First post, by winuser3162
i have a few TNT2 m64 cards and was wondering how they compared to a voodoo 3 2000.
i have been having a hard time finding information of this particular comparison online.
both cards have the same amount of SDR memory (16 MB) and both have 2 TMU's.
the Voodoo 3 2000 only has 1 ROPS and 1 Pixel Shader but has a 128 bit bus while the TNT2 m64 has 2 ROPS and 2 Pixel shaders but only has a 64 bit bus.
the memory on both cards are clocked at 143 MHZ while the TNT2 m64 chip is clocked at 125 MHZ, the voodoo 3 2000 is clocked at 143MHZ
I haven't been able to run any benchmarks yet as i don't yet have both cards.
i suppose a big factor in this comparison could be the API these cards run.
1. Silicon Graphics octane, 2GB memory, MXE graphics board, 2 350MHZ R12K
2. Silicon graphics indigo 2, extreme graphics board, 198MB memory, 200 MHZ R4K
Reply 1 of 8, by Joseph_Joestar
The Voodoo 3 is faster.
Period correct benchmarks can be found on Anandtech.
My retro stuff
Reply 2 of 8, by winuser3162
Joseph_Joestar wrote on 2024-05-10, 20:43:
thank you!
Reply 3 of 8, by Demolition-Man
On average, both graphics cards are equally fast. The TNT2 M64 has advantages in DOS, but uses more conventional memory. The TNT2 has MPEG2 acceleration, the Voodoo 3 doesn't really. On the other hand, the Voodoo is faster with DirecetDraw, but this only affects a few games. The decision is still easy ,because the Voodoo 3 supports glide.
Reply 4 of 8, by Garrett W
They are not equally fast. The TNT2 M64 performs like a TNT most of the time, though it can surpass it at lower resolutions such as 640x480. It is severely bandwidth limited due to the 64bit bus.
As a reminder, the Voodoo 2 was the contemporary to the TNT.
Voodoo 3 matches the performance of a Voodoo2 SLI setup on the 2000 model and 3000 & 3500 are a bit faster. Stuttering and thrashing which can plague Voodoo 2 are also gone, thanks to unified memory. Voodoo 3 trades blows with the TNT2 cards, not TNT2 M64.
Reply 5 of 8, by rasz_pl
Demolition-Man wrote on 2024-05-10, 21:18:
only marketing wise :] It has "Hardware color space conversion" just like Voodoo3. gf256 added motion compensation, and only 2002 GeForce4 MX added iDCT. By 2002 even a potato cpu could flawlessly decode DVD in software.
Reply 6 of 8, by Demolition-Man
I recently tested the two cards against each other, but the PCI variants. Compared to the Voodoo 3, the DVD player on the TNT M64 at least started with hardware acceleration. But not much came out of it, that's true.
So i still would prefer the Voodoo 3.^^
Reply 7 of 8, by dionb
"Better" is about more than just raw speed.
Voodoo3 cards were manufactured by 3Dfx after taking over STB, and they were manufactured well. In particular the analog components/filters were good, resulting in a sharp, clear and vibrant image.
TNT2-M64 cards were made by a number of companies, but were usually low-end options, as high-end buyers bought the TNT2, TNT2 Pro and TNT2 Ultra. So a lot of those manufacturers cut corners when it came to quality of design and components, leading to fuzzy output and blander colours, particularly at higher resolutions. The best TNT2-M64 cards were probably on par with a V3, but the worst were downright terrible. You don't specifiy exactly which TNT2-M64 cards you have, but odds are their analog output will be worse than a V3.
Reply 8 of 8, by winuser3162
dionb wrote on 2024-05-11, 11:19:
i have a few tnt2 m64 cards as they are extremely common but the only two that i use is a vanta tnt2 and a gigabyte tnt2 m64
