First post, by fsinan
This is the second test with Cyrix 486DLC-40 with the same setup as previous AMD 386DX-40, which can be found here;
AMD 386DX-40 with Cyrix Fasmath 83D87-40-GP Benchmarks
Cyrix 486-DLC40 with Cyrix Fasmath 83D87-40-GP
PcChips M321 Rev 2.5
Tseng Labs ET4000AX with 1MB Ram
ESS1869
ISA controller with UMC chipset
Bios recognized the cpu as 486 and first made the tests without Cyrix software at Phils' Lab link,
https://www.philscomputerlab.com/cyrix-486dlc.html
You can observe the performance increase the Cyrix Fasmath fpu with Cyrix-486DLC. Frequency is same, so, teamwork is important for additional fpu performance.
System:1
Cyrix 5x86-120GP & X5-160ADZ
Lucky Star LS-486E
System:2
Intel DX4-WB & AMDDX4-120
PcChips M912 V1.7
System:3
AMD K6-2-475 & Cyrix 6x86MX PR-233
Asus P5A-B
System:4
UMC U5S-40
486UL-P101
System:5
P3 Coppermine 800EB
Gigabyte GA-6BX7
Reply 1 of 12, by fsinan
These are the tests that their result wasnt changed with Cyrix optimization software.
System:1
Lucky Star LS-486E
System:2
PcChips M912 V1.7
System:3
Asus P5A-B
System:4
UMC U5S-40
486UL-P101
System:5
P3 Coppermine 800EB
Gigabyte GA-6BX7
Reply 2 of 12, by fsinan
Landmark and Sysinfo test results after the Cyrix optimization sw, there is significant increase in results.
PC Player benchmark increased from 3.9 to 6.0. A huge improvement against AMD 386DX-40.
System:1
Lucky Star LS-486E
System:2
PcChips M912 V1.7
System:3
Asus P5A-B
System:4
UMC U5S-40
486UL-P101
System:5
P3 Coppermine 800EB
Gigabyte GA-6BX7
Reply 3 of 12, by Deunan
Not 100% sure what "Cyrix optimization sw" is, I assume the internal cache control program? You are still being held back a bit by lack of Write-Back mode in mobo cache.
In Lanmark 6.0 I get 168 MHz AT, 164 MHz 80287, 5146.81 chr/ms.
65.7 in Norton SI 8.0, 6.2 in PC Player Benchmark 320x200 mode.
This is with Trident 8900D in 32-bit/0WS mode (standard ISA 8MHz clock).
Reply 4 of 12, by fsinan
Deunan wrote on 2024-05-28, 15:10:
Not 100% sure what "Cyrix optimization sw" is, I assume the internal cache control program? You are still being held back a bit […]
Cyrix’s own application. I provided the link you can download and look.
System:1
Lucky Star LS-486E
System:2
PcChips M912 V1.7
System:3
Asus P5A-B
System:4
UMC U5S-40
486UL-P101
System:5
P3 Coppermine 800EB
Gigabyte GA-6BX7
Reply 5 of 12, by kixs
It's 1KB L1 cache enabler. Most BIOSes support Cyrix cpus and have an option to enable it. So you don't need to run any other software.
Also note the PCPlayer benchmark uses FPU and will run faster with one installed.
Reply 6 of 12, by fsinan
Added U32 additional cache module for wb cache. Bios was already enabled without u32.
Sysinfo or Landmark didn't change. Difference was observed with cachechk, topbench etc.I didnt make 3d tests. You can compare with previous tests.
System:1
Lucky Star LS-486E
System:2
PcChips M912 V1.7
System:3
Asus P5A-B
System:4
UMC U5S-40
486UL-P101
System:5
P3 Coppermine 800EB
Gigabyte GA-6BX7
Reply 7 of 12, by Deunan
I get 33 / 55 us in CACHECHK V7 so I think you're now running the system as fast as it can go (not counting any potential OC). Maybe x87 performance is down to extra wait state cycle on your mobo after all. This is perhaps beneficial if you decide to overclock the CPU. I think it's much easier to find a DLC (or better yet SXL) CPU that will take, say, 50MHz than a coprocessor that will not glitch or hang above 40MHz.
Reply 8 of 12, by BitWrangler
I grabbed one of those ULSI that were going cheaper on eBay a few months back. Some youtuber(s?) have tested them at over 50, I wanna say good to 55. They lag a couple of percent vs a fasmath at same clock in some things, but can go a few percent ahead in others. Just being able to do a higher clock makes up the diff though. Anyway, when I get back to basement dwelling in the fall, I will be working up my BL3 system trying to get 2x50 or 3x40 see which actually goes faster on game demo benches.
Reply 9 of 12, by fsinan
Deunan wrote on 2024-07-09, 18:18:
Not overclocking but maxed out bios settings. Totaly stable system as it is now.
System:1
Lucky Star LS-486E
System:2
PcChips M912 V1.7
System:3
Asus P5A-B
System:4
UMC U5S-40
486UL-P101
System:5
P3 Coppermine 800EB
Gigabyte GA-6BX7
Reply 10 of 12, by Anonymous Coward
I’m going to have a go with the DLC-40. I’ve mostly ran SXL-40s, but recently I finally got a real Cyrix branded DLC. I always thought a DLC-40 should give about 486-33 performance, but your benchmarks seem more like 486-25 level. I wonder if that extra chip you installed to enable WB L2 is actually doing anything…
Reply 11 of 12, by BitWrangler
From what I've seen, where i486 is approx 2x IPC of i386 is that these SLC/DLC/BL class CPU seem to do 1.5x IPC of a 386. 0.75 IPC of an i486, with about plus or minus 10 percent depending on how much cache can be used, how well the board supports it, and how much the benchmark/application responds to cache.
Therefore I'd expect in optimum circumstances a DLC-40 would split the difference between an i486-25 and an i486-33
Reply 12 of 12, by fsinan
Anonymous Coward wrote on 2024-07-10, 11:25:
It improved the cache and memory timings.DLC40 is not equal to 486-DX-33. In between DX-25 and DX-33.
System:1
Lucky Star LS-486E
System:2
PcChips M912 V1.7
System:3
Asus P5A-B
System:4
UMC U5S-40
486UL-P101
System:5
P3 Coppermine 800EB
Gigabyte GA-6BX7
