Reply 80 of 85, by DLL hell
DLL hell wrote on 2026-03-27, 17:48:
Out of the box dx8 Lite won't work with dx8 Game, any advice
My win nt 4.0 sp6a roll up setup is Intel 865g, Pentium 4 northwood and 512 ram, graphics card is the Intel integrated extreme graphics 2
Reply 81 of 85, by rmay635703
Need to get PAE 64gb working on all NT versions including 3.1 and 2k
Then get Supermium browser up and running on all NT versions
Reply 82 of 85, by shadowmage
wierd_w wrote on 2026-03-24, 21:02:
I figured it would work. […]
shadowmage wrote on 2026-01-24, 23:38:
Here it is: https://youtu.be/3FYarwJOp9k […]
the3dfxdude wrote on 2025-04-06, 14:31:
When D3D on top of OpenGL work was beginning, the devs were using the best Nvidia cards at the time. I think the minimum version of OpenGL ended up being 2.0, and I remember that version 1.5 was kind of dodgy. What is the best you can do with NT4.0? OpenGL 1.1? Maybe there are newer vendor provided drivers that come close. Sorry, I don't think I've ever done OpenGL with NT 4. I doubt anyone thought about testing and make working Wined3d on NT 4.0 for what limited set is available. It will be interesting to see.
Here it is:
WineD3D works on Windows NT 4.0. 3DMark 2000 score - 21422. Unfortunately I couldn't make it work on Windows NT 3.51.
What was the ogl igp version?
It may be 'plausible' to use mesa for windows as a shim, hook the graphics card's IGP for everything that *can* be run on hardware, then using mesagl to supply missing features to reach OGL 2.0 feature level.
It’s the QEMU OpenGL passthrough, which directly exposes the host’s NVIDIA RTX 4060 Ti driver to the Windows NT 4.0 guest, providing full OpenGL 4.6 support.
Direct3D 9 benchmark 3DMark 2003 also works on Windows NT 4.0. Here is the video:
https://www.youtube.com/watch?v=gtvmWzg15I8
You can use Mesa9x (JHRobotics) with WineD3D to run 3DMark 2000 on Windows NT 4.0, but since it's CPU-based, it’s much slower.
Reply 83 of 85, by wierd_w
shadowmage wrote on 2026-03-27, 23:11:
It’s the QEMU OpenGL passthrough, which directly exposes the host’s NVIDIA RTX 4060 Ti driver to the Windows NT 4.0 guest, provi […]
Here it is:
At least on linux*, Mesa3d can pass hardware supported functions through, and only process hardware unsupported functions as software.
I was considering 'older ICD' + MESA, where the OpenGL 1.5ish drivers of yore provide a big chunk of the pipeline, with lighting and shadows done as renders to textures by mesa.
Would still be slow, but not as slow as mesa doing all the lifting.
Reply 84 of 85, by shadowmage
wierd_w wrote on 2026-03-28, 14:06:
At least on linux*, Mesa3d can pass hardware supported functions through, and only process hardware unsupported functions as sof […]
OpenGL passthrough via QEMU also works on Windows 10, not just on Linux.
Here are some examples:
- Half-Life 2 running on a Windows 98 VM (host OS: Windows 10 1809):
https://youtu.be/R59aYcJxrGc
- Doom 3 running on a Windows 98 VM (host OS: Windows 10 1809):
https://youtu.be/R_ZtCmAYSUw
WineD3D is a wrapper, so it's possible it could also work on older GPUs. Someone already tried using WineD3D on Windows 98 with a Quadro FX 4500 GPU:
SoftGPU: OpenGL + DirectX + Glide driver for Windows 95/98/Me
Reply 85 of 85, by digger
Seeing 3dMark 2003 run with DX9 hardware acceleration and high frame rates in NT4 is really impressive. That would have been unthinkable back in the day.
I applaud everyone who worked on getting it working so well!
