d6
BIU -- -
BIU -- I
BIU T1 - Paged(p):0003b8c6=37(7); Normal(p):00004516=37(7); Paged(p):0003b8c7=8b(ï); Normal(p):00004517=8b(ï); Paged(p):0003b8c8=e5(σ); Normal(p):00004518=e5(σ); Paged(p):0003b8c9=5d(]); Normal(p):00004519=5d(])
BIU -- S
BIU -- - 373b:000044d9 B8 04 00 mov ax,0004
Registers:
ESP: 0000f836 EBP: 0000f836 ESI: 00000082 EDI: 00fff94d
EIP: 000044d9 EFLAGS: 00007286
Previous CS:EIP: 373b:000044d7
BIU -- -
BIU -- I
BIU -- -
BIU -- S
BIU T1 - 373b:000044dc Paged(p):0003b8ca=cb(╦); Normal(p):0000451a=cb(╦); Paged(p):0003b8cb=90(É); Normal(p):0000451b=90(É); Paged(p):0003b8cc=55(U); Normal(p):0000451c=55(U); Paged(p):0003b8cd=8b(ï); Normal(p):0000451d=8b(ï)
BIU T1 - 373b:000044dc MemoryBus(w):000000000005d6e4=3b(;); RAM(w):000000000005d6e4=373b(7;); RealRAM(w):000000000005d6e4=373b(7;); Paged(w):0005d6e4=373b(7;)
BIU T1 - 373b:000044dc MemoryBus(w):000000000005d6e2=e1(ß); RAM(w):000000000005d6e2=44e1(Dß); RealRAM(w):000000000005d6e2=44e1(Dß); Paged(w):0005d6e2=44e1(Dß)
BIU -- - 373b:000044dc
BIU -- E 373b:000044dc 9A BE 1E 57 3C call 3c57:00001ebe
Registers:
EAX: 80000004 EBX: 0000f83a ECX: 000012a6 EDX: 0000373b
EIP: 000044dc EFLAGS: 00007286
Previous CS:EIP: 373b:000044d9
BIU -- I
BIU T1 - 3c57:00001ebe RealRAM(r):000000000005d6e2=44e1(Dß); RAM(r):000000000005d6e2=44e1(Dß); MemoryBus(r):000000000005d6e2=44e1(Dß); Paged(r):0005d6e2=e1(ß); Paged(r):0005d6e3=44(D)
Registers:
ESP: 0000f832 EBP: 0000f836 ESI: 00000082 EDI: 00fff94d
EIP: 00001ebe EFLAGS: 00007286
Previous CS:EIP: 373b:000044dc
BIU -- -
BIU -- I
BIU T1 - 3c57:00001ebf RealRAM(r):000000000005d6e4=f86a373b(°j7;); RAM(r):000000000005d6e4=f86a373b(°j7;); MemoryBus(r):000000000005d6e4=f86a373b(°j7;); Paged(r):0005d6e4=3b(;); Paged(r):0005d6e5=37(7)
Registers:
EAX: 80000004 EBX: 0000f83a ECX: 000044e1 EDX: 0000373b
ESP: 0000f834 EBP: 0000f836 ESI: 00000082 EDI: 00fff94d
EIP: 00001ebf EFLAGS: 00007286
BIU -- -
BIU -- I
BIU -- -
BIU -- S
Registers:
EIP: 00001ec0 EFLAGS: 00007286
BIU -- -
BIU -- I
BIU -- -
BIU -- S
Registers:
EAX: 80000004 EBX: 0000f836 ECX: 000044e1 EDX: 0000373b
EIP: 00001ec2 EFLAGS: 00007286
BIU -- -
BIU -- I
BIU -- -
BIU -- S
Registers:
EAX: 80000004 EBX: 0000f832 ECX: 000044e1 EDX: 0000373b
EIP: 00001ec4 EFLAGS: 00007282
FLAGSINFO: 0000000000ipfavr0N11odItSz0a0p1c
BIU -- -
BIU -- -
BIU -- I
BIU -- -
BIU -- S
Registers:
EIP: 00001ec6 EFLAGS: 00007282
BIU -- -
BIU -- S
Registers:
EIP: 00001eca EFLAGS: 00007206
FLAGSINFO: 0000000000ipfavr0N11odItsz0a0P1c
BIU -- -
BIU -- -
BIU -- I
BIU -- -
BIU -- S
Registers:
EIP: 00001ecc EFLAGS: 00007206
BIU -- -
BIU -- I
BIU T1 - 3c57:00001ece MemoryBus(w):000000000005d6e0=3b(;); RAM(w):000000000005d6e0=373b(7;); RealRAM(w):000000000005d6e0=373b(7;); Paged(w):0005d6e0=373b(7;)
Registers:
EIP: 00001ece EFLAGS: 00007206
BIU -- -
BIU -- I
BIU T1 - 3c57:00001ecf MemoryBus(w):000000000005d6de=e1(ß); RAM(w):000000000005d6de=44e1(Dß); RealRAM(w):000000000005d6de=44e1(Dß); Paged(w):0005d6de=44e1(Dß)
Registers:
ESP: 0000f830 EBP: 0000f836 ESI: 00000082 EDI: 00fff94d
EIP: 00001ecf EFLAGS: 00007206
BIU -- -
BIU -- I
BIU T1 - 3c57:00001ed0 RealRAM(r):000000000005d6de=44e1(Dß); RAM(r):000000000005d6de=44e1(Dß); MemoryBus(r):000000000005d6de=44e1(Dß); Paged(r):0005d6de=e1(ß); Paged(r):0005d6df=44(D)
BIU T1 - 3c57:00001ed0 MemoryBus(r):000000000005d6e0=44e1373b(Dß7;); Paged(r):0005d6e0=3b(;); Paged(r):0005d6e1=37(7)
Registers:
ESP: 0000f82e EBP: 0000f836 ESI: 00000082 EDI: 00fff94d
EIP: 00001ed0 EFLAGS: 00007206
BIU T1 - Paged(p):0003b891=b8(╕); Normal(p):000044e1=b8(╕); Paged(p):0003b892=bc(╝); Normal(p):000044e2=bc(╝); Paged(p):0003b893=cc(╠); Normal(p):000044e3=cc(╠); Paged(p):0003b894=89(ë); Normal(p):000044e4=89(ë)
BIU T1 - Paged(p):0003b895=46(F); Normal(p):000044e5=46(F); Paged(p):0003b896=fc(ⁿ); Normal(p):000044e6=fc(ⁿ); Paged(p):0003b897=8c(î); Normal(p):000044e7=8c(î); Paged(p):0003b898=5e(^); Normal(p):000044e8=5e(^)
BIU T1 - Paged(p):0003b899=fe(■); Normal(p):000044e9=fe(■); Paged(p):0003b89a=1e(▲); Normal(p):000044ea=1e(▲); Paged(p):0003b89b=50(P); Normal(p):000044eb=50(P); Paged(p):0003b89c=9a(Ü); Normal(p):000044ec=9a(Ü)
BIU T1 - Paged(p):0003b89d=9c(£); Normal(p):000044ed=9c(£); Paged(p):0003b89e=12(↕); Normal(p):000044ee=12(↕); Paged(p):0003b89f=3b(;); Normal(p):000044ef=3b(;); MemoryBus(p):000000000003b8a0=04c48337(♦─â7); Paged(p):0003b8a0=37(7); Normal(p):000044f0=37(7)
BIU T1 - Paged(p):0003b8a1=83(â); Normal(p):000044f1=83(â); Paged(p):0003b8a2=c4(─); Normal(p):000044f2=c4(─); Paged(p):0003b8a3=04(♦); Normal(p):000044f3=04(♦); Paged(p):0003b8a4=ff( ); Normal(p):000044f4=ff( )
BIU T1 - Paged(p):0003b8a5=76(v); Normal(p):000044f5=76(v); Paged(p):0003b8a6=0c(♀); Normal(p):000044f6=0c(♀); Paged(p):0003b8a7=ff( ); Normal(p):000044f7=ff( ); Paged(p):0003b8a8=76(v); Normal(p):000044f8=76(v)
BIU T1 - Paged(p):0003b8a9=0a( ); Normal(p):000044f9=0a( ); Paged(p):0003b8aa=ff( ); Normal(p):000044fa=ff( ); Paged(p):0003b8ab=76(v); Normal(p):000044fb=76(v); Paged(p):0003b8ac=08(◘); Normal(p):000044fc=08(◘)
BIU T1 - Paged(p):0003b8ad=ff( ); Normal(p):000044fd=ff( ); Paged(p):0003b8ae=76(v); Normal(p):000044fe=76(v); Paged(p):0003b8af=06(♠); Normal(p):000044ff=06(♠); MemoryBus(p):000000000003b8b0=500010b8(P ►╕); Paged(p):0003b8b0=b8(╕); Normal(p):00004500=b8(╕)
BIU T1 - Paged(p):0003b8b1=10(►); Normal(p):00004501=10(►); Paged(p):0003b8b2=00( ); Normal(p):00004502=00( ); Paged(p):0003b8b3=50(P); Normal(p):00004503=50(P); Paged(p):0003b8b4=9a(Ü); Normal(p):00004504=9a(Ü)
BIU T1 - Paged(p):0003b8b5=8e(Ä); Normal(p):00004505=8e(Ä); Paged(p):0003b8b6=43(C); Normal(p):00004506=43(C); Paged(p):0003b8b7=3b(;); Normal(p):00004507=3b(;); Paged(p):0003b8b8=37(7); Normal(p):00004508=37(7)
BIU T1 - Paged(p):0003b8b9=83(â); Normal(p):00004509=83(â); Paged(p):0003b8ba=c4(─); Normal(p):0000450a=c4(─); Paged(p):0003b8bb=0a( ); Normal(p):0000450b=0a( ); Paged(p):0003b8bc=ff( ); Normal(p):0000450c=ff( )
BIU T1 - Paged(p):0003b8bd=76(v); Normal(p):0000450d=76(v); Paged(p):0003b8be=fe(■); Normal(p):0000450e=fe(■); Paged(p):0003b8bf=ff( ); Normal(p):0000450f=ff( ); MemoryBus(p):000000000003b8c0=c69afc76(╞Üⁿv); Paged(p):0003b8c0=76(v); Normal(p):00004510=76(v)
BIU T1 - Paged(p):0003b8c1=fc(ⁿ); Normal(p):00004511=fc(ⁿ); Paged(p):0003b8c2=9a(Ü); Normal(p):00004512=9a(Ü); Paged(p):0003b8c3=c6(╞); Normal(p):00004513=c6(╞); Paged(p):0003b8c4=12(↕); Normal(p):00004514=12(↕)
BIU T1 I Paged(p):0003b8c5=3b(;); Normal(p):00004515=3b(;); Paged(p):0003b8c6=37(7); Normal(p):00004516=37(7); Paged(p):0003b8c7=8b(ï); Normal(p):00004517=8b(ï); Paged(p):0003b8c8=e5(σ); Normal(p):00004518=e5(σ)
BIU T1 - Paged(p):0003b8c9=5d(]); Normal(p):00004519=5d(]); Paged(p):0003b8ca=cb(╦); Normal(p):0000451a=cb(╦); Paged(p):0003b8cb=90(É); Normal(p):0000451b=90(É); Paged(p):0003b8cc=55(U); Normal(p):0000451c=55(U)
BIU T1 S Paged(p):0003b8cd=8b(ï); Normal(p):0000451d=8b(ï); Paged(p):0003b8ce=ec(∞); Normal(p):0000451e=ec(∞); Paged(p):0003b8cf=b8(╕); Normal(p):0000451f=b8(╕); MemoryBus(p):000000000003b8d0=be9a0008(╛Ü ◘); Paged(p):0003b8d0=08(◘); Normal(p):00004520=08(◘)
BIU -- - 373b:000044e1 B8 BC CC mov ax,ccbc
Registers:
EIP: 000044e1 EFLAGS: 00007206
BIU -- -
BIU -- I
BIU T1 - Paged(p):0003b8d1=00( ); Normal(p):00004521=00( ); Paged(p):0003b8d2=9a(Ü); Normal(p):00004522=9a(Ü); Paged(p):0003b8d3=be(╛); Normal(p):00004523=be(╛); Paged(p):0003b8d4=1e(▲); Normal(p):00004524=1e(▲)
BIU -- S
BIU -- -
BIU -- - 373b:000044e4
BIU T1 - 373b:000044e4 MemoryBus(w):000000000005d6e2=bc(╝); RAM(w):000000000005d6e2=ccbc(╠╝); RealRAM(w):000000000005d6e2=ccbc(╠╝); Paged(w):0005d6e2=ccbc(╠╝)
Registers:
EAX: 8000ccbc EBX: 0000f832 ECX: 000044e1 EDX: 0000373b
EIP: 000044e4 EFLAGS: 00007206
Previous CS:EIP: 373b:000044e1
BIU -- I ^ 89 46 FC mov word ss:[bp-04],ax
BIU -- -
BIU -- S
BIU T1 - Paged(p):0003b8d5=57(W); Normal(p):00004525=57(W); Paged(p):0003b8d6=3c(<); Normal(p):00004526=3c(<); Paged(p):0003b8d7=c7(╟); Normal(p):00004527=c7(╟); Paged(p):0003b8d8=46(F); Normal(p):00004528=46(F)
BIU -- - 373b:000044e7
BIU T1 - 373b:000044e7 MemoryBus(w):000000000005d6e4=eb(δ); RAM(w):000000000005d6e4=4deb(Mδ); RealRAM(w):000000000005d6e4=4deb(Mδ); Paged(w):0005d6e4=4deb(Mδ)
Registers:
EIP: 000044e7 EFLAGS: 00007206
Previous CS:EIP: 373b:000044e4
BIU -- I ^ 8C 5E FE mov word ss:[bp-02],ds
BIU -- - 373b:000044ea
BIU T1 - 373b:000044ea MemoryBus(w):000000000005d6e0=eb(δ); RAM(w):000000000005d6e0=4deb(Mδ); RealRAM(w):000000000005d6e0=4deb(Mδ); Paged(w):0005d6e0=4deb(Mδ)
Registers:
EIP: 000044ea EFLAGS: 00007206
Previous CS:EIP: 373b:000044e7
BIU -- - 373b:000044eb
BIU T1 - 373b:000044eb MemoryBus(w):000000000005d6de=bc(╝); RAM(w):000000000005d6de=ccbc(╠╝); RealRAM(w):000000000005d6de=ccbc(╠╝); Paged(w):0005d6de=ccbc(╠╝)
Registers:
EIP: 000044eb EFLAGS: 00007206
Previous CS:EIP: 373b:000044ea
BIU T1 - Paged(p):0003b8d9=f8(°); Normal(p):00004529=f8(°); Paged(p):0003b8da=01(☺); Normal(p):0000452a=01(☺); Paged(p):0003b8db=00( ); Normal(p):0000452b=00( ); Paged(p):0003b8dc=b8(╕); Normal(p):0000452c=b8(╕)
BIU T1 S Paged(p):0003b8dd=c4(─); Normal(p):0000452d=c4(─); Paged(p):0003b8de=cc(╠); Normal(p):0000452e=cc(╠); Paged(p):0003b8df=89(ë); Normal(p):0000452f=89(ë); MemoryBus(p):000000000003b8e0=5e8cfa46(^î·F); Paged(p):0003b8e0=46(F); Normal(p):00004530=46(F)
BIU -- - 373b:000044ec
BIU T1 - 373b:000044ec MemoryBus(w):000000000005d6dc=3b(;); RAM(w):000000000005d6dc=373b(7;); RealRAM(w):000000000005d6dc=373b(7;); Paged(w):0005d6dc=373b(7;)
BIU T1 - 373b:000044ec MemoryBus(w):000000000005d6da=f1(±); RAM(w):000000000005d6da=44f1(D±); RealRAM(w):000000000005d6da=44f1(D±); Paged(w):0005d6da=44f1(D±)
BIU -- E 373b:000044ec 9A 9C 12 3B 37 call 373b:0000129c
Registers:
EIP: 000044ec EFLAGS: 00007206
Previous CS:EIP: 373b:000044eb
BIU -- I
BIU T1 - 373b:0000129c MemoryBus(w):000000000005d6d8=36(6); RAM(w):000000000005d6d8=f836(°6); RealRAM(w):000000000005d6d8=f836(°6); Paged(w):0005d6d8=f836(°6)
Registers:
ESP: 0000f82a EBP: 0000f836 ESI: 00000082 EDI: 00fff94d
EIP: 0000129c EFLAGS: 00007206
Previous CS:EIP: 373b:000044ec
BIU -- -
BIU -- S
Registers:
ESP: 0000f828 EBP: 0000f836 ESI: 00000082 EDI: 00fff94d
EIP: 0000129d EFLAGS: 00007206
BIU -- -
BIU -- I
BIU -- S
Registers:
ESP: 0000f828 EBP: 0000f828 ESI: 00000082 EDI: 00fff94d
EIP: 0000129f EFLAGS: 00007206
BIU -- -
BIU -- I
BIU -- -
BIU -- S
BIU T1 - 373b:000012a1 MemoryBus(w):000000000005d6d6=3b(;); RAM(w):000000000005d6d6=373b(7;); RealRAM(w):000000000005d6d6=373b(7;); Paged(w):0005d6d6=373b(7;)
BIU T1 - 373b:000012a1 MemoryBus(w):000000000005d6d4=a6(ª); RAM(w):000000000005d6d4=12a6(↕ª); RealRAM(w):000000000005d6d4=12a6(↕ª); Paged(w):0005d6d4=12a6(↕ª)
Registers:
EAX: 80000000 EBX: 0000f832 ECX: 000044e1 EDX: 0000373b
FLAGSINFO: 0000000000ipfavr0N11odItsZ0a0P1c
BIU -- I
BIU T1 - 3c57:00001ebe RealRAM(r):000000000005d6d4=373b12a6(7;↕ª); RAM(r):000000000005d6d4=373b12a6(7;↕ª); MemoryBus(r):000000000005d6d4=373b12a6(7;↕ª); Paged(r):0005d6d4=a6(ª); Paged(r):0005d6d5=12(↕)
Registers:
ESP: 0000f824 EBP: 0000f828 ESI: 00000082 EDI: 00fff94d
BIU -- -
BIU -- I
BIU T1 - 3c57:00001ebf Paged(r):0005d6d6=3b(;); Paged(r):0005d6d7=37(7)
Registers:
EAX: 80000000 EBX: 0000f832 ECX: 000012a6 EDX: 0000373b
ESP: 0000f826 EBP: 0000f828 ESI: 00000082 EDI: 00fff94d
BIU -- -
BIU -- I
BIU -- -
BIU -- S
Registers:
BIU -- -
BIU -- I
BIU -- -
BIU -- S
Registers:
EAX: 80000000 EBX: 0000f828 ECX: 000012a6 EDX: 0000373b
BIU -- -
BIU -- I
BIU -- -
BIU -- S
Registers:
BIU -- -
BIU -- -
BIU -- I
BIU -- -
BIU -- S
Registers:
BIU -- -
BIU -- S
Registers:
BIU -- -
BIU -- -
BIU -- I
BIU -- -
BIU -- S
Registers:
BIU -- -
BIU -- I
BIU T1 - 3c57:00001ece MemoryBus(w):000000000005d6d6=3b(;); RAM(w):000000000005d6d6=373b(7;); RealRAM(w):000000000005d6d6=373b(7;); Paged(w):0005d6d6=373b(7;)
Registers:
BIU -- -
BIU -- I
BIU T1 - 3c57:00001ecf MemoryBus(w):000000000005d6d4=a6(ª); RAM(w):000000000005d6d4=12a6(↕ª); RealRAM(w):000000000005d6d4=12a6(↕ª); Paged(w):0005d6d4=12a6(↕ª)
Registers:
BIU -- -
BIU -- I
BIU T1 - 3c57:00001ed0 RealRAM(r):000000000005d6d4=373b12a6(7;↕ª); RAM(r):000000000005d6d4=373b12a6(7;↕ª); MemoryBus(r):000000000005d6d4=373b12a6(7;↕ª); Paged(r):0005d6d4=a6(ª); Paged(r):0005d6d5=12(↕)
BIU T1 - 3c57:00001ed0 Paged(r):0005d6d6=3b(;); Paged(r):0005d6d7=37(7)
Registers:
Registers:
EIP: 000012a6 EFLAGS: 00007206
BIU -- -
BIU -- -
BIU -- I
BIU -- -
BIU -- -
BIU -- S
BIU -- -
BIU -- -
BIU T1 - 373b:000012aa Paged(r):0004dff6=00( ); Paged(r):0004dff7=00( )
Registers:
EIP: 000012aa EFLAGS: 00007206
BIU -- -
BIU -- -
BIU -- -
BIU -- I
BIU -- -
BIU -- S
Registers:
BIU T1 - 373b:000012c4 RealRAM(r):000000000005d6d8=0000000044f1f836(╠╝7;D±°6); RAM(r):000000000005d6d8=0000000044f1f836(╠╝7;D±°6); MemoryBus(r):000000000005d6d8=44f1f836(D±°6); Paged(r):0005d6d8=36(6); Paged(r):0005d6d9=f8(°)
Registers:
BIU T1 - 373b:000012c5 Paged(r):0005d6da=f1(±); Paged(r):0005d6db=44(D)
BIU T1 - 373b:000012c5 Paged(r):0005d6dc=3b(;); Paged(r):0005d6dd=37(7)
Registers:
BIU T1 - RealRAM(p):000000000003b8a1=83(â); RAM(p):000000000003b8a1=83(â); MemoryBus(p):000000000003b8a1=83(â); Paged(p):0003b8a1=83(â); Normal(p):000044f1=83(â); RealRAM(p):000000000003b8a2=04c4(♦─); RAM(p):000000000003b8a2=04c4(♦─); MemoryBus(p):000000000003b8a2=04c4(♦─); Paged(p):0003b8a2=c4(─); Normal(p):000044f2=c4(─); Paged(p):0003b8a3=04(♦); Normal(p):000044f3=04(♦); RealRAM(p):000000000003b8a4=ff0c76ff( ♀v ); RAM(p):000000000003b8a4=ff0c76ff( ♀v ); MemoryBus(p):000000000003b8a4=ff0c76ff( ♀v ); Paged(p):0003b8a4=ff( ); Normal(p):000044f4=ff( )
BIU T1 - Paged(p):0003b8a5=76(v); Normal(p):000044f5=76(v); Paged(p):0003b8a6=0c(♀); Normal(p):000044f6=0c(♀); Paged(p):0003b8a7=ff( ); Normal(p):000044f7=ff( ); RealRAM(p):000000000003b8a8=0000000076ff0a76(♠v ◘v  v); RAM(p):000000000003b8a8=0000000076ff0a76(♠v ◘v  v); MemoryBus(p):000000000003b8a8=76ff0a76(v  v); Paged(p):0003b8a8=76(v); Normal(p):000044f8=76(v)
BIU T1 - Paged(p):0003b8c5=3b(;); Normal(p):00004515=3b(;); Paged(p):0003b8c6=37(7); Normal(p):00004516=37(7); Paged(p):0003b8c7=8b(ï); Normal(p):00004517=8b(ï); Paged(p):0003b8c8=e5(σ); Normal(p):00004518=e5(σ)
BIU T1 - Paged(p):0003b8cd=8b(ï); Normal(p):0000451d=8b(ï); Paged(p):0003b8ce=ec(∞); Normal(p):0000451e=ec(∞); Paged(p):0003b8cf=b8(╕); Normal(p):0000451f=b8(╕); MemoryBus(p):000000000003b8d0=be9a0008(╛Ü ◘); Paged(p):0003b8d0=08(◘); Normal(p):00004520=08(◘)
BIU T1 I Paged(p):0003b8d5=57(W); Normal(p):00004525=57(W); Paged(p):0003b8d6=3c(<); Normal(p):00004526=3c(<); Paged(p):0003b8d7=c7(╟); Normal(p):00004527=c7(╟); Paged(p):0003b8d8=46(F); Normal(p):00004528=46(F)
BIU -- -
BIU -- - 373b:000044f1 83 C4 04 add sp,0004
Registers:
EIP: 000044f1 EFLAGS: 00007297
BIU -- -
BIU -- -
BIU -- I
BIU T1 - Paged(p):0003b8e1=fa(·); Normal(p):00004531=fa(·); Paged(p):0003b8e2=8c(î); Normal(p):00004532=8c(î); Paged(p):0003b8e3=5e(^); Normal(p):00004533=5e(^); Paged(p):0003b8e4=fc(ⁿ); Normal(p):00004534=fc(ⁿ)
BIU -- S
BIU -- -
BIU -- - 373b:000044f4
BIU T1 - 373b:000044f4 RealRAM(r):000000000005d6f2=4deb(Mδ); RAM(r):000000000005d6f2=4deb(Mδ); MemoryBus(r):000000000005d6f2=4deb(Mδ); Paged(r):0005d6f2=eb(δ); Paged(r):0005d6f3=4d(M)
BIU T1 - 373b:000044f4 MemoryBus(w):000000000005d6e0=eb(δ); RAM(w):000000000005d6e0=4deb(Mδ); RealRAM(w):000000000005d6e0=4deb(Mδ); Paged(w):0005d6e0=4deb(Mδ)
BIU -- - 373b:000044f4 FF 76 0C push word ss:[bp+0c]
Registers:
EIP: 000044f4 EFLAGS: 00007292
Previous CS:EIP: 373b:000044f1
FLAGSINFO: 0000000000ipfavr0N11odItSz0A0p1c
BIU -- I
BIU -- -
BIU -- S
BIU T1 - Paged(p):0003b8e5=1e(▲); Normal(p):00004535=1e(▲); Paged(p):0003b8e6=50(P); Normal(p):00004536=50(P); Paged(p):0003b8e7=9a(Ü); Normal(p):00004537=9a(Ü); Paged(p):0003b8e8=9c(£); Normal(p):00004538=9c(£)
BIU -- - 373b:000044f7
BIU T1 - 373b:000044f7 MemoryBus(r):000000000005d6f0=4debf846(Mδ°F); Paged(r):0005d6f0=46(F); Paged(r):0005d6f1=f8(°)
BIU T1 - 373b:000044f7 MemoryBus(w):000000000005d6de=46(F); RAM(w):000000000005d6de=f846(°F); RealRAM(w):000000000005d6de=f846(°F); Paged(w):0005d6de=f846(°F)
BIU -- - 373b:000044f7 FF 76 0A push word ss:[bp+0a]
Registers:
EIP: 000044f7 EFLAGS: 00007292
Previous CS:EIP: 373b:000044f4
BIU -- I
BIU -- -
BIU -- S
BIU T1 - Paged(p):0003b8e9=12(↕); Normal(p):00004539=12(↕); Paged(p):0003b8ea=3b(;); Normal(p):0000453a=3b(;); Paged(p):0003b8eb=37(7); Normal(p):0000453b=37(7); Paged(p):0003b8ec=83(â); Normal(p):0000453c=83(â)
BIU -- - 373b:000044fa
BIU T1 - 373b:000044fa RealRAM(r):000000000005d6ee=4deb(Mδ); RAM(r):000000000005d6ee=4deb(Mδ); MemoryBus(r):000000000005d6ee=4deb(Mδ); Paged(r):0005d6ee=eb(δ); Paged(r):0005d6ef=4d(M)
BIU T1 - 373b:000044fa MemoryBus(w):000000000005d6dc=eb(δ); RAM(w):000000000005d6dc=4deb(Mδ); RealRAM(w):000000000005d6dc=4deb(Mδ); Paged(w):0005d6dc=4deb(Mδ)
BIU -- - 373b:000044fa FF 76 08 push word ss:[bp+08]
Registers:
EIP: 000044fa EFLAGS: 00007292
Previous CS:EIP: 373b:000044f7
BIU -- I
BIU -- -
BIU -- S
BIU -- -
BIU -- - 373b:000044fd
BIU T1 - 373b:000044fd RealRAM(r):000000000005d6ec=4debf85a(Mδ°Z); RAM(r):000000000005d6ec=4debf85a(Mδ°Z); MemoryBus(r):000000000005d6ec=4debf85a(Mδ°Z); Paged(r):0005d6ec=5a(Z); Paged(r):0005d6ed=f8(°)
BIU T1 - 373b:000044fd MemoryBus(w):000000000005d6da=5a(Z); RAM(w):000000000005d6da=f85a(°Z); RealRAM(w):000000000005d6da=f85a(°Z); Paged(w):0005d6da=f85a(°Z)
BIU -- - 373b:000044fd FF 76 06 push word ss:[bp+06]
Registers:
ESP: 0000f82c EBP: 0000f836 ESI: 00000082 EDI: 00fff94d
EIP: 000044fd EFLAGS: 00007292
Previous CS:EIP: 373b:000044fa
BIU -- I
BIU T1 - Paged(p):0003b8ed=c4(─); Normal(p):0000453d=c4(─); Paged(p):0003b8ee=04(♦); Normal(p):0000453e=04(♦); Paged(p):0003b8ef=c4(─); Normal(p):0000453f=c4(─); MemoryBus(p):000000000003b8f0=8b26065e(ï&♠^); Paged(p):0003b8f0=5e(^); Normal(p):00004540=5e(^)
BIU -- S
BIU -- - 373b:00004500 B8 10 00 mov ax,0010
Registers:
EIP: 00004500 EFLAGS: 00007292
Previous CS:EIP: 373b:000044fd
BIU -- -
BIU -- I
BIU -- - 373b:00004503
BIU T1 - 373b:00004503 MemoryBus(w):000000000005d6d8=10(►); RAM(w):000000000005d6d8=0010( ►); RealRAM(w):000000000005d6d8=0010( ►); Paged(w):0005d6d8=0010( ►)
Registers:
EAX: 80000010 EBX: 0000f828 ECX: 000012a6 EDX: 0000373b
EIP: 00004503 EFLAGS: 00007292
Previous CS:EIP: 373b:00004500
BIU T1 - Paged(p):0003b8f1=06(♠); Normal(p):00004541=06(♠); Paged(p):0003b8f2=26(&); Normal(p):00004542=26(&); Paged(p):0003b8f3=8b(ï); Normal(p):00004543=8b(ï); Paged(p):0003b8f4=47(G); Normal(p):00004544=47(G)
BIU T1 S Paged(p):0003b8f5=0a( ); Normal(p):00004545=0a( ); Paged(p):0003b8f6=26(&); Normal(p):00004546=26(&); Paged(p):0003b8f7=2b(+); Normal(p):00004547=2b(+); Paged(p):0003b8f8=47(G); Normal(p):00004548=47(G)
BIU -- - 373b:00004504
BIU T1 - 373b:00004504 MemoryBus(w):000000000005d6d6=3b(;); RAM(w):000000000005d6d6=373b(7;); RealRAM(w):000000000005d6d6=373b(7;); Paged(w):0005d6d6=373b(7;)
BIU T1 - 373b:00004504 MemoryBus(w):000000000005d6d4=09( ); RAM(w):000000000005d6d4=4509(E ); RealRAM(w):000000000005d6d4=4509(E ); Paged(w):0005d6d4=4509(E )
BIU -- E 373b:00004504 9A 8E 43 3B 37 call 373b:0000438e
Registers:
EIP: 00004504 EFLAGS: 00007292
Previous CS:EIP: 373b:00004503
BIU T1 - RealRAM(p):000000000003b73e=8b55(ïU); RAM(p):000000000003b73e=8b55(ïU); MemoryBus(p):000000000003b73e=8b55(ïU); Paged(p):0003b73e=55(U); Normal(p):0000438e=55(U); Paged(p):0003b73f=8b(ï); Normal(p):0000438f=8b(ï); MemoryBus(p):000000000003b740=eb5657ec(δVW∞); Paged(p):0003b740=ec(∞); Normal(p):00004390=ec(∞); Paged(p):0003b741=57(W); Normal(p):00004391=57(W)
BIU T1 - Paged(p):0003b742=56(V); Normal(p):00004392=56(V); Paged(p):0003b743=eb(δ); Normal(p):00004393=eb(δ); Paged(p):0003b744=03(♥); Normal(p):00004394=03(♥); Paged(p):0003b745=90(É); Normal(p):00004395=90(É)
BIU T1 - Paged(p):0003b746=00( ); Normal(p):00004396=00( ); Paged(p):0003b747=00( ); Normal(p):00004397=00( ); Paged(p):0003b748=06(♠); Normal(p):00004398=06(♠); Paged(p):0003b749=2e(.); Normal(p):00004399=2e(.)
BIU T1 - Paged(p):0003b74a=8c(î); Normal(p):0000439a=8c(î); Paged(p):0003b74b=1e(▲); Normal(p):0000439b=1e(▲); Paged(p):0003b74c=96(û); Normal(p):0000439c=96(û); Paged(p):0003b74d=43(C); Normal(p):0000439d=43(C)
BIU T1 - Paged(p):0003b74e=8a(è); Normal(p):0000439e=8a(è); Paged(p):0003b74f=46(F); Normal(p):0000439f=46(F); MemoryBus(p):000000000003b750=43cfbb06(C╧╗♠); Paged(p):0003b750=06(♠); Normal(p):000043a0=06(♠); Paged(p):0003b751=bb(╗); Normal(p):000043a1=bb(╗)
BIU T1 - Paged(p):0003b752=cf(╧); Normal(p):000043a2=cf(╧); Paged(p):0003b753=43(C); Normal(p):000043a3=43(C); Paged(p):0003b754=2e(.); Normal(p):000043a4=2e(.); Paged(p):0003b755=88(ê); Normal(p):000043a5=88(ê)
BIU T1 - Paged(p):0003b756=47(G); Normal(p):000043a6=47(G); Paged(p):0003b757=01(☺); Normal(p):000043a7=01(☺); Paged(p):0003b758=c4(─); Normal(p):000043a8=c4(─); Paged(p):0003b759=76(v); Normal(p):000043a9=76(v)
BIU T1 - Paged(p):0003b75a=08(◘); Normal(p):000043aa=08(◘); Paged(p):0003b75b=26(&); Normal(p):000043ab=26(&); Paged(p):0003b75c=8b(ï); Normal(p):000043ac=8b(ï); Paged(p):0003b75d=04(♦); Normal(p):000043ad=04(♦)
BIU T1 - Paged(p):0003b75e=26(&); Normal(p):000043ae=26(&); Paged(p):0003b75f=8b(ï); Normal(p):000043af=8b(ï); MemoryBus(p):000000000003b760=8b26025c(ï&☻\); Paged(p):0003b760=5c(\); Normal(p):000043b0=5c(\); Paged(p):0003b761=02(☻); Normal(p):000043b1=02(☻)
BIU T1 - Paged(p):0003b762=26(&); Normal(p):000043b2=26(&); Paged(p):0003b763=8b(ï); Normal(p):000043b3=8b(ï); Paged(p):0003b764=4c(L); Normal(p):000043b4=4c(L); Paged(p):0003b765=04(♦); Normal(p):000043b5=04(♦)
BIU T1 - Paged(p):0003b766=26(&); Normal(p):000043b6=26(&); Paged(p):0003b767=8b(ï); Normal(p):000043b7=8b(ï); Paged(p):0003b768=54(T); Normal(p):000043b8=54(T); Paged(p):0003b769=06(♠); Normal(p):000043b9=06(♠)
BIU T1 - Paged(p):0003b76a=50(P); Normal(p):000043ba=50(P); Paged(p):0003b76b=26(&); Normal(p):000043bb=26(&); Paged(p):0003b76c=8b(ï); Normal(p):000043bc=8b(ï); Paged(p):0003b76d=44(D); Normal(p):000043bd=44(D)
BIU T1 - Paged(p):0003b76e=08(◘); Normal(p):000043be=08(◘); Paged(p):0003b76f=26(&); Normal(p):000043bf=26(&); MemoryBus(p):000000000003b770=260a7c8b(& |ï); Paged(p):0003b770=8b(ï); Normal(p):000043c0=8b(ï); Paged(p):0003b771=7c(|); Normal(p):000043c1=7c(|)
BIU T1 - Paged(p):0003b772=0a( ); Normal(p):000043c2=0a( ); Paged(p):0003b773=26(&); Normal(p):000043c3=26(&); Paged(p):0003b774=8e(Ä); Normal(p):000043c4=8e(Ä); Paged(p):0003b775=5c(\); Normal(p):000043c5=5c(\)
BIU T1 - Paged(p):0003b776=0e(♫); Normal(p):000043c6=0e(♫); Paged(p):0003b777=26(&); Normal(p):000043c7=26(&); Paged(p):0003b778=8e(Ä); Normal(p):000043c8=8e(Ä); Paged(p):0003b779=44(D); Normal(p):000043c9=44(D)
BIU T1 - Paged(p):0003b77a=0c(♀); Normal(p):000043ca=0c(♀); Paged(p):0003b77b=8b(ï); Normal(p):000043cb=8b(ï); Paged(p):0003b77c=f0(≡); Normal(p):000043cc=f0(≡); Paged(p):0003b77d=58(X); Normal(p):000043cd=58(X)
BIU -- I
BIU -- - 373b:0000438e
BIU T1 - 373b:0000438e MemoryBus(w):000000000005d6d2=36(6); RAM(w):000000000005d6d2=f836(°6); RealRAM(w):000000000005d6d2=f836(°6); Paged(w):0005d6d2=f836(°6)
Registers:
ESP: 0000f824 EBP: 0000f836 ESI: 00000082 EDI: 00fff94d
EIP: 0000438e EFLAGS: 00007292
Previous CS:EIP: 373b:00004504
BIU -- -
BIU -- S
BIU -- - 373b:0000438f 8B EC mov bp,sp
Registers:
ESP: 0000f822 EBP: 0000f836 ESI: 00000082 EDI: 00fff94d
EIP: 0000438f EFLAGS: 00007292
Previous CS:EIP: 373b:0000438e
BIU -- -
BIU -- I
BIU T1 - 373b:00004391 Paged(p):0003b77e=55(U); Normal(p):000043ce=55(U); Paged(p):0003b77f=cd(═); Normal(p):000043cf=cd(═); MemoryBus(p):000000000003b780=2e1e5d00(.▲] ); Paged(p):0003b780=00( ); Normal(p):000043d0=00( ); Paged(p):0003b781=5d(]); Normal(p):000043d1=5d(])
BIU -- - 373b:00004391
BIU T1 - 373b:00004391 MemoryBus(w):000000000005d6d0=4d(M); RAM(w):000000000005d6d0=f94d(∙M); RealRAM(w):000000000005d6d0=f94d(∙M); Paged(w):0005d6d0=f94d(∙M)
BIU -- - 373b:00004391 57 push di
Registers:
ESP: 0000f822 EBP: 0000f822 ESI: 00000082 EDI: 00fff94d
EIP: 00004391 EFLAGS: 00007292
Previous CS:EIP: 373b:0000438f
BIU -- -
BIU -- I
BIU -- - 373b:00004392
BIU T1 - 373b:00004392 MemoryBus(w):000000000005d6ce=82(é); RAM(w):000000000005d6ce=0082( é); RealRAM(w):000000000005d6ce=0082( é); Paged(w):0005d6ce=0082( é)
BIU -- - 373b:00004392 56 push si
Registers:
ESP: 0000f820 EBP: 0000f822 ESI: 00000082 EDI: 00fff94d
EIP: 00004392 EFLAGS: 00007292
Previous CS:EIP: 373b:00004391
BIU -- -
BIU -- I
BIU -- -
BIU -- S
BIU -- E 373b:00004393 EB 03 jmp 00004398
Registers:
ESP: 0000f81e EBP: 0000f822 ESI: 00000082 EDI: 00fff94d
EIP: 00004393 EFLAGS: 00007292
Previous CS:EIP: 373b:00004392
BIU T1 - Paged(p):0003b748=06(♠); Normal(p):00004398=06(♠); Paged(p):0003b749=2e(.); Normal(p):00004399=2e(.); Paged(p):0003b74a=8c(î); Normal(p):0000439a=8c(î); Paged(p):0003b74b=1e(▲); Normal(p):0000439b=1e(▲)
BIU T1 - Paged(p):0003b74c=96(û); Normal(p):0000439c=96(û); Paged(p):0003b74d=43(C); Normal(p):0000439d=43(C); Paged(p):0003b74e=8a(è); Normal(p):0000439e=8a(è); Paged(p):0003b74f=46(F); Normal(p):0000439f=46(F)
BIU T1 - Paged(p):0003b750=06(♠); Normal(p):000043a0=06(♠); Paged(p):0003b751=bb(╗); Normal(p):000043a1=bb(╗); Paged(p):0003b752=cf(╧); Normal(p):000043a2=cf(╧); Paged(p):0003b753=43(C); Normal(p):000043a3=43(C)
BIU T1 - Paged(p):0003b754=2e(.); Normal(p):000043a4=2e(.); Paged(p):0003b755=88(ê); Normal(p):000043a5=88(ê); Paged(p):0003b756=47(G); Normal(p):000043a6=47(G); Paged(p):0003b757=01(☺); Normal(p):000043a7=01(☺)
BIU T1 - Paged(p):0003b758=c4(─); Normal(p):000043a8=c4(─); Paged(p):0003b759=76(v); Normal(p):000043a9=76(v); Paged(p):0003b75a=08(◘); Normal(p):000043aa=08(◘); Paged(p):0003b75b=26(&); Normal(p):000043ab=26(&)
BIU T1 - Paged(p):0003b75c=8b(ï); Normal(p):000043ac=8b(ï); Paged(p):0003b75d=04(♦); Normal(p):000043ad=04(♦); Paged(p):0003b75e=26(&); Normal(p):000043ae=26(&); Paged(p):0003b75f=8b(ï); Normal(p):000043af=8b(ï)
BIU T1 I Paged(p):0003b760=5c(\); Normal(p):000043b0=5c(\); Paged(p):0003b761=02(☻); Normal(p):000043b1=02(☻); Paged(p):0003b762=26(&); Normal(p):000043b2=26(&); Paged(p):0003b763=8b(ï); Normal(p):000043b3=8b(ï)
BIU T1 - 373b:00004398 Paged(p):0003b764=4c(L); Normal(p):000043b4=4c(L); Paged(p):0003b765=04(♦); Normal(p):000043b5=04(♦); Paged(p):0003b766=26(&); Normal(p):000043b6=26(&); Paged(p):0003b767=8b(ï); Normal(p):000043b7=8b(ï)
BIU T1 - 373b:00004398 Paged(p):0003b768=54(T); Normal(p):000043b8=54(T); Paged(p):0003b769=06(♠); Normal(p):000043b9=06(♠); Paged(p):0003b76a=50(P); Normal(p):000043ba=50(P); Paged(p):0003b76b=26(&); Normal(p):000043bb=26(&)
BIU T1 - 373b:00004398 Paged(p):0003b76c=8b(ï); Normal(p):000043bc=8b(ï); Paged(p):0003b76d=44(D); Normal(p):000043bd=44(D); Paged(p):0003b76e=08(◘); Normal(p):000043be=08(◘); Paged(p):0003b76f=26(&); Normal(p):000043bf=26(&)
BIU T1 - 373b:00004398 Paged(p):0003b770=8b(ï); Normal(p):000043c0=8b(ï); Paged(p):0003b771=7c(|); Normal(p):000043c1=7c(|); Paged(p):0003b772=0a( ); Normal(p):000043c2=0a( ); Paged(p):0003b773=26(&); Normal(p):000043c3=26(&)
BIU T1 - 373b:00004398 MemoryBus(w):000000000005d6cc=eb(δ); RAM(w):000000000005d6cc=4deb(Mδ); RealRAM(w):000000000005d6cc=4deb(Mδ); Paged(w):0005d6cc=4deb(Mδ)
BIU -- - 373b:00004398 06 push es
Registers:
EIP: 00004398 EFLAGS: 00007292
Previous CS:EIP: 373b:00004393
BIU T1 - Paged(p):0003b774=8e(Ä); Normal(p):000043c4=8e(Ä); Paged(p):0003b775=5c(\); Normal(p):000043c5=5c(\); Paged(p):0003b776=0e(♫); Normal(p):000043c6=0e(♫); Paged(p):0003b777=26(&); Normal(p):000043c7=26(&)
BIU T1 I Paged(p):0003b778=8e(Ä); Normal(p):000043c8=8e(Ä); Paged(p):0003b779=44(D); Normal(p):000043c9=44(D); Paged(p):0003b77a=0c(♀); Normal(p):000043ca=0c(♀); Paged(p):0003b77b=8b(ï); Normal(p):000043cb=8b(ï)
BIU T1 - Paged(p):0003b77c=f0(≡); Normal(p):000043cc=f0(≡); Paged(p):0003b77d=58(X); Normal(p):000043cd=58(X); Paged(p):0003b77e=55(U); Normal(p):000043ce=55(U); Paged(p):0003b77f=cd(═); Normal(p):000043cf=cd(═)
BIU T1 - Paged(p):0003b780=00( ); Normal(p):000043d0=00( ); Paged(p):0003b781=5d(]); Normal(p):000043d1=5d(]); Paged(p):0003b782=1e(▲); Normal(p):000043d2=1e(▲); Paged(p):0003b783=2e(.); Normal(p):000043d3=2e(.)
BIU T1 S Paged(p):0003b784=8e(Ä); Normal(p):000043d4=8e(Ä); Paged(p):0003b785=1e(▲); Normal(p):000043d5=1e(▲); Paged(p):0003b786=96(û); Normal(p):000043d6=96(û); Paged(p):0003b787=43(C); Normal(p):000043d7=43(C)
BIU T1 - Paged(p):0003b788=06(♠); Normal(p):000043d8=06(♠); Paged(p):0003b789=56(V); Normal(p):000043d9=56(V); Paged(p):0003b78a=c4(─); Normal(p):000043da=c4(─); Paged(p):0003b78b=76(v); Normal(p):000043db=76(v)
BIU -- -
BIU -- - 373b:00004399
BIU T1 - 373b:00004399 MemoryBus(w):000000000003b746=eb(δ); RAM(w):000000000003b746=4deb(Mδ); RealRAM(w):000000000003b746=4deb(Mδ); Paged(w):0003b746=4deb(Mδ)
Registers:
ESP: 0000f81c EBP: 0000f822 ESI: 00000082 EDI: 00fff94d
EIP: 00004399 EFLAGS: 00007292
Previous CS:EIP: 373b:00004398
BIU -- I ^ 2E 8C 1E 96 43 mov word cs:[4396],ds
BIU -- -
BIU -- S
BIU T1 - Paged(p):0003b78c=0c(♀); Normal(p):000043dc=0c(♀); Paged(p):0003b78d=26(&); Normal(p):000043dd=26(&); Paged(p):0003b78e=89(ë); Normal(p):000043de=89(ë); Paged(p):0003b78f=04(♦); Normal(p):000043df=04(♦)
BIU -- - 373b:0000439e
BIU T1 - 373b:0000439e RealRAM(r):000000000005d6d8=00000000f85a0010(°FMδ°Z ►); RAM(r):000000000005d6d8=00000000f85a0010(°FMδ°Z ►); MemoryBus(r):000000000005d6d8=f85a0010(°Z ►); Paged(r):0005d6d8=10(►)
BIU -- - 373b:0000439e 8A 46 06 mov al,byte ss:[bp+06]
Registers:
EIP: 0000439e EFLAGS: 00007292
Previous CS:EIP: 373b:00004399
BIU -- -
BIU -- I
BIU -- -
BIU -- S
BIU T1 - 373b:000043a1 BB CF 43 mov bx,43cf MemoryBus(p):000000000003b790=025c8926(☻\ë&); Paged(p):0003b790=26(&); Normal(p):000043e0=26(&); Paged(p):0003b791=89(ë); Normal(p):000043e1=89(ë); Paged(p):0003b792=5c(\); Normal(p):000043e2=5c(\); Paged(p):0003b793=02(☻); Normal(p):000043e3=02(☻)
Registers:
EIP: 000043a1 EFLAGS: 00007292
Previous CS:EIP: 373b:0000439e
BIU -- -
BIU -- I
BIU -- -
BIU -- -
BIU -- S
BIU T1 - Paged(p):0003b794=26(&); Normal(p):000043e4=26(&); Paged(p):0003b795=89(ë); Normal(p):000043e5=89(ë); Paged(p):0003b796=4c(L); Normal(p):000043e6=4c(L); Paged(p):0003b797=04(♦); Normal(p):000043e7=04(♦)
BIU -- -
BIU -- - 373b:000043a4
BIU T1 - 373b:000043a4 Paged(w):0003b780=0010( ►); MemoryBus(w):000000000003b780=eb(δ); RAM(w):000000000003b780=eb(δ); RealRAM(w):000000000003b780=eb(δ)
Registers:
EAX: 80000010 EBX: 000043cf ECX: 000012a6 EDX: 0000373b
EIP: 000043a4 EFLAGS: 00007292
Previous CS:EIP: 373b:000043a1
BIU -- I ^ 2E 88 47 01 mov byte cs:[bx+01],al
BIU -- -
BIU -- S
BIU -- -
BIU -- - 373b:000043a8
BIU T1 - 373b:000043a8 Paged(r):0005d6da=5a(Z); Paged(r):0005d6db=f8(°)
BIU T1 - 373b:000043a8 Paged(r):0005d6dc=eb(δ); Paged(r):0005d6dd=4d(M)
BIU -- - 373b:000043a8 C4 76 08 les si,word ss:[bp+08]
Registers:
EIP: 000043a8 EFLAGS: 00007292
Previous CS:EIP: 373b:000043a4
BIU -- -
BIU -- -
BIU -- I
BIU T1 - Paged(p):0003b798=26(&); Normal(p):000043e8=26(&); Paged(p):0003b799=89(ë); Normal(p):000043e9=89(ë); Paged(p):0003b79a=54(T); Normal(p):000043ea=54(T); Paged(p):0003b79b=06(♠); Normal(p):000043eb=06(♠)
BIU -- -
BIU -- S
BIU -- -
BIU -- - 373b:000043ab
BIU T1 - 373b:000043ab RealRAM(r):000000000005d70a=0f00(☼ ); RAM(r):000000000005d70a=0f00(☼ ); MemoryBus(r):000000000005d70a=0f00(☼ ); Paged(r):0005d70a=00( ); Paged(r):0005d70b=0f(☼)
BIU -- - 373b:000043ab 26 8B 04 mov ax,word es:[si]
Registers:
ESP: 0000f81c EBP: 0000f822 ESI: 0000f85a EDI: 00fff94d
EIP: 000043ab EFLAGS: 00007292
Previous CS:EIP: 373b:000043a8
BIU -- -
BIU -- I
BIU -- -
BIU -- -
BIU -- S
BIU T1 - Paged(p):0003b79c=58(X); Normal(p):000043ec=58(X); Paged(p):0003b79d=26(&); Normal(p):000043ed=26(&); Paged(p):0003b79e=89(ë); Normal(p):000043ee=89(ë); Paged(p):0003b79f=44(D); Normal(p):000043ef=44(D)
BIU -- -
BIU -- - 373b:000043ae
BIU T1 - 373b:000043ae RealRAM(r):000000000005d70c=f87af94d(°z∙M); RAM(r):000000000005d70c=f87af94d(°z∙M); MemoryBus(r):000000000005d70c=f87af94d(°z∙M); Paged(r):0005d70c=4d(M); Paged(r):0005d70d=f9(∙)
BIU -- - 373b:000043ae 26 8B 5C 02 mov bx,word es:[si+02]
Registers:
EAX: 80000f00 EBX: 000043cf ECX: 000012a6 EDX: 0000373b
EIP: 000043ae EFLAGS: 00007292
Previous CS:EIP: 373b:000043ab
BIU -- -
BIU -- I
BIU -- -
BIU -- -
BIU -- S
BIU T1 - MemoryBus(p):000000000003b7a0=7c892608(|ë&◘); Paged(p):0003b7a0=08(◘); Normal(p):000043f0=08(◘); Paged(p):0003b7a1=26(&); Normal(p):000043f1=26(&); Paged(p):0003b7a2=89(ë); Normal(p):000043f2=89(ë); Paged(p):0003b7a3=7c(|); Normal(p):000043f3=7c(|)
BIU -- -
BIU -- - 373b:000043b2
BIU T1 - 373b:000043b2 Paged(r):0005d70e=7a(z); Paged(r):0005d70f=f8(°)
BIU -- - 373b:000043b2 26 8B 4C 04 mov cx,word es:[si+04]
Registers:
EAX: 80000f00 EBX: 0000f94d ECX: 000012a6 EDX: 0000373b
EIP: 000043b2 EFLAGS: 00007292
Previous CS:EIP: 373b:000043ae
BIU -- -
BIU -- I
BIU -- -
BIU -- -
BIU -- S
BIU T1 - Paged(p):0003b7a4=0a( ); Normal(p):000043f4=0a( ); Paged(p):0003b7a5=58(X); Normal(p):000043f5=58(X); Paged(p):0003b7a6=26(&); Normal(p):000043f6=26(&); Paged(p):0003b7a7=89(ë); Normal(p):000043f7=89(ë)
BIU -- -
BIU -- - 373b:000043b6
BIU T1 - 373b:000043b6 MemoryBus(r):000000000005d710=373b2e1e(7;.▲); Paged(r):0005d710=1e(▲); Paged(r):0005d711=2e(.)
BIU -- - 373b:000043b6 26 8B 54 06 mov dx,word es:[si+06]
Registers:
EAX: 80000f00 EBX: 0000f94d ECX: 0000f87a EDX: 0000373b
EIP: 000043b6 EFLAGS: 00007292
Previous CS:EIP: 373b:000043b2
BIU -- -
BIU -- I
BIU -- - 373b:000043ba
BIU T1 - 373b:000043ba MemoryBus(w):000000000005d6ca=00( ); RAM(w):000000000005d6ca=0f00(☼ ); RealRAM(w):000000000005d6ca=0f00(☼ ); Paged(w):0005d6ca=0f00(☼ )
Registers:
EAX: 80000f00 EBX: 0000f94d ECX: 0000f87a EDX: 00002e1e
EIP: 000043ba EFLAGS: 00007292
Previous CS:EIP: 373b:000043b6
BIU T1 - Paged(p):0003b7a8=44(D); Normal(p):000043f8=44(D); Paged(p):0003b7a9=0c(♀); Normal(p):000043f9=0c(♀); Paged(p):0003b7aa=58(X); Normal(p):000043fa=58(X); Paged(p):0003b7ab=26(&); Normal(p):000043fb=26(&)
BIU -- -
BIU -- S
BIU -- -
BIU -- -
BIU -- - 373b:000043bb
BIU T1 - 373b:000043bb Paged(r):0005d712=3b(;); Paged(r):0005d713=37(7)
BIU -- - 373b:000043bb 26 8B 44 08 mov ax,word es:[si+08]
Registers:
ESP: 0000f81a EBP: 0000f822 ESI: 0000f85a EDI: 00fff94d
EIP: 000043bb EFLAGS: 00007292
Previous CS:EIP: 373b:000043ba
BIU -- -
BIU -- I
BIU T1 - Paged(p):0003b7ac=89(ë); Normal(p):000043fc=89(ë); Paged(p):0003b7ad=44(D); Normal(p):000043fd=44(D); Paged(p):0003b7ae=0e(♫); Normal(p):000043fe=0e(♫); Paged(p):0003b7af=07(•); Normal(p):000043ff=07(•)
BIU -- -
BIU -- S
BIU -- -
BIU -- -
BIU -- - 373b:000043bf
BIU T1 - 373b:000043bf Paged(r):0005d714=00( ); Paged(r):0005d715=00( )
BIU -- - 373b:000043bf 26 8B 7C 0A mov di,word es:[si+0a]
Registers:
EAX: 8000373b EBX: 0000f94d ECX: 0000f87a EDX: 00002e1e
EIP: 000043bf EFLAGS: 00007292
Previous CS:EIP: 373b:000043bb
BIU -- -
BIU -- I
BIU T1 - MemoryBus(p):000000000003b7b0=5f5e589c(_^X£); Paged(p):0003b7b0=9c(£); Normal(p):00004400=9c(£); Paged(p):0003b7b1=58(X); Normal(p):00004401=58(X); Paged(p):0003b7b2=5e(^); Normal(p):00004402=5e(^); Paged(p):0003b7b3=5f(_); Normal(p):00004403=5f(_)
BIU -- -
BIU -- S
BIU -- -
BIU -- -
BIU -- - 373b:000043c3
BIU T1 - 373b:000043c3 Paged(r):0005d718=3b(;); Paged(r):0005d719=37(7)
BIU -- - 373b:000043c3 26 8E 5C 0E mov ds,word es:[si+0e]
Registers:
ESP: 0000f81a EBP: 0000f822 ESI: 0000f85a EDI: 00ff0000
EIP: 000043c3 EFLAGS: 00007292
Previous CS:EIP: 373b:000043bf
BIU -- -
BIU -- -
BIU -- I
BIU T1 - Paged(p):0003b7b4=8b(ï); Normal(p):00004404=8b(ï); Paged(p):0003b7b5=e5(σ); Normal(p):00004405=e5(σ); Paged(p):0003b7b6=5d(]); Normal(p):00004406=5d(]); Paged(p):0003b7b7=cb(╦); Normal(p):00004407=cb(╦)
BIU -- -
BIU -- S
BIU -- -
BIU -- -
BIU -- - 373b:000043c7
BIU T1 - 373b:000043c7 Paged(r):0005d716=89(ë); Paged(r):0005d717=51(Q)
BIU -- - 373b:000043c7 26 8E 44 0C mov es,word es:[si+0c]
Registers:
CS: 373b DS: 373b ES: 4deb FS: 0000 GS: 0000 SS: 4deb TR: 0000 LDTR: 0000
EIP: 000043c7 EFLAGS: 00007292
DS descriptor: 0000930373B0FFFF
Previous CS:EIP: 373b:000043c3
BIU -- -
BIU -- -
BIU -- I
BIU T1 - Paged(p):0003b7b8=55(U); Normal(p):00004408=55(U); Paged(p):0003b7b9=8b(ï); Normal(p):00004409=8b(ï); Paged(p):0003b7ba=ec(∞); Normal(p):0000440a=ec(∞); Paged(p):0003b7bb=b8(╕); Normal(p):0000440b=b8(╕)
BIU -- S
BIU -- - 373b:000043cb 8B F0 mov si,ax
Registers:
CS: 373b DS: 373b ES: 5189 FS: 0000 GS: 0000 SS: 4deb TR: 0000 LDTR: 0000
EIP: 000043cb EFLAGS: 00007292
ES descriptor: 000093051890FFFF
Previous CS:EIP: 373b:000043c7
BIU -- -
BIU -- I
BIU -- - 373b:000043cd
BIU T1 - 373b:000043cd RealRAM(r):000000000005d6ca=0f00(☼ ); RAM(r):000000000005d6ca=0f00(☼ ); MemoryBus(r):000000000005d6ca=0f00(☼ ); Paged(r):0005d6ca=00( ); Paged(r):0005d6cb=0f(☼)
BIU -- - 373b:000043cd 58 pop ax
Registers:
ESP: 0000f81a EBP: 0000f822 ESI: 0000373b EDI: 00ff0000
EIP: 000043cd EFLAGS: 00007292
Previous CS:EIP: 373b:000043cb
BIU -- -
BIU -- I
BIU -- - 373b:000043ce
BIU T1 - 373b:000043ce MemoryBus(w):000000000005d6ca=22("); RAM(w):000000000005d6ca=f822(°"); RealRAM(w):000000000005d6ca=f822(°"); Paged(w):0005d6ca=f822(°")
BIU -- - 373b:000043ce 55 push bp
Registers:
ESP: 0000f81c EBP: 0000f822 ESI: 0000373b EDI: 00ff0000
EIP: 000043ce EFLAGS: 00007292
Previous CS:EIP: 373b:000043cd
BIU -- -
BIU -- I
BIU T1 - Paged(p):0003b7bc=0e(♫); Normal(p):0000440c=0e(♫); Paged(p):0003b7bd=00( ); Normal(p):0000440d=00( ); Paged(p):0003b7be=9a(Ü); Normal(p):0000440e=9a(Ü); Paged(p):0003b7bf=be(╛); Normal(p):0000440f=be(╛)
BIU -- S
BIU -- - 373b:000043cf
BIU T1 - 373b:000043cf MemoryBus(r):0000000000000000=3c5700cc(<W ╠); Paged(r):00000000=cc(╠); Paged(r):00000001=00( )
BIU T1 - 373b:000043cf Paged(r):00000002=57(W); Paged(r):00000003=3c(<)
BIU T1 - 373b:000043cf MemoryBus(w):000000000005d6c8=92(Æ); RAM(w):000000000005d6c8=7292(rÆ); RealRAM(w):000000000005d6c8=7292(rÆ); Paged(w):0005d6c8=7292(rÆ)
BIU T1 - 373b:000043cf MemoryBus(w):000000000005d6c6=3b(;); RAM(w):000000000005d6c6=373b(7;); RealRAM(w):000000000005d6c6=373b(7;); Paged(w):0005d6c6=373b(7;)
BIU T1 - 373b:000043cf MemoryBus(w):000000000005d6c4=d1(╤); RAM(w):000000000005d6c4=43d1(C╤); RealRAM(w):000000000005d6c4=43d1(C╤); Paged(w):0005d6c4=43d1(C╤)
BIU -- E 373b:000043cf CD 00 int 00 Interrupt 00=3C57:000000CC@373B:43D1(CD); ERRORCODE: FFFFFFFE
Registers:
EIP: 000043cf EFLAGS: 00007292
Previous CS:EIP: 373b:000043ce
BIU T1 - RealRAM(p):000000000003c63c=8e4debb8(ÄMδ╕); RAM(p):000000000003c63c=8e4debb8(ÄMδ╕); MemoryBus(p):000000000003c63c=8e4debb8(ÄMδ╕); Paged(p):0003c63c=b8(╕); Normal(p):000000cc=b8(╕); Paged(p):0003c63d=eb(δ); Normal(p):000000cd=eb(δ); Paged(p):0003c63e=4d(M); Normal(p):000000ce=4d(M); Paged(p):0003c63f=8e(Ä); Normal(p):000000cf=8e(Ä)
BIU T1 - MemoryBus(p):000000000003c640=0003b8d8( ♥╕╪); Paged(p):0003c640=d8(╪); Normal(p):000000d0=d8(╪); Paged(p):0003c641=b8(╕); Normal(p):000000d1=b8(╕); Paged(p):0003c642=03(♥); Normal(p):000000d2=03(♥); Paged(p):0003c643=00( ); Normal(p):000000d3=00( )
BIU T1 - Paged(p):0003c644=36(6); Normal(p):000000d4=36(6); Paged(p):0003c645=c7(╟); Normal(p):000000d5=c7(╟); Paged(p):0003c646=06(♠); Normal(p):000000d6=06(♠); Paged(p):0003c647=2c(,); Normal(p):000000d7=2c(,)
BIU T1 - Paged(p):0003c648=a5(Ñ); Normal(p):000000d8=a5(Ñ); Paged(p):0003c649=70(p); Normal(p):000000d9=70(p); Paged(p):0003c64a=02(☻); Normal(p):000000da=02(☻); Paged(p):0003c64b=50(P); Normal(p):000000db=50(P)
BIU T1 - Paged(p):0003c64c=9a(Ü); Normal(p):000000dc=9a(Ü); Paged(p):0003c64d=92(Æ); Normal(p):000000dd=92(Æ); Paged(p):0003c64e=26(&); Normal(p):000000de=26(&); Paged(p):0003c64f=57(W); Normal(p):000000df=57(W)
BIU T1 - MemoryBus(p):000000000003c650=26679a3c(&gÜ<); Paged(p):0003c650=3c(<); Normal(p):000000e0=3c(<); Paged(p):0003c651=9a(Ü); Normal(p):000000e1=9a(Ü); Paged(p):0003c652=67(g); Normal(p):000000e2=67(g); Paged(p):0003c653=26(&); Normal(p):000000e3=26(&)
BIU T1 - Paged(p):0003c654=57(W); Normal(p):000000e4=57(W); Paged(p):0003c655=3c(<); Normal(p):000000e5=3c(<); Paged(p):0003c656=b8(╕); Normal(p):000000e6=b8(╕); Paged(p):0003c657=ff( ); Normal(p):000000e7=ff( )
BIU T1 - Paged(p):0003c658=00( ); Normal(p):000000e8=00( ); Paged(p):0003c659=50(P); Normal(p):000000e9=50(P); Paged(p):0003c65a=0e(♫); Normal(p):000000ea=0e(♫); Paged(p):0003c65b=ff( ); Normal(p):000000eb=ff( )
BIU T1 - Paged(p):0003c65c=16(▬); Normal(p):000000ec=16(▬); Paged(p):0003c65d=2c(,); Normal(p):000000ed=2c(,); Paged(p):0003c65e=a5(Ñ); Normal(p):000000ee=a5(Ñ); Paged(p):0003c65f=00( ); Normal(p):000000ef=00( )
BIU T1 - MemoryBus(p):000000000003c660=ec8bc58b(∞ï┼ï); Paged(p):0003c660=8b(ï); Normal(p):000000f0=8b(ï); Paged(p):0003c661=c5(┼); Normal(p):000000f1=c5(┼); Paged(p):0003c662=8b(ï); Normal(p):000000f2=8b(ï); Paged(p):0003c663=ec(∞); Normal(p):000000f3=ec(∞)
BIU T1 - Paged(p):0003c664=8c(î); Normal(p):000000f4=8c(î); Paged(p):0003c665=da(┌); Normal(p):000000f5=da(┌); Paged(p):0003c666=c5(┼); Normal(p):000000f6=c5(┼); Paged(p):0003c667=5e(^); Normal(p):000000f7=5e(^)
BIU T1 - Paged(p):0003c668=04(♦); Normal(p):000000f8=04(♦); Paged(p):0003c669=89(ë); Normal(p):000000f9=89(ë); Paged(p):0003c66a=07(•); Normal(p):000000fa=07(•); Paged(p):0003c66b=89(ë); Normal(p):000000fb=89(ë)
BIU T1 - Paged(p):0003c66c=7f(⌂); Normal(p):000000fc=7f(⌂); Paged(p):0003c66d=02(☻); Normal(p):000000fd=02(☻); Paged(p):0003c66e=89(ë); Normal(p):000000fe=89(ë); Paged(p):0003c66f=77(w); Normal(p):000000ff=77(w)
BIU T1 - MemoryBus(p):000000000003c670=06678904(♠gë♦); Paged(p):0003c670=04(♦); Normal(p):00000100=04(♦); Paged(p):0003c671=89(ë); Normal(p):00000101=89(ë); Paged(p):0003c672=67(g); Normal(p):00000102=67(g); Paged(p):0003c673=06(♠); Normal(p):00000103=06(♠)
BIU T1 - Paged(p):0003c674=8b(ï); Normal(p):00000104=8b(ï); Paged(p):0003c675=4e(N); Normal(p):00000105=4e(N); Paged(p):0003c676=00( ); Normal(p):00000106=00( ); Paged(p):0003c677=89(ë); Normal(p):00000107=89(ë)
BIU T1 - Paged(p):0003c678=4f(O); Normal(p):00000108=4f(O); Paged(p):0003c679=08(◘); Normal(p):00000109=08(◘); Paged(p):0003c67a=8b(ï); Normal(p):0000010a=8b(ï); Paged(p):0003c67b=4e(N); Normal(p):0000010b=4e(N)
BIU -- -
BIU -- -
BIU -- -
BIU -- -
BIU -- -
BIU -- -
BIU -- -
BIU -- -
BIU -- -
BIU -- -
BIU -- I
BIU -- -
BIU -- S
BIU -- - 3c57:000000cc B8 EB 4D mov ax,4deb
Registers:
ESP: 0000f814 EBP: 0000f822 ESI: 0000373b EDI: 00ff0000
CS: 3c57 DS: 373b ES: 5189 FS: 0000 GS: 0000 SS: 4deb TR: 0000 LDTR: 0000
EIP: 000000cc EFLAGS: 00007092
CS descriptor: 00009303C570FFFF
Previous CS:EIP: 373b:000043cf
FLAGSINFO: 0000000000ipfavr0N11oditSz0A0p1c
Edit: Hmmm...
https://keyj.emphy.de/the-case-of-the-mysterious-ao486-bug/
Perhaps this is related?
Edit: It seems it is a related bug:
At 373B:43A4 it's executing "2E 88 47 01 mov byte cs:[bx+01],al".
That's patching the INT 00 instruction to become "INT 10". But somehow the memory write gets turned into a EBh write (also 16-bit 0010h in the BIU)?
Said memory write contains gibberish it seems? The base address seems correct, but the data and written data size is entirely incorrect? Is it even written to the memory correctly?
UniPCemu Git repository
Reply 771 of 781, by superfury
OK. Noticed something. During the jump to said 32F5 segment from segment 1B54 (running WhatVGA), I see it's performing the jump, invalidating the PIQ, then executes over 20 BIU cycles without any BIU stall it's supposed to do.
So it's filling lots of BIU PIQ data from memory, including the jump instruction (which just happens in cycle-accurate mode. IPS clocking mode only fetches 12 bytes (maximum instruction length) and stops fetching).
Edit: Fixed it by decreasing the PIQ size to 16 bytes on all 386+ CPUs.
Edit: Reverted that and instead chose to invalidate the PIQ whenever data inside of it is modified by an instruction writing to it's linear memory address (on a 386 CPU and higher).
Edit: Also added reverse paging (from physical to linear) lookups to invalidate PIQ addresses (when possible. If the TLB entry is evicted already, it won't work).
Reply 772 of 781, by superfury
Fixing 16-bit stack pushes and pops for interrupt and IRET instructions (even in 32-bit mode) with proper 16-bit writes and reads peformed for the stack accesses fixed more.
Then fixing stack access checks (which checks if a push or pop is allowed according to paging and segmentation access rights)) to handle the protected mode resetting state correctly (allowing for it to pause and resume/restart properly) fixed Windows 3.0's 386 enhanced mode to once again boot properly.
I still see the #GP(0) for the PUSHF instruction during the Windows startup process (due to Virtual 8086 mode's IOPL being 0), but apparently that's supposed to happen.
Edit: And the standard mode bug of the CALL 0:FFFFh instruction returns once again?
So the corrupted CALL instruction strikes again (just like before).
Edit: Moved all stack and memory pending operations to the main memory check handling.
Reply 773 of 781, by superfury
After running the latest test386.asm testsuite I adjusted myself (both older versions that ran and my newly made newer version (which has some basic TSS task switching with validation (just segment and general purpose registers tested though)), I see it failing in a spectacular way on my 80386 emulation (with the latest BIU changed CALL/JMP handling):
			Previous CS:EIP: f000:000013c3
FLAGSINFO: 00000000000000vr0n00oDitSz0a0P1C
BIU T1 - MemoryBus(p):00000000000f13de=0ff0(☼≡); Paged(p):000f13de=f0(≡); Normal(p):000013de=f0(≡); Paged(p):000f13df=0f(☼); Normal(p):000013df=0f(☼); MemoryBus(p):00000000000f13e0=ebe90c83(δΘ♀â); Paged(p):000f13e0=83(â); Normal(p):000013e0=83(â); Paged(p):000f13e1=0c(♀); Normal(p):000013e1=0c(♀)
BIU T2 I
BIU T1 - MemoryBus(p):00000000000f13e2=ebe9(δΘ); Paged(p):000f13e2=e9(Θ); Normal(p):000013e2=e9(Θ); Paged(p):000f13e3=eb(δ); Normal(p):000013e3=eb(δ); MemoryBus(p):00000000000f13e4=08e88312(◘Φâ↕); Paged(p):000f13e4=12(↕); Normal(p):000013e4=12(↕); Paged(p):000f13e5=83(â); Normal(p):000013e5=83(â)
BIU T2 -
BIU T1 S MemoryBus(p):00000000000f13e6=08e8(◘Φ); Paged(p):000f13e6=e8(Φ); Normal(p):000013e6=e8(Φ); Paged(p):000f13e7=08(◘); Normal(p):000013e7=08(◘); MemoryBus(p):00000000000f13e8=850fc439(à☼─9); Paged(p):000f13e8=39(9); Normal(p):000013e8=39(9); Paged(p):000f13e9=c4(─); Normal(p):000013e9=c4(─)
BIU T2 -
BIU T1 - MemoryBus(p):00000000000f13ea=850f(à☼); Paged(p):000f13ea=0f(☼); Normal(p):000013ea=0f(☼); Paged(p):000f13eb=85(à); Normal(p):000013eb=85(à); MemoryBus(p):00000000000f13ec=c083e901(└âΘ☺); Paged(p):000f13ec=01(☺); Normal(p):000013ec=01(☺); Paged(p):000f13ed=e9(Θ); Normal(p):000013ed=e9(Θ)
BIU T2 - f000:000013d7
BIU -- - f000:000013d7 PUSH(F000) pending!
BIU T1 - f000:000013d7 MemoryBus(w):000000000001fff9=00( ); RAM(w):000000000001fff9=00( ); RealRAM(w):000000000007fff9=00( ); Paged(w):0001fff9=00( ); Paged(w):0001fffa=f0(≡); MemoryBus(w):000000000001fffa=f0(≡); RAM(w):000000000001fffa=f0(≡); RealRAM(w):000000000007fffa=f0(≡)
BIU T2 - f000:000013d7 PUSHed (16)!; PUSH(000013DF) pending!
BIU T1 - f000:000013d7 MemoryBus(w):000000000001fff1=df(▀); RAM(w):000000000001fff1=df(▀); RealRAM(w):000000000007fff1=df(▀); Paged(w):0001fff1=df(▀); Paged(w):0001fff2=0013( ‼); MemoryBus(w):000000000001fff2=13(‼); RAM(w):000000000001fff2=0013( ‼); RealRAM(w):000000000007fff2=0013( ‼)
BIU T1 - f000:000013d7 Paged(w):0001fff4=00( ); MemoryBus(w):000000000001fff4=00( ); RAM(w):000000000001fff4=00( ); RealRAM(w):000000000007fff4=00( )
BIU T2 E f000:000013d7 66 9A E5 13 00 00 00 F0 calld f000:000013e5 PUSHed (32)!
Registers:
EAX: 0000fff9 EBX: 0000138d ECX: 00000000 EDX: 00000084
ESP: 0000fff9 EBP: 00000000 ESI: 00010000 EDI: 0001ffff
CS: f000 DS: 2200 ES: 6200 FS: 2000 GS: 2000 SS: 1000 TR: 0000 LDTR: 0000
EIP: 000013d7 EFLAGS: 00000486
CR0: 00000000 CR2: 00000000 CR3: 00000000
GDTR: 000000000000ffff IDTR: 00000000000003ff
CS descriptor: 0000930F0000FFFF
SS descriptor: 000093010000FFFF
DS descriptor: 000093022000FFFF
ES descriptor: 000093062000FFFF
FS descriptor: 000093020000FFFF
GS descriptor: 000093020000FFFF
It's obviously writing the stack to a wrong address there, almost like it forgets to properly decrease (E)SP for the stack write?
The values it's trying to write are obviously correct (the "PUSH(valuehere) pending" being logged is proof of that). Somehow it's writing the values to what seems to be an undecreased (E)SP register, or incorrectly decreasing said register somehow? That's writing at 1fff1 and 1fff9, which is supposed to have been lowered before writing?
Edit: After a bit of debugging I found a bug in the protected mode push operation when it was interrupted. Somehow, it would incorrectly decrease (E)SP in such a case, causing the non-commit repeated handling to not decrease (E)SP on subsequent attempts. That part is running now again with those fixes.
Reply 774 of 781, by superfury
Just fixed a bug where reading a TSS descriptor with bit 3 (32-bit) of the AR byte cleared doesn't lock the bus for the read-modify-write. Now it will do so properly (besides when the accessed bit is cleared for a non-system descriptor. Interesting it's named "system" while it's system while it's cleared instead of set).
Reply 775 of 781, by superfury
Now trying OS/2 1.3, since that's one of the very few test OSes I know of that seemingly uses 16-bit protected mode (and not 32-bit protected mode). It seems to boot to the installer just fine (using disk A and disk 1 after that)? Although if I put the floppy on read-only (with the known ST1(27h)/ST2(31h) results for writes), it seems to think it had a CRC error somehow (MS-DOS properly thinks the drive is read-only)?
Edit: Changed it to 02(ST1) 00(ST2) to test.
Edit: That seems to have fixed MS-DOS formatting and file copy to report a write-protected disk, but somehow format.com messes up the disk format when it's terminated in such a state (no other format operation after, reads using incorrect settings for the read)?
Edit: That seems due to it being a 2.44MB drive with a 1.44MB floppy in it and it's setting up the wrong bitrate on the controller, thus making it fault (ST1=25h ST2=20h) for some weird reason all of a sudden (after the failed format only).
Reply 776 of 781, by superfury
OK. Found a bug with the BIU's LOCK# signal handling. It was somehow reaching a state where the CPU had locked the bus without the CPU having bus ownership (actually, the DMA controller (dual 8259A chips) was somehow getting control of the bus while the CPU had it in a LOCK# state, which should never happen).
Having fixed that, I manage to continue the OS/2 1.3 setup past disk 1's CONFIG.SYS and settings step. So far tested till disk 5.
Edit: That makes me think about something. Does windows 3.0 standard mode rely on the LOCK instruction somehow to boot properly?
Reply 777 of 781, by superfury
Can't seem to figure out what's going wrong with the new protected mode cycle-accurate (though the BIU instead of directly) handling of the memory read/write operations (that happen only during protected mode, handled like stepping through the code over and over with a counter as a return label position, stepping through the code repeatedly until it completes fully.). Somehow it causes various things to go wrong in the CPU, although some things still run for the most part (like OS/2 managing to boot partly and Windows 9x still booting, but crashing on a ESDI_506.PDR driver during IE5 installation)? Tried Simcity 2000 again, but that seems to give a incorrect drive access somehow?
Reply 779 of 781, by superfury
Managed to get xv6-public to compile for i686 without FPU, MMX or other instructions. But it seems to crash during userinit on the boot CPU somehow (the BSP CPU). I see it entering the function and never returning from it.
But most of the booting process was already completed, but it's getting back to the BIOS ROM somehow, performing a POST. I don't see any x86 CPU faults, so maybe it's clearing CR0 somehow, receiving an INIT from some hardware or itself or 8042/PPI? The last I checked was a call instruction calling the userinit function, it crashing somehow in the function or it's called functions somehow.
Edit: OK, it's faulting due to a triple fault in the kmalloc function. Somehow, the kmem.freelist seems to contain 0xFFFFFFFF, which it faults on when trying to follow the chain of free kernel memory blocks.
