First post, by vetz
I have the same issue as mentioned in this old thread: Brent Inverson EA's Flight sims - Issues with 4 axis joysticks (LHX, CYAC, SU25)
The game have a JTUNER.EXE program to help calibrate (trim) your joystick. When you have a 4 axis joystick it seems that you need to select JOYSTICK 2, because if you select JOYSTICK 1, your normal X and Y axis won't work. Instead the hat switch and the Z axis will respond. Unfortunately the games do not allow you to select Joystick 1 or Joystick 2, so you're completely screwed
Was there ever a newer version of LHX that works with 4-axis joysticks (that is the case with Chuck Yeager which uses the same engine), or is there a way to force use of joystick 2 (or swap the axis)?
I don't own a 2-axis joystick. Currently using a Microsoft Sidewinder 3D Pro for DOS gaming.
Reply 1 of 6, by carlostex
It’s a pity, i never found a solution to this, nor i ever bought a 2 axis joystick. I also a 3D Pro joystick
Reply 2 of 6, by appiah4
Can't you use a Gameport Y cable and a dummy DB-25 adapter to emulate a Joystick 1 to get around the issue? I'm pretty sure this can also be done in software if someone tried. It can definitely be done in emulation..
Reply 3 of 6, by vetz
appiah4 wrote on 2024-04-25, 11:05:
Not sure I quite understand what you mean here. Could you elaborate?
Reply 4 of 6, by appiah4
vetz wrote on 2024-04-25, 13:02:
You know these Y cables for game ports?
We used to use them for playing multiplayer games. You could get one of these, and theoretically attach a DSUB with some kind of terminator in it to one end that would fool the system into thinking there is a joystick there. Then the 4-axis joystick would be detected as Joystick 2.
How that terminator could be done is beyond me but theoretically it will just have to make it look like a joystick is there, which shouldn't be too difficult.
Reply 5 of 6, by vetz
I see what you mean, but I can't see how that will solve the problem. The game automatically selects Joystick 1 and that can't be overridden. The 4-axis joystick is detected as 2 joysticks, one for each for the axis, so then I'd figure the 4-axis joystick would be detected as joystick 2 and joystick 3.
Reply 6 of 6, by appiah4
vetz wrote on 2024-04-26, 11:45:
OH, I get it now! I'm sorry I completely misunderstood what you are saying *facepalm*
