First post, by montezuma iii
Hi all: I'm looking for someone who understands both electronics and computers.
I have an old Frael King pc, with NEC V20 cpu, 8088 compatible: by mistake I inserted an isa card backwards and, wanting to equip it with a storage drive, I opted for SD cards and CF cards (in the sense that I tried both): I do wipedisk, then reboot, then fdisk, create the partition successfully (fat16, tried with freedos and ms-dos 3.30, 3.31 and 6.22), reboot again, format c: successful, then sys c: also successful, then fdisk /mbr, successfully entered c:, I created a file autoexec. bat with PATH=C:\ and PATH=C:\COMMAND.COM, file created correctly, but when I try to give a command the pc freezes, and when I reboot the pc does its BIOS, does the POST, and then when booting from C: the pc freezes. The partition was successfully activated by fdisk, but after the reboot it loses its active status.
The guy who repaired it for me just changed a fuse, and it seemed like the pc was working, but I'd like to find out if there's any damage left in any track or integrated/chip.
When I go into C: (booting from floppy/gotek) and run the autoexec.bat file, it runs correctly, and the sys c: writes a command.com file, also correctly: so the partition works in write mode, but doesn't boot from C:, is this due to a motherboard fault, or incompatibility with memory cards and daughterboards? (I installed an ISA floppy and serial controller from Sergey Malinov and an xt-ide rev. 4 from glittchwrks (both cards are modern, but for retro PCs with 8 bit ISA) and an IDE to CF card adapter).
Unfortunately, I did all these tests after the failure, and I don't know if the PC had booted before.
I hope I have not been too verbose, but I have tried to include all the details, also for easier help.
Thanx in advance.
Casino Ambulante
Top of page
Commodore 64: tutto il resto è noiaaaaaaaaaaaaaa
Women?
?FORMULA TOO COMPLEX
ERROR
READY
Reply 1 of 1, by montezuma iii
In addition: I have a terrible doubt: the riser card inserted in the ISA slot is not the original one, but is 16 bits, while the Frael slot is 8 bits: could this be the cause of the partition losing its 'active' status after a reboot, while the C: disc is working in write mode and the autoexec.bat file on it is regularly running?
(I've cut in two the post 'cause It seemed too long to me)
Women?
ERROR
READY
