Reply 780 of 895, by Icy
Yeah, I'm using d3d with Hitman cause it's the only one having a drawing distance hack for.
Ok, here's my error. log for it:
Peixotos's patch remote settings: 32bit: 1 <Gpad>: <Textswap>: s=4;sz=256;path=Textures\VOKSI;n=PgUP;p=PgDn;d=home;sw=end;c=del […]
32bit: 1
<Gpad>:
<Textswap>: s=4;sz=256;path=Textures\VOKSI;n=PgUP;p=PgDn;d=home;sw=end;c=del;q=ins;
BLT3D: 1
CPY: 1
D3D: 7
D3D_Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_22fc90e01dc4ebe8\nvldumd.dll
dsk: 3840x2160
error_log: C:\Games\Peixoto\error.log
HD: 1
HDPI: 1
injector_dir: C:\Games\Peixoto
max_4x3_res: 2048x1536
Mydocs: C:\Users\Admin\Documents
os_version: 10.000000
Path: C:\Users\Admin\Documents\Games\Hitman\Codename 47\
READ: 1
rlst: 640x480 720x480 720x576 800x600 1024x768 1152x864 1176x664 1280x720 1280x768 1280x800 1280x960 1280x1024 1360x768 1366x768 1600x900 1600x1024 1600x1200 1680x1050 1768x992 1920x1080 1920x1200 1920x1440 2048x1536 2560x1440 2560x1600 3840x2160 1440x900 640x350
script_hwnd: 0xf046a
SSAA: 1
target: C:\Games\HitmanC47\hitman.exe
target_dir: C:\Games\HitmanC47
target_name: hitman.exeCreateProcessA Hook: 0
CreateProcessW Hook: 0
ShellExecuteA Hook :0
Desktop 3840x2160
OpenAdapter Hook 0
DDraw.dll : C:\Games\HitmanC47\DDRAW.dll
DirectDrawCreateEX Hook: 0
Succeeded to create DirectDraw
Succeeded to create Direct3D
Succeeded to create the DirectDraw7 and Direct3D7 Interfaces
Succeeded to hook IDirectDraw7::CreateSurface
Succeeded to hook IDirect3D7::CreateDevice
Succeeded to hook IDirect3DDevice7::EndScene
Succeeded to hook IDirectDraw7::SetDisplayMode
Succeeded to hook IDirect3DDevice7::SetViewPort
Succeeded to hook IDirect3DDevice7::Clear
Succeeded to hook IDirectDraw7::EnumDisplayModes
Succeeded to hook IDirect3DDevice7::DrawPrimitive
Succeeded to hook IDirect3D7::CreateVertexBuffer
Succeeded to hook IDirect3DDevice7::DrawPrimitiveVB
Succeeded to hook IDirect3DDevice7::DrawIndexedPrimitiveVB
Succeeded to hook IDirectDrawSurface7::flip
Succeeded to hook IDirectDrawSurface7::EnumAttachedSurfaces
Succeeded to hook IDirectDrawSurface7::GetPixelFormat
Succeeded to hook IDirectDraw7::GetDisplayMode
Succeeded to hook IDirectDrawSurface7::AddAttachedSurface
Succeeded to hook IDirectDrawSurface::GetDC
Succeeded to hook IDirectDrawSurface::ReleaseDC
Succeeded to hook IDirectDrawSurface7::Lock
Succeeded to hook IDirectDrawSurface7::UnLock
Succeeded to hook IDirectDrawSurface7::Blt
Succeeded to hook IDirectDraw7::SetCooperativeLevel
IDirectDrawSurface7::flip is already hooked
Succeeded to hook IDirectDrawSurface7::GetAttachedSurface
IDirectDrawSurface7::EnumAttachedSurfaces is already hooked
Create Surrogate - Surface7 2289434836 DDERR_NOCOOPERATIVELEVELSET format PAL8 512x384
Create Surrogate - Surface7 2147500037 format 33554816 0x1
1 DD7 0x0-0
Create Surrogate - Surface7 0 DDERR_OK format RG6B 512x384
Create Surrogate - Surface1 0 DDERR_OK
2 DD7 512x384-1024
Create Surrogate - Surface7 0 DDERR_OK format X8RGB 512x384
3 DD7 512x384-2048
Create Surrogate - Surface7 0 DDERR_OK format PAL8 640x480
1 DD7 640x480-640
Create Surrogate - Surface7 0 DDERR_OK format RG6B 640x480
2 DD7 640x480-1280
Create Surrogate - Surface7 0 DDERR_OK format X8RGB 640x480
3 DD7 640x480-2560
Create Surrogate - Surface7 0 DDERR_OK format PAL8 720x540
1 DD7 720x540-720
Create Surrogate - Surface7 0 DDERR_OK format RG6B 720x540
2 DD7 720x540-1536
Create Surrogate - Surface7 0 DDERR_OK format X8RGB 720x540
3 DD7 720x540-2944
Create Surrogate - Surface7 0 DDERR_OK format PAL8 960x540
1 DD7 960x540-960
Create Surrogate - Surface7 0 DDERR_OK format RG6B 960x540
2 DD7 960x540-1920
Create Surrogate - Surface7 0 DDERR_OK format X8RGB 960x540
3 DD7 960x540-3840
Create Surrogate - Surface7 0 DDERR_OK format PAL8 800x600
1 DD7 800x600-800
Create Surrogate - Surface7 0 DDERR_OK format RG6B 800x600
2 DD7 800x600-1664
Create Surrogate - Surface7 0 DDERR_OK format X8RGB 800x600
3 DD7 800x600-3200
Create Surrogate - Surface7 0 DDERR_OK format PAL8 1024x768
1 DD7 1024x768-1024
