First post, by PlaneVuki
Hi.
Recently I had a wish to run doom from ramdisk on a 486 mobo without L2 cache chips. (Case4 below)
The mobo is Chaintech 4ULD0 with umc chipset.
(Similar to this one https://theretroweb.com/motherboards/s/chaintech-4uld1)
Here is what happens:
Case1:   L2 present + hdd = doom works
Case2:   L2 present + ramdisk = doom works
Case3:   L2 removed + hdd = doom works
Case4:   L2 removed + ramdisk = doom is installed ok but fails to start, freezes on black screen.
(In all above cases setting L2 on/off from bios made no difference).
Why doom not starting in case4 and what can I do to fix this?
I am thinking about cases where fake L2 caches are used, are they just plain empty or do they short some pins of the socket?
Any further required information I can provide.
Thanks.
