First post, by my03
I recently sourced a rather nice package consisting of this laptop with dock, floppy (somewhat working) and CD (also somewhat working). It was expanded to 128mb but unfortunately w98 was installed in the wrong language (to my preference) + it had the 6.2gb HDD.
So, i ended up swapping out the HDD for a CF (8gb) and at first i had to struggle a bit (due to very shaky periphials - floppy was sounding like it would die at any moment and only a firm tap would allow it to read the w98 boot floppy. CD was more or less the same). Until i realized that my 480CDT actually had the same connectors for floppy and CD and - yes they worked immediately when connecting them 😀
So, after installing w98, finding all the crucial drivers (graphics, inf/usb, pcmcia, etc) i finally got it running nicely (even with wifi using my pwc-0301 card). But now comes the issue.
While i managed to install everything (except one thing - "PCI Card") including usb support (mouse and usb-storage works fine), i can only use either a ps/2 mouse (via the dock) or a usb-mouse (via the usb-slot on the machine or the usb-slot on the dock). The trackpoint (i think Toshiba calls it "accupoint") does not react at all when i move it.
I checked the flat-cable connections inside the machine and they are all connected to the best of my knowledge. Question is: does the accupoint require some extra driver or software to function?
Reply 1 of 18, by Thermalwrong
That's great that you got the floppy drive from the 480CDT to use with it.
The silver floppy drive that comes with the Portege 3xxx laptops is a Citizen W1D and the belts have gone bad on even those later ones, so you'd need to swap out the belt to use that drive.
I'm surprised the connector matched up, I thought there was a connector pitch difference between the 480CDT caddy and the Portege, at least on my Portege 3010CT.
"PCI Card" - that gets me every time too, it's the Toshiba Fast IR driver 😀
The mouse should work without any drivers, it's emulating a regular PS2 mouse. It could be the same is damaged but beyond that perhaps the trackpoint itself is damaged since those are just some variable resistors that react to pressure. I've seen them fail on laptops that were corroded / dirty enough.
Reply 2 of 18, by my03
Thank you Thermalwrong. It was indeed the IR. Now everything is well in the driver department 😀
Oh and i need to apologize for my (wrongful) claim that the 480CDT shares the same connector as the portege, they don't. When i bought the 480, i got some periphials with it (including this external floppy) but never reflected on that further as it already have an internal floppy as well. But now when i checked IRL, i noticed that this larger unit and the smaller silver one (that came with the Portege) have the same connector (took a picture of them both). I have no idea what this larger unit is supposed to support 😁 Of course, the 480 on the other hand has a slightly wider connector for its intended external floppy.
I will try to remove the keyboard again and peek carefully if there is something that may have come loose..
Thx again
Reply 3 of 18, by dukeofurl
I have this exact same computer with win 98 install on original HDD. Actually I used it regularly 24 years ago and just held onto it this long, and it's still working. My floppy drive crapped out recently though.
If you need to check anything or you think I might have a driver you need just let me know and I'll see if I can help.
Reply 4 of 18, by my03
Thank you heaps both Thermalwrongs and dukeofurl for your kind input 😀 Much appreciated.
I think the trackpoint a.k.a "accupoint" gave up on this machine. I carefully removed the keyboard and looked at the small flat-cable but from what i can see, it looks pristine. No big issue as i can use my small usb travelmouse with the machine much more comfortably (and the small scroll-wheel works also which is a very nice bonus).
Oh, i thought the IR package would solve this mysterious driver issue (PCI Card) but after rebooting once again (after installing the 740fir.exe (and after that the 780fir.exe) referenced here: https://support.dynabook.com/support/viewCont … ontentId=106226
but actually found here: https://www.retrospace.net/toshiba/windows_98_files.htm (the 780 version)
I still have the yellow "PCI Card" thing in the device manager. Looking at what resources it occupies, i see I/O range FF60-FF7F which after some googling reveals that it may be related to UHCI USB Controllers (https://forums.linuxmint.com/viewtopic.php?t=50726) ??
Its no biggie as such as the machine works perfectly fine, but it IS intriguing 😁. And having this thing sorted would be nice at the end of the day. Has it something to do with USB (which works fine)? I did install the NUSB36e from Phils Computerlab earlier (which now makes the system properties proclaim the macine as "Microsoft Windows Me", probably because NUSB packages reuse Windows ME stuff i guess)
Reply 5 of 18, by Thermalwrong
To find out what the device is in Windows 98 - go to Start > Run > "hwinfo /ui" minus quotes. Then when that loads, go to view > Problem Devices and you can see the PCI device ID which should help you to find what it really is since you can search for that and usually find definitive answers
Reply 6 of 18, by my03
Great input Thermalwrong. Thank you.
And i finally managed to fix this 😀
Following your advice i could find the vendor and subsystem (IR).
What DIDN'T work was to try the w98 specific drivers for the IR (740fir98.exe or 780fir98.exe) that i used before, but rather to download the xp package (p349irxp.exe), then using 7zip to extract it and finally point the driver install to the inf-file in this xp package. that did the trick and the IR kick-started immediately (funny enough).
All good. Thx heaps for the help.
Reply 7 of 18, by Zeugitai
dukeofurl wrote on 2024-06-09, 00:08:
I, too, have a Toshiba Portege 3110CT that I am reviving to my family's ridicule. Unfortunately, I have to do a clean install of Win98 and lack vital drivers, especially the PCMCIA CD-ROM driver and the SMC EZ Connect G PCMCIA wireless driver. I managed to replace the belt in the floppy drive and use it to get the USB driver installed, so I have that access now, at least. Would you happen to still have any drivers? The display driver, too? I'd be very much obliged!
Reply 8 of 18, by DaveDDS
Did the trackpad work with the original (Wrong language) HD?
Do you still have that HD?
If yes to both, I'd try putting it back in and see if the trackpad works..
If yes ... you have a software/driver problem .. Perhaps you can recover the
drivers it needs from that HD
Also, if that original HD is the one that shipped with the machine when
it was new... Perhaps there is a "recovery" partition on it?
Dave ::: https://dunfield.themindfactory.com ::: "Daves Old Computers"->Personal
- Dave ; https://dunfield.themindfactory.com ; "Daves Old Computers" ; SW dev addict best known:
ImageDisk: rd/wr ANY floppy PChardware can ; Micro-C: compiler for DOS+ManySmallCPU ; DDLINK: simple/small FileTrans(w/o netSW)via Lan/Lpt/Serial
Reply 9 of 18, by MAZter
Zeugitai wrote on 2025-02-25, 00:56:
This unofficial boot floppy image contain at least DOS driver for Freecom F-TO-TCD-24L CD-ROM, found in this thread:
The attachment Tos_Companion_Disk_P3110CT_CD_Support.zip is no longer available
Page at Archive.com with recover media cd/floppy for 3110CT
Doom is what you want (c) MAZter
Reply 10 of 18, by Zeugitai
MAZter wrote on 2025-02-25, 12:41:
This unofficial boot floppy image contain at least DOS driver for Freecom F-TO-TCD-24L CD-ROM, found in this thread: […]
Big thanks! I've wasted days already scouring around. I should have come here first!
The attachment Image_20250225130833.jpg is no longer available
Everything is back except the driver for the SMCWCB-G PCMCIA Wireless Cardbus Adapter called 'EZ Connect g' (802.11g). Anyone have this?
The attachment Image_20250225134715.jpg is no longer available
Reply 11 of 18, by MAZter
Zeugitai wrote on 2025-02-25, 14:35:
You are welcome!
Try this one:
https://drivers.plus/pt/smc-smcwcb-g-keyboard … -0-0-167/13813/
Reply 12 of 18, by dukeofurl
I have this stuff which looks very promising. The companion disk just seems like it is a bootdisk, and also includes a hardware diagnostic utility on it. I think the CDs will probably give a factory reset style install of win95 or 98, probably with the appropriate drivers. Let me know if you'd still like any of this.
The attachment PXL_20250227_024950794.jpg is no longer available
Reply 13 of 18, by my03
DaveDDS wrote on 2025-02-25, 02:07:
Did the trackpad work with the original (Wrong language) HD? Do you still have that HD? If yes to both, I'd try putting it back […]
Terribly sorry for answering this late.
I tried it with the original HDD but the issue still remained so i guess its a HW issue here.
Also, i have all drivers loaded and supposedly working (no yellow exclamation marks in system properties) so i guess the only thing i potentially every could try is to find a keyboard replacment. It doesn't bother me that much imho as i can connect my small usb travel-mouse which works great (but it will probably keep gnawing away at me.... Lets see where it all ends up 😁 ).
Reply 14 of 18, by my03
yeah, sorry for bumping this thread, but perhaps either one of you gentlemen (and ladies) might have a good answer to this one: audio!
This machine has the ESS 1978 so its not really "great" from any DOS perspectives. In my case, i can run DOOM by creating a w98 shortcut to the doom.exe and the SB-settings will work.
But if I would (for example) try to run a demo such as "second reality", it will immedately complain. Same if i try to run Duke Nukem.
If i try out the settings (FX card: 0x220, (SB16 or even 2.0), irq 5, 8-bit dma 1, 16-bit dma 5) it will throw an error.
Tried "Blood" and its the same.
I have the ESS suite installed in DOS (including Maestro) but it will not make any difference.
What have you tried and potentially succeeded with that works?
Reply 15 of 18, by MAZter
my03 wrote on 2025-09-05, 20:28:
I recommend to use Maestro utility version 1.25, it's make sound works a little louder:
The attachment 3110CT-audio.zip is no longer available
and use IRQ 10 instead of 5 or 7, works fine for me (uncheck use automatic settings), DMA 1 & PORT 220, SB PRO (not 16):
The attachment 2025-09-05 21.34.55.jpg is no longer available
Just replace 05, or 07 inside mstrinf.ini to 16 in configuration file (already did it in attached file):
The attachment 16.jpg is no longer available
Reply 16 of 18, by my03
Thx heaps MAZter,
i dropped the files from the zip into the windows\system dir. All good.
But changing the IRQ gave me some headache. Even when trying it manually, it won't allow me to change it to "10" (i see 5 and 7 depending on configuration). Also, the port setting seems to be invisible to me (no choice for it in either selection under "Sound, video and game controlles" unfortunately
Reply 17 of 18, by MAZter
my03 wrote on 2025-09-11, 21:36:
This mean you need correct windows drivers as well. I'll try to look for the ones I installed.
