First post, by Nexxen
- l33t
Hello!!
Yesterday I was testing a PCIe slot on a new mobo I acquired. Am4 B450M chipset.
PCIe is 3.0. Slot #1 is connected to the cpu,
GTX690 is @ 16x 3.0 - slot works
RX580 is @ 16 x 3.0 - slot works
Fire Gl is @ 16x 1.1 - works @ 4x 1.1
Other cards 16x 1.1 works @ 8x 1.1
2.0 same @ 1.1......
Is this a compatibility issue with old + new? I'll test all these cards on PCIe 2.0 and 3.0 boards on i7 4th gen to check if it is.
Curiosity mostly, as what needs to work at its rated speed works, but not these old cards.
Meaning I can't use this board to test old stuff.
Thanks for any help!
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
"One hates the specialty unobtainium parts, the other laughs in greed listing them under a ridiculous price" - kotel studios
