First post, by vglover2005
This game works great with the new patch and fixes alot of client side and server issues for the multiplayer aspect, (the CD KEY Authorization) problem as well.
Now the only problem I experienced is when I get to the map called Island Estate Or PearlCastle, the map does not want to load at all. It just goes back to the Campaign mode. I dont know why there are 2 names for this map.
When you try to use this map in a multiplayer session, the server will NOT load the map and return an error. I dont know what the error is since when the error does occour, the window closes immeditely.
Has anyone else experienced this or is the map corruped? Thanks
