First post, by winuser3162
- Member
I have an ABit-BX6 paired with a PIII 750 and a sound blaster AWE 64 that im planning on using along side a voodoo 3 2000. unfortunately i get an error in device manager with every video card ive tried with this particular board. ive tried various cards ranging from a geforce2 MX 4000, Voodoo 3 2000 and ATI 128 pro with the same problem each time. After i install the drivers i get the same (Code 24) despite all of the cards being tested and confirmed working in other systems. the Sound blaster installs and works without any issues. i dont have chipset drivers installed for this board yet im not sure if that would make a difference. any help would be appreciated.
EDIT: I took a look in the manual and learned that through installing the chipset drivers for this motherboard, you also install the "Processor to AGP/PCI controller"
1. Silicon Graphics octane, 2GB memory, MXE graphics board, 2 350MHZ R12K
2. Silicon graphics indigo 2, extreme graphics board, 198MB memory, 200 MHZ R4K
