First post, by Jonsmith0815
Onboard USB on my Foxconn X58 Flaming Blade board with X5675 CPU is not working perfectly and crashes at certain times and settings.
Motherboard is not supported and has no drivers for 98. However it works stable after a fresh install and rloew patchmem.
GPU is 7900GTX stable with patched 82 drivers and rloew nvcore driver patch for 256MB.
Sound is not working so far, Audigy 2ZS blue screens after installation on startup.
USB 1.1 is working with NUSB36 drivers when 2.0 is disabled in bios.
USB 2.0 installs fine if no USB was installed before, but hangs on startup screen, until it is uninstalled from device manager in safe mode or disabled in bios. After that it reinstalls fine but again hangs after reboot.
USB devices are only zowie EC1B gaming mouse and ducky 2SF keyboard on a noname 2.0 hub/usb switch.
Reply 1 of 1, by Jonsmith0815
Sound is working using these instructions:
[OUTDATED] Installing Windows 9x and DOS drivers on Audigy cards (version 3.1)
System is stable running CS1.5
USB still only at 1.1
I suspect IRQ problems with USB 2.0, as there seem to be many USB 2.0 devices in device manager when enabled, and many different IRQ, both more than when using USB 1.1 only. I also tried disabling most USB 2.0 devices in device manager but that works only a few times until it hangs again at start up.
How could I manually set IRQs to avoid conflicts?
