First post, by Kouwes
I have the very first released PAS16 and while installing it in a pentium 166MMX system I noticed that the audio cable connector has 5 pins?? 🤔
Since I’m going to use this PC for DOS games only it doesn’t really matter but my OCD forces me to connect an audio cable 😄.
Of course I could just go and try different cable positions but maybe someone knows the pinout on the card?
Reply 1 of 3, by PD2JK
Should be like this. 😀
12.93 KiB
i386 16 ⇒ i486 DX4 100 ⇒ Pentium MMX 200 ⇒ Athlon Orion 700 | TB 1000 ⇒ AthlonXP 1700+ ⇒ Opteron 165 ⇒ Dual Opteron 856
Reply 2 of 3, by Kouwes
Well that helps..thanks!!!!
Not quite my card but the audio connector is.
    1.57 MiB
Reply 3 of 3, by Shponglefan
I've run into the same thing with PAS16 cards. No idea why they decided to use a 5 pin connector, but it does make for extra work to deal with.
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
