First post, by ssokolow
I just received an HP t5710 that I ordered and, having had a bad night, I unthinkingly powered it up from the included PSU without double-checking.
It did appear to run fine... but I've since discovered that the PSU is a 19V supply, not a 12V supply. I contacted the seller, but they're insistent that they've been selling this combination under the definition of "compatible" in their listings for years and never had a complaint and that, if I don't like it, they'll give me a return label for the entire order.
Is anyone familiar enough with the t5710's circuitry to know whether feeding it 19V would cause a less immediate problem?
(I'm a software guy, so my concerns are not at all based in actual expertise, but concerns that pop to mind include decreased longevity of the voltage regulation circuitry, more waste heat putting strain on the system's ability to passively cool itself, the possibility that it's using "unregulated 12V" for the serial port when RS-232 specifies 3 to 15 volt signalling, or the possible existence of a trace that feeds unregulated supply voltage to 12V+ pin on the PCI slot.)
Internet Archive: My Uploads
My Blog: Retrocomputing Resources
My Rose-Coloured-Glasses Builds
I also try to announce retro-relevant stuff on on Mastodon.
Reply 1 of 10, by rasz_pl
Old 19V laptop supplies are cheaper and more plentiful than 12V ones, so Im not surprised by ebay seller 😀
I dont think there is anything using 12V in this box. I think you correctly located the two possible problem points, measure if PCI A2 is even connected.
https://github.com/raszpl/440BX Reference Design adapted to Kicad
Reply 2 of 10, by ssokolow
Thanks. It's late here, but I'll try to find time to check A2 tomorrow.
Is there anything to my concerns about straining the voltage regulation or pushing the limits of the case's ability to convectively cool itself?
I don't know what kind of voltage regulation it uses, but my reading up for five minutes of playing around with an Arduino half a decade ago taught me that, if it's using a linear regulator, higher input voltages result in more power being burned off as waste heat, so, for an Arduino Uno, all else being equal, 7V is better than 9V is better than 12V within the recommended 7-12V subset of the input range its regulator supports.
Reply 3 of 10, by The Serpent Rider
higher input voltages result in more power being burned off as waste heat.
More voltage equals less heat, because less current is required and efficiency of conversion is usually better, that if a VRM can handle it and nothing is feeding directly from 12V. Anyway, it's not a big issue to procure a standard 12V power supply.
Reply 5 of 10, by ssokolow
The Serpent Rider wrote on 2024-06-08, 03:00:
It's a question of whether I should negotiate with the seller for a partial refund over whether this meets the "man on the street" definition of "(compatible)" for a power supply.
I don't know about where you live but, here, it's $20 + $5 S&H on Amazon.ca for the kind of power supply you'd expect to see being pulled apart on bigclivedotcom and all the sources for genuine high-quality supplies seem to want $20 + $20 S&H for this configuration. That's a non-trivial portion of what I paid for what was supposed to be the unit and a power supply I can trust to be compatible.
Reply 6 of 10, by The Serpent Rider
I just power my T5720 with generic 12V power supply from a spare external HDD box. T5710 requires even less power.
Reply 7 of 10, by ssokolow
The Serpent Rider wrote on 2024-06-08, 09:38:
That still assumes I have a 12V supply where I don't also want to use whatever it came with... and that I consider it reasonable to have paid a price on the assumption that I'll have a use for the included power supply when I already have more 19V supplies kicking around with no use for them.
Reply 8 of 10, by ssokolow
Yeah, I'm definitely not considering the supplied PSU "compatible". All the capacitors are rated 16V except for a couple of small ones in behind those big green ones which are rated 6.3V.
Unless HP designed a DC-DC converter with no capacitors on the input side, the only reason the seller hasn't blown one of these things up by feeding 19V power into it is that HP picked capacitors with enough of a safety margin to account for degradation with age.
The barrel jack is in that gap behind the rightmost tall, green capacitor.
The attachment IMG_0855_scaled.JPG is no longer available
Reply 9 of 10, by kdr
Of interest is that the later HP t5740 is actually spec'd for 19V and uses the same connector as the HP laptop power supplies. I picked up my t5740 without a power supply and it was easy to find a compatible power supply for it. (This thread did inspire me to go check the t5740's spec sheet to make sure I wasn't inadvertently dooming mine to an early death!)
Reply 10 of 10, by ssokolow
I understand where you're coming from (the same reason 240V countries can use less copper for the same wattage rating when wiring a house) but I was talking about the inner workings of a linear regulator.
What I was referring to when saying "All else being equal, 7V is better than 12V in the recommended 7-12V range for powering an Arduino Uno from the barrel jack" is the VIN – VOUT in the PD = [(VIN – VOUT) * IOUT] + (VIN * IGND) power dissipation equation for linear regulators as laid out in https://www.maxlinear.com/files/ApplicationNo … /LDOThermal.pdf.
With linear regulators, heat dissiptation requirements can be crudely thought of as "burning off the excess voltage".
