Exploring the performance of the Matrox G550
Reply 80 of 123, by dr.zeissler
G400 SD 128Bit / G450 DDR 64Bit / G550 DDR 64Bit. G4x/5x have working vSync in D3D but not in OpenGL.
G400/450 works in EMBM G550 does not work in Expandable, don't know if it works in others.
G550 has an additional Texture-Unit, but the performance is only slightly better.
Reply 81 of 123, by appiah4
It would be interesting to add the G450 to this comparison.
Reply 82 of 123, by The Serpent Rider
G550 PCIe is that slow even while running native? I was thinking about grabbing one for fun, but G200 level of performance is underwhelming.
Reply 83 of 123, by dr.zeissler
Running native? Ithought it has a bridgechip or am i wrong here?
Reply 84 of 123, by vvbee
It looks to be slow due to low vertex throughput, slightly higher fillrate than the G400. Passable for older games and may be the most compatible PCIe card you can find for these games. Probably also a strong GUI accelerator like the original G550, has snappy VM performance in any case.
Reply 85 of 123, by vvbee
The VFIO enabled fork of 86Box, https://github.com/richardg867/86Box, looks to not have worked with the G550 PCIe at all until about three months ago with commit 6c72fc2. It's a nice one with 1600 files changed so not possible to figure out which change fixed it. But looking at the code I can see there's some VFIO workarounds for certain ATI, Nvidia and Trident cards, so the gist may be that the Matrox needs a workaround as well for artifact free rendering. But implementing it would require specialist knowledge, or just luck.
Could be useful to have passthrough for the G550 in 86Box. It works with QEMU/KVM but any speed sensitive game is going to give trouble with the overly fast CPU.
Reply 86 of 123, by vvbee
Tested to see if the G550 PCIe can work in a Windows 3 VM. Someone said the G450 OS/2 driver works with the G550, but that's not the case, so can't use Windows 3 through Win-OS/2. I combined the Windows 3 driver from the G450 OS/2 driver set with the G400 driver set for native Windows 3, but again it's not compatible with the G550. Maybe for the G450 it would work, but that's not a PCIe card.
Reply 87 of 123, by vvbee
PCIe vs. AGP version of the G550 in vertex throughput. Showing FPS ratio of the PCIe to the AGP on Y, triangle count on X. Rendering a static textured mesh using Direct3D 7 in Windows 98.
The attachment 39c87b4bec5b.png is no longer available
So the PCIe version starts off at 80% of the speed of the AGP version, makes sense since it's clocked at 80%. But with anything more than 500 triangles it takes a massive extra hit. I can't imagine the PCI bus being this gimped vs. AGP so it's more likely the bridge chip, the TI XIO2000. But then I don't know.
In this particular test the PCIe version tops out at about 300000 triangles per second, the AGP version does just over a million.
So the PCIe version should do relatively well in low poly games, and suffer more in games with poor visibility culling. But from what I've seen the polycount probably isn't the only factor.
Reply 88 of 123, by dr.zeissler
Could be that I made a mistake on that win3 compatibility, I have to recheck it.
G400 offers native Win3x drivers. G450 does not work with these, but G450 OS2 drivers work with winos2, So you can get high-true-color and hires support on win3(within OS2 of course) with g450. The G550 works with the g450 driver in OS2, but if it really supports Winos2 as well...I am not sure about it anymore. It has to be retested. I removed my G550 card, because it get's too hot in my E600. In the E600 advertisement from FSC there is only the G450 DVI listed as suitable option, not the G550. Also the G450 offers EMBM (expendable), the G550 refuses this. There must be more differences than just an additional TMU on that G550. compared to the G450.
Reply 89 of 123, by vvbee
Warp 4 wasn't compatible with the G550, not with the PCIe version passed through to a VM.
Approximating from the earlier data the PCIe version could hang within about 20% of the AGP version up to about 200000 triangles per second, presumably the bridge chip or whatever starts saturating beyond that. At that rate 3000 triangles per frame gets you about 60 FPS, so games like Thief 1 or Quake 2 might run comfortably and see these two cards perform relatively close. That's ignoring various other factors, but a first guess.
Reply 90 of 123, by The Serpent Rider
So in other words G550 PCIe is just a gimped even further PCI G550. I wonder if AGP G550 without GART driver (i.e. PCI 66 mode) behaves in similar manner or it's unique interaction with PCI-PCIe bridge.
Reply 91 of 123, by vvbee
You brought the pessimism but not the data. The PCI version uses a bridge chip also but an older design, so I'll give the PCIe version the benefit of the doubt. It's the more useful version of the two in any case.
Reply 92 of 123, by vvbee
I was intending to test earlier drivers with the passthrough PCIe G550 in Windows 98 but looks like they didn't support it. 6.50 boots into a blank screen and 6.71 (first official driver for the G550) doesn't have 3D acceleration at least by default. There are potential performance benefits for certain games in older drivers for the AGP card, but at least the newest drivers works.
Reply 93 of 123, by vvbee
GLQuake:
The attachment ec825de9932d.png is no longer available
Data for the G450 and Voodoo3 from vgamuseum.info.
The G550 PCIe takes the smallest hit from doubling the resolution, so it's the least fill rate limited. At 1024 x 768 it's on par with the G400, Voodoo3 etc. Keeping in mind it's running in a VM so let's say 10% slower than direct native, and has about 20% lower clocks compared to the G550 AGP.
A few other games:
The attachment 0e6b00dcee7b.png is no longer available
The PCIe's FPS is as my napkin calculations predicted but even in these lower poly games the AGP version is far ahead. Again the PCIe version isn't primarily limited by fill rate. If it's the bridge chip then patterns of data access could play into it and not just the amount of data.
Reply 94 of 123, by appiah4
vvbee wrote on 2025-09-03, 23:45:
GLQuake: […]
GLQuake:
A few other games:
My experience with G450 is that it has quite good GLQuake performance but it has driver bugs that absolutely destroy its performance in Quake2 unless you disable dynamic lighting.
Reply 95 of 123, by vvbee
Phil's recent video had some benchmark numbers for GLQuake with the G550 PCIe in Windows 98. Essentially identical numbers to what I got with passthrough in a VM, so we can assume performance in a VM is essentially identical to native in this case.
Reply 96 of 123, by DEAT
dr.zeissler wrote on 2025-09-02, 06:21:
Sort of false - if you don't install any monitor timings during the driver installation, you can get 1152x864 resolution to work fine with a G450 on a LCD/OSSC capture. You could probably get the other resolutions working if you can figure out the monitor timings that the G450 wants to behave properly.
win16.page | Twitch
Reply 97 of 123, by vvbee
Claude Opus and Fable had a go at figuring out why the AGP G550 is slower than the G400 in Direct3D. Relatively thorough exploration but not over every possible thing. The outcome is inconclusive but more strongly suggests hardware than software.
The effect in 3DMark2000 where game 1 specifically was progressively slower on the G550 compared to the G400 at higher detail levels looks to come down to alpha blending, not vertex count. Higher detail levels have more trees which are alpha-blended. Fable implemented a driver patch that activates an alpha stipple mode documented in the G400 spec that skips the blend lookup. Looks ugly but the G550 then runs at the same speed as the G400 in that 3DMark2000 test. I don't know if this stipple mode is toggleable anywhere in the Matrox tools or registry settings, wasn't aware that anything but the G100 had it. And now that I think about it, I wonder whether it can be toggled off on the G100.
The attachment g550-stipple.png is no longer available
That said, I didn't test on the G400, maybe the stipple patch would speed that up as well. But if the issue is alpha blending, overclocking the memory on the G550 may be enough to reach parity with the G400 in most if not all games. The memory chips on my G550 are rated for 200 MHz and I remember from past tests that upping the G550 clocks 133 -> 166 on core and 166 -> 200 on memory put it above the G400 in just about every game. Can't remember if I ever tested overclocking just the memory without the core, but in any case it's not overclocking technically because the chips are still running within spec. I think I've seen 5 and 5.5 ns rated on the AGP G550, maybe 5.5 wouldn't quite be fast enough.
Reply 98 of 123, by vvbee
With some more analysis, Claude Code's working hypothesis comes down to SDR vs DDR latency in switching between writing and reading. So that's why lots of alpha blending slows down the G550, and maybe the G450 as well, more than the G400. And maybe there's some other conditions at play, like polygon size when alpha-blended. I'll believe that as a hypothesis.
There was confusion at some point on Vogons about overclocking the G550, so I had Claude write a Win 9x/Me tool for it. The UI is shit but I won't bother cleaning it up now, the functionality matters. Tools like Everest may or may not misreport the G550 clocks, this one may or may not be more accurate. Available from leikareipa.github.io. Free, no warranty, not fit for purpose, use at your own risk, tested briefly on my own G550 but your mileage may vary, etc. Doesn't change memory timings.
The attachment g550oc.png is no longer available
On my G550 with 5 ns memory chips it looks I can keep the core at stock while raising the memory up to max spec, and on a brief test this gives similar performance as the G400 in 3DMark2000 in the worst case scenario. Overclocking the core a little helps too but maxing out the memory looks to be most of the difference, without having done the actual benchmarking to be sure.
Reply 99 of 123, by vvbee
The G550oc utility was cleaned up. Available from leikareipa.github.io. Free, no warranty, not fit for purpose, use at your own risk, tested briefly on my own G550 but your mileage may vary, etc. Audited by Claude Fable 5.2 against specs, datasheets, drivers, BIOSes etc., brief conclusion: checks out but don't use together with other overclocking tools on the G550, keep memory above 150 MHz ideally, and reboot if issues setting clocks were reported.
The attachment g550oc2.png is no longer available
Tests in 3DMark2000 relative to the G400 at 800 x 600 16-bit:
The attachment 17aa74b12c70.png is no longer available
On a G550 with 5 ns memory chips, the core speed can be kept stock while upping the memory to what it's rated for, or 198 MHz in this case. That alone makes the G550's Direct3D performance better than the G400's in most cases while remaining slower in a few. I think most G400 come with 6 ns memory, some with 5, and in the latter case you could get an edge, but even then the G400 will probably tend to lose when multitexturing is used. Upping the G550 clocks to 158/198 makes it considerably faster than the G400, only being somewhat slower in the texture test; probably somewhere in the G400 MAX ballpark depending on the game etc.
A G550 with 5.5 ns memory chips probably can't do 200 MHz on memory, only rated for 180. The core can't be kept at stock while maintaining 180 on memory due to how the dividers work, so the closest options are 120 and 144 MHz on the core. Overall, a G550 with 5.5 ns chips isn't ideal.
Temps with no airflow were around 57 C on the heatsink at stock and 62 C at 158 MHz, and the memory was around 60 C at 198 MHz.
