First post, by 8dot3
Hi everyone!
I have some 16bit ISA cards lying around and I want/"need" a) a VGA card and b) a soundcard and c) a NE2000 card for an XT.
So I heard that some 16 bit-VGA cards can run in 8bit slots, and some soundblaster (&compatible) cards can, CD-ROM interfaces aside, run in 8bit slots, same for network cards.
Is there a list anywhere where people put the results of their tests in? I would be happy to add my data there and be even more happy to find some info there.
So, does such a list exist, and if so, where?
Thank you!
Reply 1 of 9, by Grem Five
Only list I know of is for VGA cards here.
Reply 2 of 9, by Tiido
YMF71x sound cards work in 8bit slots as long as you do not choose DMA0, the card will stop working properly in such a case (it appears not to like floating DMA ack line).
Reply 3 of 9, by theelf
I can confirm i have a trident 8900c and a ess 1868 in a XT board, works fine
Reply 4 of 9, by Grzyb
theelf wrote on 2024-06-07, 19:31:
How do you initialize it?
ESSCFG? UNISOUND? Something else?
In 2003, I voted in favour of joining the European Union. However, due to later developments - especially the restrictions on cash usage - I have withdrawn my support. DOWN WITH THE EU!
Reply 5 of 9, by TamaMan
Not a sound card but for MPU-401 compatible MIDI access, the 16-bit version of the "Music Quest PC MIDI Card" works in a 8-bit slot (IRQ selection limitations apply).
Reply 7 of 9, by kingcake
A dirty little secret is that quite a large number of "16-bit" ISA cards only do 8-bit transfers. The only reason they use the 16-bit card edge connector is for access to high IRQs. So if you use a low IRQ they will work.
Reply 8 of 9, by Shponglefan
I'm not aware of any compatibility list for 16-bit ISA cards with 8-bit slots (at least not for sound cards).
That said, I have used an PAS16 sound card with an 8-bit ISA slot (in a Tandy 1000 TL) and it worked.
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 9 of 9, by Grzyb
kingcake wrote on 2024-06-07, 22:04:
Oh yeah - see eg. Sound Blaster Pro.
Also, all those multi-I/O cards only use 16-bit for IDE - other functions (FDC, COM, LPT, GAME) are 8-bit.
