First post, by Achilles2
Dear All,
Seems the fan of my AGP card NVIDIA P50 G3Ti200 Pro is dying. I'm looking for a new fan but I can't find some of the older models that seemed to be compatible with it. Any recommendation on which fan to buy?
Thank you.
Reply 1 of 3, by Repo Man11
I've a PNY GeForce 3 Ti200 and I just installed one of the Chinese Zalman cooler knockoffs on it. As they are a "Universal" fit, some of the mounting points interfered with the RAM heat sinks so I had to use a hack saw and a file to trim the unnecessary mounting points to make it fit.
A lot of times when you first start out on a project you think, This is never going to be finished. But then it is, and you think, Wow, it wasn't even worth it. - Jack Handey
Reply 2 of 3, by Repo Man11
One of these would be an easy and inexpensive replacement, just be sure to find one that matches the mounting holes on your card. I bought one of these for a card that died, then used it on my Ti200 (until I replaced it yesterday) as it was better than the stock one. These retail for less than $10.00.
Reply 3 of 3, by Achilles2
Thanks Repo! Will look for something similar to the 2nd cooler you've posted. 😀
