First post, by mtest001
Hi all,
As some of you may know already, I was given a Compaq LTE Lite 25 which I brought back to life. The laptop came with a black 3.5" external FDD, that connects via a parallel port plug. I wasn't sure why this drive was there, until I realized that the internal disk drive was not working.
The attachment 20240519_141746.jpg is no longer available
Now, without a working floppy drive, I am a bit stuck to copy files from/to the machine, so I tried to make this external drive work. Unfortunately I have no idea how this is supposed to be configured. I did connect it to the laptop, then in the BIOS there is an option to indicate that an external FDD is present but it does not seem to have any effect.
Would someone know how this is supposed to work? Thanks.
/me love my P200MMX@225 Mhz + Voodoo Banshee + SB32 PnP + Sound Canvas SC-55ST = unlimited joy !
Reply 1 of 16, by dominusprog
Doesn't the drive have an external power connector?
Creative AWE64 Value ❇ 8.4GiB Quantum Fireball ❇ Win95 OSR2 Plus!
Reply 3 of 16, by mtest001
dominusprog wrote on 2024-05-19, 15:50:
I could not see any power socket, which is indeed suprising because I am not sure if a parallel port can deliver enough power for a disk drive.
Reply 4 of 16, by chrismeyer6
Can you post some more pictures of the floppy drive? There might be some kind of non-standard power plug on it.
Reply 5 of 16, by mtest001
weedeewee wrote on 2024-05-19, 16:28:
Does the drive not respond when attached and you try to do a
DIR B:
in dos ?
I tried and no it does not work.
Reply 6 of 16, by weedeewee
mtest001 wrote on 2024-05-19, 19:24:
DIR B:
in dos ?
Dangit, I was hoping it would work out of the box since I'm fairly certain on later model compaq m700 it actually does work, though I would have to check to be 100% certain.
I guess a driver of some sort will be required for these older machines, although since the bios sees the external drive when attached... mmmh I do not know.
Do not ask Why !
Reply 7 of 16, by AngelaTheSephira
weedeewee wrote on 2024-05-19, 20:26:
DIR B:
in dos ?
Note that when this is connected, that is no longer a parallel port at all, and the pinouts change. It's worth checking the cable itself for damage inside the connectors; it may be missing something that tells the computer to change the pinout and put 12V or 5V on some pin to power it.
It effectively turns the LPT port into "just a bunch of pins".
HP OmniBook 600CT
i486/DX4-75 | 16 MB RAM
800x600 full-colour LCD
256 MB CF card in a PCMCIA adapter
Reply 8 of 16, by weedeewee
AngelaTheSephira wrote on 2024-05-19, 21:01:
There was mention of this
mtest001 wrote on 2024-05-19, 12:36:
So the bios detects it.
but, indeed that does not rule out that some wires might be faulty.
Do not ask Why !
Reply 9 of 16, by AngelaTheSephira
weedeewee wrote on 2024-05-19, 21:13:
There was mention of this […]
The best part is that no two vendors did the cabling the same way, often not even between different machines in the same line. So, the only way to know for sure is to either take the cable apart (destructive) and make your own brand new one that's a replication after, or find another unit that works with THIS machine, is known good in the first place and probe it out. Can we get pictures of both sides of the cable? It's possible the cable itself is a straight through DB-25 cable and the drive itself (or the computer) have an issue.
HP OmniBook 600CT
Reply 10 of 16, by weedeewee
AngelaTheSephira wrote on 2024-05-20, 01:55:
just an fyi, I'm not the OP of this thread.
Opening up the cable and fdd seems kinda futile if we do not have the actual wiring scheme it needs to have.
A photo of the underside of the FDD that shows the sticker mentioning which model compaq fdd it is will also be helpful if enough documentation can be found.
edit: Thanks to this Re: Compaq LTE Lite 4/33c parts, drivers and BIOS which leads to
this, https://web.archive.org/web/19991109002030/ht … es/us/1_23.html
there does not seem to be any drivers for the external floppy drive at first glance.
Do not ask Why !
Reply 11 of 16, by mtest001
The other end of the cable, attached to the drive, is sealed in plastic. I'll also try to take a picture from below the drive to see if there is any useful indication.
I'm traveling right now so unfortunately that's going to take a bit of time.
In the meantime I thought maybe some settings in the BIOS need to be changed. In the BIOS there is an option that says "External Diskette Drive" (see below), I tried to change that to enable it but it did not work. Perhaps I also need to disable the parallel port?
file.php?id=192259&mode=view
Reply 12 of 16, by kaputnik
You could also give fixing the internal drive a shot. It seems to be detected properly, the electronics should be ok.
In my experience, it's almost always simple mechanical problems when floppy drives go bad, like dried up lubricant, dust collected over the years clogging the mechanics, broken/stiffened rubber belts, etc. If you're lucky, just cleaning and relubricating it might be enough.
Reply 13 of 16, by mtest001
Thank you and yes, eventually I'll need to do that. But I am procrastinating because the case is quite fragile and every time I open it is an other occasion to break some of the tiny plastic latches...
Reply 14 of 16, by AngelaTheSephira
weedeewee wrote on 2024-05-20, 06:52:
just an fyi, I'm not the OP of this thread. Opening up the cable and fdd seems kinda futile if we do not have the actual wiring […]
This is the reason I'd really like to not have to have them do that. But since it's encased in the plastic of the drive itself, there's no point in my thought of it being a straight-through DB-25 cable or the like.
HP OmniBook 600CT
Reply 15 of 16, by mtest001
Ok I'm back to my issue... Finally took the time to take more pictures.
I was wrong when I said the cable was sealed in the plastic, in fact the internals are fully exposed as you can see...
The part number says 135233-001 .
The attachment 20240524_224836.jpg is no longer available
The attachment 20240524_224841.jpg is no longer available
The attachment 20240524_224852.jpg is no longer available
The attachment 20240524_224855.jpg is no longer available
Just to be sure I'll try to disable the parallel port in the BIOS to see if it helps.
Reply 16 of 16, by weedeewee
mtest001 wrote on 2024-05-24, 21:13:
Ok I'm back to my issue... Finally took the time to take more pictures. […]
Yep, that looks like what I remember, you can even take the drive out and use it in an appropriate machine. like an armada m700.
The connector at the floppy side of the cable is the same as what is on the inside of the laptop.
It should just get detected when attached to the laptop for all I recall.
I'm guessing that the external drive you have is just not appropriate for your machine.
Do not ask Why !
