First post, by jabbamonkey
I cant seem to get Privateer 2 to work on my computer. I read on the DosBox site (and an earlier post on this forum) that the game can only be run using an earlier. So, I downloaded and installed DosBox 0.61 ... however, it isnt working.
I also tried to follow someone elses post, but the posting just stopped with no resolution.
So, at this time, I wanted to appeal to those of you out there for help. When I run the game, DosBox starts up, and the game begins to load ... and then, when the game is done loading the "..........." across the screen, the program crashes.
I am on a decent computer (Pentium 3 3Ghz, 1GB memory, plenty of HD space, running Windows Media Center edition)
Here is my configuration file for DosBox 0.61
# Config file created by Boxer Version 0.61.6
[sdl]
fullscreen=true
fulldouble=true
fullfixed=true
fullwidth=800
fullheight=600
output=surface
hwscale=1.00
autolock=true
sensitivity=100
waitonerror=true
[dosbox]
language=
machine=auto
memsize=32
[render]
frameskip=0
snapdir=C:\
aspect=false
scaler=none
[cpu]
core=dynamic
cycles=30000
cycleup=10
cycledown=10
[mixer]
nosound=true
rate=22050
blocksize=16384
wavedir=C:\
[midi]
mpu401=false
[sblaster]
sblaster=true
base=220
irq=7
dma=1
sbrate=22050
adlib=false
cms=false
[gus]
gus=false
[speaker]
pcspeaker=false
disney=false
[dos]
xms=true
ems=true
[modem]
modem=false
[autoexec]
Reply 1 of 3, by gulikoza
Find a patch for Privateer2...might help.
Reply 3 of 3, by J.B.
These Settings work for me. You may also need a patch from here: http://www.wcnews.com/files.shtml#wcpriv2
I can't get the joystick to work though. Has anyone else?
[sdl]
fullscreen=true
fulldouble=true
fullfixed=false
fullresolution=Default
output=overlay
hwscale=1.00
autolock=true
sensitivity=100
waitonerror=true
priority=higher,normal
mapperfile=mapper.txt
[dosbox]
language=
machine=vga
captures=D:\Programme\emulation\DOS\D-Fend 2\Capture
memsize=16
[render]
frameskip=2
aspect=false
scaler=normal2x
[cpu]
core=normal
cycles=50000
cycleup=500
cycledown=500
timesynched=true
showcycles=true
[mixer]
nosound=false
rate=22050
blocksize=2048
prebuffer=10
[midi]
mpu401=true
intelligent=true
device=default
config=
[sblaster]
type=sb16
base=220
irq=5
dma=1
hdma=5
mixer=true
oplmode=auto
oplrate=22050
[gus]
gus=true
rate=22050
base=240
irq1=7
irq2=7
dma1=3
dma2=3
ultradir=C:\ULTRASND
[speaker]
pcspeaker=true
pcrate=22050
tandyrate=22050
disney=true
[dos]
xms=false
ems=false
