First post, by PlaneVuki
Hello
I made ramdisk 11mb using dos5.
I tried 32mb edo ram. When I check ram using mem.exe it reports that:
31mb extended memory exist, 4.2mb available XMS memory (as normal ram). And my ramdisk is 10.8mb.
31mb - 10.8mb - 4.2mb available = 16mb seems to be missing. What hapened to remaining 16mb ram?
How can I make this to work using 16mb ram instead of 32mb. Why 16mb of ram is wasted?
(or, equivally, I want to be able to make bigger ramdisk and have more available ram using 32mb edo ram)
Here is current config.sys (booting from floppy ms-dos 5.0, pure boot, only below config.sys parameters used, no autoexec.bat):
DEVICE=A:\HIMEM.SYS
DEVICEHIGH=A:\RAMDRIVE.SYS 11000 /E
Reply 1 of 3, by rasz_pl
>486
> And it worked.
source of your problems might be:
> edo ram.
https://github.com/raszpl/440BX Reference Design adapted to Kicad
Reply 2 of 3, by PlaneVuki
rasz_pl wrote on 2024-05-02, 13:14:
>486 > And it worked. >16mb seems to be missing […]
>486
> And it worked.
> edo ram.
What problem can be? Both amounts of ram (16mb stick, and, 16+16mb) are recognized in POST.
And like I wrote above, mem.exe recognizes 31mb extended memory.
Reply 3 of 3, by Grzyb
I wouldn't trust DOS 5.0 with such amounts of RAM.
Try 6.20 and/or 7.10.
In 2003, I voted in favour of joining the European Union. However, due to recent developments - especially the restrictions on cash usage - I'm hereby withdrawing my support. DOWN WITH THE EU!
