First post, by BEEN_Nath_58
It was where I learnt firing headshots... When I was 8.
What I remember is it had no hostage missions...it was either a full squash match (fy?) or most probably a bomb match (de). I remember it stood in the maps list after cs_747 but before maps like de_aztec.
The theme was blue (similar world colours like fy_iceworld), the walls were probably made of snow.
There were two rooms one after another for each side, outside which you had only the walls and stairs which connected both the CT and T sides. There were multiple stairs connecting both sides, the spawn areas were in much higher altitude then the lowest point you can get with stairs. As you can imagine the map was small.
Could anybody recall?
Reply 1 of 4, by Fujoshi-hime
as_tundra?
Reply 2 of 4, by BEEN_Nath_58
Fujoshi-hime wrote on 2024-04-29, 20:46:
as_tundra?
No it was not tundra. But the environmental colours were very similar. The map was very symmetrical
Reply 3 of 4, by momaka
fy_snow??
At least I think that's it.
I used to play that one and iceworld a good deal at the time, partially because the server I frequented would regularly go through these.
My favorite FY map by far is fy_pool_day, though.
Reply 4 of 4, by BEEN_Nath_58
momaka wrote on 2024-05-16, 23:29:
fy_snow?? At least I think that's it. […]
fy_snow??
Not fy snow. The map is significantly larger. I suppose it was a de map after all. Color theme was same
