First post, by Yoghoo
Got a MSI K7T Turbo2 motherboard which I repaired (had a missing SMD) and added an ISA slot onto. More information about this motherboard can be found here: https://theretroweb.com/motherboards/s/msi-ms-6330-ver-5.0.
It worked great for a couple of weeks but suddenly it does not read floppy disks correctly anymore. Sometimes it will list the files (but nothing more) but even this takes longer then usual. Most of the times though it will just error out when trying to access it (cannot read disk etc). It will also corrupt the image files on the USB stick if using a Gotek. I did the following to try to narrow it down:
  • Tried in Windows 98SE and DOS
  • Used a Gotek and a real floppy drive (1.44MB)
  • Used multiple different floppy cables
  • Tried another PSU
  • Checked BIOS settings
So the problem lies somewhere on the motherboard. Everything else is working fine btw (sound cards (1 ISA and 1 PCI), AGP video card, 2 DVD/CD drives, PATA2SATA SSD etc).
So the question is what has failed on the motherboard? What chip is responsible for the floppy? Anyone has any idea to debug this further?
Reply 1 of 13, by Yoghoo
Forgot to add that when I enable the "Boot Up Floppy Seek" BIOS option, which I normally always leave disabled, I now get a "Floppy disk fail(40)" error. Pressing F1 and continue to boot it will give the same symptom as I described above. Normally that indicates no floppy drive or cable not connected correctly but that is not the case.
Reply 2 of 13, by Deunan
AFAIK it's the south bridge job, and it looks to be a BGA chip. Could be dying, could be cracked solder balls. Put the mobo on a flat surface and press the chip with your finger - see if that helps any. If there is a change in behaviour you need to reflow that BGA.
Reply 3 of 13, by rasz_pl
that was my guess, try tracking floppy connector further and check continuity, maybe there is a crack somewhere along the way.
https://github.com/raszpl/FIC-486-GAC-2-Cache-Module for AT&T Globalyst
https://github.com/raszpl/386RC-16 memory board
https://github.com/raszpl/440BX Reference Design adapted to Kicad
https://github.com/raszpl/Zenith_ZBIOS MFM-300 Monitor
Reply 4 of 13, by Yoghoo
Deunan wrote on 2024-05-10, 17:08:
Just tried that but unfortunately that didn't change the behavior.
rasz_pl wrote on 2024-05-10, 17:29:
Going to do that tomorrow (if time permits). But had a good look already earlier when I did the repair work. So not to hopeful I will find anything new.
Reply 5 of 13, by Deunan
If BIOS shows floppy error only when seeking is enabled you can limit your search area quite a lot. All the BIOS does is step 43 times in and then out, checking the track 0 sensor output. This lets it detect 40-cylinder drives (360k). So the only signals used are drive select, motor on, direction, step and track 0 (that's input). Everything else doesn't matter.
BTW I never had it happen to me but it's possible for the floppy cables with twist to go bad at the twisted section (the cable is too thin and pressed to hard in factory, wires break inside). Try straight cable or the non-twisted connector and either set the drive to B: (if only to test) or there might be a drive letter swap option in BIOS.
Reply 6 of 13, by Yoghoo
Deunan wrote on 2024-05-11, 09:52:
Found the issue. What I didn't test yet was to remove all cards (USB, network, sound cards). When I did that the floppy drive suddenly was working again. Then added them one by one and it seems the ISA sound card is causing this issue. Had to suspect this earlier as I had issues with sound suddenly not working when playing a game with an ALS100 card but thought it was a broken card. When replacing it with a ES1868F everything was working at first.
Sound card is still working correctly (with standard values IRQ5 A220 DMA1+DMA0). Only the floppy drive is not working anymore when the ES1868F card is inserted now. As the floppy drive is using IRQ6 and DMA2 there shouldn't be any resource conflicts.
So a bit puzzled at the moment. Anyone got an idea what could cause this? Will do a continuity/voltage test on the ISA slot tomorrow. But I have no idea how to measure the floppy connector on the motherboard though. So some hints (without oscilloscope) are appreciated.
Reply 7 of 13, by Deunan
Is this a sound card with extra IDE interface (for CD-ROM)? Is it disabled properly?
Reply 8 of 13, by Yoghoo
Deunan wrote on 2024-05-12, 15:32:
Both the tested ASL100 and ES1868F have an extra IDE interface. I disabled them on both with their config tools.
Also just now measured the ISA connector and all voltages are within range. Also did a continuity test and so far everything seems ok.
*EDIT* Also added an ALS4000 PCI card (with IRQ5, DMA1, A220) and with that the floppy drive is also working. Didn't do a DOS sound test yet.
Reply 9 of 13, by Yoghoo
Forgot that I had a cheap oscilloscoop so took a look at the RDATA, MOTEA#, DRVSA pins on the floppy connector with and then without an ISA card. Unfortunately the signals are exactly the same. So I am out of ideas what the problem could be. So will be going with the ALS4000 PCI sound card for now. Not a bad DOS card at all but not what I had in mind.
Reply 10 of 13, by Deunan
So it doesn't work with either ISA card? But does work with PCI? Perhaps it's some sort of PnP issue, did you try manual assigment of the sound card IRQ/DMA to ISA in BIOS?
Or perhaps it's a some weird ISA slot problem, like maybe something got into one of the slots and is shorting DMA1 and DMA3 signals for example (or IRQ with either IRQ5 or IRQ7).
Reply 11 of 13, by Yoghoo
Deunan wrote on 2024-05-13, 13:10:
I always do a manual reservation in the BIOS (if possible). Checked for shorts yesterday and took a good look as well. But no shorts are found. ISA socket is brand new and was soldered on the board as the motherboard lacks it normally. This mod has been done successfully before by other members on Vogons. I thought it was maybe a bad solder job but after intens investigation yesterday I can't find a problem. No shorts and voltage are in range.
Reply 12 of 13, by Deunan
Ah, so ISA slot was added later. I gave the photo another look, there's a few resistor packs near the ISA - are all of those populated on your mobo? I was wondering if there is perhaps a missing pull-up (or pull-down) for the IRQ or DRQ lines.
Another possibility is the BIOS, since it's not expecting to have ISA slot installed perhaps there are some internal chipset registers not set up correctly. This might be somehow affecting IRQ/DMA routing from the slot and the internally emulated floppy controller. It's a wild guess but I don't have other ideas.
Reply 13 of 13, by Yoghoo
Deunan wrote on 2024-05-13, 15:38:
It was working for a couple of weeks. So the BIOS supports it. Also other Vogons members used the standard BIOS.
I checked the motherboard before and all was there. But I didn't measure them so will do that in the future. For now I put it on the backlog as I am a little fed up with it. 😉
