Reply 940 of 1106, by snipe3687
- Member
ErroneousHyphen wrote on 2024-10-05, 08:22:So hoping for some assistance or advice! Due to being quite busy I started my weecee build quite some time ago, and then had to […]
So hoping for some assistance or advice! Due to being quite busy I started my weecee build quite some time ago, and then had to leave it for a while before I finished it off (last few resistors etc.) just today! I was actually considering buying that one that was on ebay relatively recently, and am now severely regretting it as unfortunately I appear to have not done something correctly, and I dont really have a lot of time to troubleshoot, so!
finished off my weecee, hooked it up, and it looked good to start with. The COP unit lit up, the keyboard lit up, and after a short while, the ethernet port lit up as well, but, I didnt appear to be getting any image from the unit (this is running through an RGBs SCART/AV/VGA > HDMI converter that I know to be working) I checked continuity from the pins on the board for VGA to the end of my VGA cable and all had correct continuity.
Unfortunately in the process of unplugging it and troubleshooting, I ripped the USB power port off the board.
If anyone has any thoughts on where to start looking for whats up with it, that would be greatly appreciated. If anyone is in NSW Australia and would have the time to look at it and fix it for me (with payment), even better. Failing all that if someone is selling one, but I think I want to get this one going.
Have you checked your soldering on the header that attaches the SOM to the board? sometimes, even if they look solid, it's possible there's a bridge somewhere or it's not fully connected. also, make sure the connectors on the bottom of your SOM are in good shape. I've seen them break before even if you're being careful.
good luck!
