GLX Player the only XT player ? Check Mod Master...
Reply 920 of 932, by FreddyV
audiocrush wrote on 2022-10-02, 00:56:
Hi, is there any special trick to run this software properly? I can't seem to get anything but crackles and pops out of this sof […]
Hi,
I can't seem to get anything but crackles and pops out of this software.
Does it require special hardware requirements like specific display modes or a minimum amount of memory?
My system has got a 8088/8087 that I can run from 4,77MHz to 10MHz, 512k of ram and a Soundblaster 2
Hi,
On this machine, you can expect 14KHz at 4MHz or 26-30KHz at 10MHz for a 4 channel module.
The pop can be due tothe fact that the volume is too high, then there is overflow.
Your SB2.0 probably have a problem ?
Reply 921 of 932, by audiocrush
MobyGamer wrote on 2022-10-02, 04:03:
I can run modmxt on my PC (4.77 MHz, Sound Blaster Pro) just fine. It should run on yours, and sound great at 10 MHz too. What settings (port, irq, dma) is your soundcard set to? Do you have a BLASTER environment variable set up that matches the settings, and does modmxt show those settings on startup?
For an additional successful test, run "modm" as it is lighter on memory usage, and use a simple 4-channel .MOD file for your first test to ensure the software is working.
Hi,
the SB2.0 is set to IRQ5, IO address 220 and DMA channel 1. These are also set in the blaster variable.
Is there maybe more ideal values for those, provided they're not conflicting with the rest of my hardware 😁
The card appears to work fine, since the soundblaster compatible games produce very clean sound.
@FreddyV
It is not just some pops, the music is not audible at all. Pops and crackles are literally the only thing that come out of the soundcard when I use Mod Master.
I just don't know what I'm doing wrong.
I even went down with the sampling rate to 8KHz but I can't even hear the melody through the noise. Also the user Interface becomes very unresponsive during playback, so I usually reset the machine to exit the program.
https://www.nerdsh.org/ - my blog, a bit neglected though
https://www.youtube.com/channel/UChsU6woi3lhLhtT_ILbSCCw - Some videos of mine
Reply 922 of 932, by root42
Can you please show the exact contents of the BLASTER variable? echo %BLASTER%
I remember having the wrong or no T value a long time ago and ModMaster became a bit confused by that.
YouTube and Bonus
Reply 923 of 932, by FreddyV
Try to delete modmxt.cfg
Reply 924 of 932, by FreddyV
root42 wrote on 2022-10-06, 05:53:
T is no more used
Reply 925 of 932, by root42
FreddyV wrote on 2022-10-07, 12:40:
T is no more used
Thanks! Noted!
YouTube and Bonus
Reply 926 of 932, by RetroFletch
Im trying to use this program with a picoGUS, it detects it and i can play midi with other programs but when i try play with this i get a "hardware initialization error - MPU dosnt answear" error and then i cant exit out and have to restart pc, maybe its just a configuration issue but i cant find anything in the textfiles or in this thread about it, any ideas?
i have started ultramid and initiated the picogus.
i have verified that when running dosmid.exe standalone with the /gus option it works just fine, i tried to pass this parameter using the dosmid.cfg file but it seems xt player ignores this and it goes to mpu mode =/
EDIT: Solution found
it seems Mod Master XT 1.0 is hard coded to run dosmid like this "/noxms /mpu" simply editing the exe file and replacing /mpu with /gus and now it runs in gus mode.
Also removed the /noxms as that prevented me from loading large midi files.
now i got a setup that works well enough, great software! only issue seems to be button controls seems to be overwritten for dosmid, luckily i can still skip to next song with esc ( should be enter ). and i cant seem to get back into modmaster XT to select different songs but its ok 😀
Reply 927 of 932, by FreddyV
RetroFletch wrote on 2023-06-17, 20:36:
Im trying to use this program with a picoGUS, it detects it and i can play midi with other programs but when i try play with thi […]
Hi,
Thanks for the test.
Yes, the DOSMID Support is really experimental, it is done more for fun than real use 😀
Reply 929 of 932, by OPLx
Nice! 👍
Reply 930 of 932, by zb10948
Can I ask to compare performance limits on a very low end systems? 😀
NEC V20 @ 7.15 MHz, Orpheus 2 LT, "space_debris.mod" plays in 20kHz stereo SbPro2 mode, UI gets a bit unresponsive here and then, but no stutters ... I think this is the limit.
Are you all getting more headroom on your turbo XTs or is this the nominal performance?
Reply 931 of 932, by zb10948
@FreddyV I've ran about dozen hours on various stuff. I must say this piece of software has rejuvenated my old XT and gave it purpose. Can't say enough good words about it. Everything seems perfect 😀 Looking into reusing your code to start a XT tracker project. The current main branch on MODMXT github corresponds to version 1.0?
I see versions 1.1 and upcoming 1.2 mentioned. What goodies/fixes do they bring? 😀
Btw. encountered few situations with S3M modules. F.e. one 8-track S3M plays OK for first 2-3 secs, but then it goes all out white noise. Lowering freq doesn't matter. Version 1.0 xt-lite flavour.
Reply 932 of 932, by FreddyV
zb10948 wrote on 2025-06-07, 12:01:
Hi,
I did tiny mix speedup, then correct bugs on the Tandy VGM replay.
Now working to add Mindscape music board VGM support as I added Mindscape emulation on the PicoMEM 😀
I Work on on Mod Master during around 10 years, so it is a mix of Mess and optimized code.
