First post, by Matrolisk
I have an Asus K7M motherboard that was pulled from a known working system.
When I power it up now the HP logo image will display but that's all. I also can't get into the bios setup either.
I was using a newer psu but swapped to it's original to test that with no change.
I've tried swapping the ram but that didn't work.
I've reseated the slot cpu.
I pulled and reinserted the clock battery and shorted the pins to clear cmos.
I'm not sure what else to try.
That computer it was in had not been used in a while but booted fine the last time it was used.
Reply 1 of 5, by PD2JK
Can you flash a BIOS image from Asus into the EEPROM? Maybe the POST shows something useful, or even resolve the issue just by reprogramming it.
Any beeps from the PC speaker?
Or get a (proper) diagnostic card.
i386 16 ⇒ i486 DX4 100 ⇒ Pentium MMX 200 ⇒ Athlon Pluto 700 ⇒ AthlonXP 1700+ ⇒ Opteron 165 ⇒ Dual Opteron 856
Reply 2 of 5, by Repo Man11
I've had systems hang on the POST screen when there is an IDE cable plugged in to a dead IDE drive or a drive that doesn't have power. One of many reasons to pull the board and strip it down to the bare minimum when troubleshooting.
Reply 3 of 5, by Matrolisk
PD2JK wrote on 2024-04-27, 16:38:
Unfortunately I don't have an eeprom programmer.
I get one beep, which I believe means all good. I did get a memory error beep which trying out other sticks but the original one doesn't cause that.
I might need to buy a card.
Repo Man11 wrote on 2024-04-27, 19:06:
Currently all that is connected is
CPU - AMD - Athlon 1000 (AMD-K7100MNR53B A) - Original
One stick of ram which is the orignial
GPU - XFX Geforce 4 TI 4200 - I did try the original but no change.
Reply 4 of 5, by rasz_pl
Matrolisk wrote on 2024-04-27, 19:23:
that would mean post finished, post card wont help you in that case
hmm is your keyboard working?
https://github.com/raszpl/440BX Reference Design adapted to Kicad
Reply 5 of 5, by Matrolisk
The keyboard is a ps/2 one which I know works.
The Caps, Scroll, and Num Lock lights turn on/off when their key is pressed.
