First post, by luke7110
Hi all, I'm trying to repair a Monster 3D with storage damage. Some traces were cut and smd components damaged. They may need to be replaced.
Is there a component map for this card ?
Capacitors C43 and C84
The attachment Monster 3D PCB .jpg is no longer available
The attachment Monster 3D 01.jpg is no longer available
The attachment Monster 3D 02.jpg is no longer available
The attachment Monster 3D 03.jpg is no longer available
The attachment Monster 3D 04.jpg is no longer available
Reply 1 of 28, by sdz
C43 and C84: 10nF 25V 0805
Reply 2 of 28, by luke7110
Thanks !! 😊
Reply 3 of 28, by sdz
You're welcome! Good luck fixing the card!
Reply 4 of 28, by luke7110
Yeah, I think I'll need a good technique to fix these traces neatly 😅
Reply 5 of 28, by sdz
-scrape the soldermask off a bit, apply flux and tin the traces with solder.
-take a small diameter wire, apply flux, tin it.
-apply some more flux on the board and solder the wire in, trim excess wire with a scalpel blade after soldering
-clean with IPA
-optional apply UV curable green soldermask
Reply 6 of 28, by appiah4
luke7110 wrote on 2024-05-07, 13:07:
Check out Bits und Bolts videos on YT for very good trace repair examples. Necroware also has some very good repairs documented.
Reply 7 of 28, by luke7110
sdz wrote on 2024-05-07, 14:00:
-scrape the soldermask off a bit, apply flux and tin the traces with solder. -take a small diameter wire, apply flux, tin it. -a […]
-clean with IPA
Thanks for the guidelines, what do you advise for the wire ? I saw people using a wire taken from an unsoldering braid.
appiah4 wrote on 2024-05-07, 14:01:
I'll check it out, thanks ! 👍
Reply 8 of 28, by sdz
Just a single strand from multistrand conductor. Seems easier to me than pulling a wire from a piece of solder braid.
Reply 9 of 28, by luke7110
Ok thanks. I'll also order some green soldermask, never used it before, until now. I think it will protect and consolidate the rework.
Reply 10 of 28, by technokater
You might need to get UV light for that as well. The solder masks I used so far needed UV light for curing. If you haven't one already. It is generally written in the spec if you need UV for your particular mask.
Reply 11 of 28, by appiah4
I just use transparent nail polish instead of solder mask..
Reply 12 of 28, by luke7110
technokater wrote on 2024-05-07, 16:25:
I have an eprom eraser, it should work?! 🤔
Reply 13 of 28, by technokater
I use an UV flashlight that's not very powerful and consistent in illuminating but it works, so I think yours will work too.
Reply 14 of 28, by luke7110
technokater wrote on 2024-05-08, 07:04:
Ok, I'll keep you posted ! Thanks 😉
Reply 15 of 28, by luke7110
Bits und bolts ... a real gold mine!
However, I think I'll begin with some nasty wire bridges in order to see IF the card could be repaired, then I'll do it the fancy way 😎
I read that windows install with previously installed Voodoo2 drivers could make interferences with drivers and prevent a voodoo 1 card from working. Do you agree with that ? I only have Voodoo 2 cards and therefore voodoo 2 configured retro pcs, so I maybe should reinstall a clean windows 98 before trying to do a diagnostic ?
Reply 16 of 28, by Thermalwrong
That's my experience with switching between a Voodoo 1 then a voodoo 2 and back again. The computer would freeze on a turqouise display when trying to switch to 3d mode.
I ended up doing a clean install and now run 2 separate compact flash cards on that test computer to go between V2 -> V1
See my post here: Re: 3Dfx Voodoo 1 - Low level hardware information and diagnostics thread
You can verify by running tomb raider in DOS which isn't tied to the Windows drivers in the same way.
So either clean install or 100% clear out the V2 drivers before putting the V1 back in, as in search the windows folder for every file in the Voodoo 2 driver folder and delete that before proceeding.
Reply 17 of 28, by luke7110
Oh yeah, thanks, this was the post I read about the driver incompatibility. I'll do a clean install just to be sure, on a spare drive (I must have one somewhere!) Thanks 😉
Reply 18 of 28, by luke7110
Anyone could advise a good green solder mask ? Can't find anything on reputable sites (rs, farnell, etc...) and only find chinese seringues on amazon with bad feedbacks about fluid not correctly drying nor sticking to the pcb ...
Reply 19 of 28, by luke7110
I think i'll also recap all the smd electrolytics on the cpu side. Anyone knows their specs ?
Thanks !
