First post, by TisellM
Hey
I've got an IBM Aptiva 2144-121.
It boots fine from floppy and the original hard disk.
However, I've installed an cf card and I'm currently trying to install MS-DOS 6.22 on it.
I can format the card and write data to it, DOS install just fine. But when I've finished installing and try to boot from the card I just get a blinking cursor...
I've looked trough the bios and can't see any settings that seems to be wrong.
Do you have any suggestions?
Reply 1 of 4, by VivienM
Did you do a fdisk /mbr?
Reply 2 of 4, by Horun
Good question VivienM! Yes CF are becoming more common as a HD replacement in older computers but they do have their own quirks, incompatibilities and it is not just the CF card but the adapter....so 2X problems...
Sorry have nothing more to add other than what is wrong with the original HD ?
Reply 3 of 4, by justin1985
I've found with other systems that kind of randomly some CF cards will work, and others not. Same adapter and same sizes, but some just won't get recognised by older BIOSes when they do with others.
I've heard this might be down to newer CF cards not always fully implementing commands that were dropped in later revisions of the CF spec, or something like that? So, try and older CF card, especially one marketed as "industrial"?
Reply 4 of 4, by saustrup
Hi! I've got a 2144-121 as well, but with a broken BIOS. Would it be possible to dump yours and attach it here? 😀
