50mm fan recommendations
First post, by Czeky
I'm looking for 50mm fans for my 450mhz PII processor, because the ones I have are starting to go bad after years of spinning. Kinda sad that Noctua doesn't make any 50mm ones.
Any recommendations? Would like to stick to standard black colored fans, but anything goes.
So you think it's really good, yeah? You should try making the bloody thing up; it's a real pain in the arse.
I'm no American.
Reply 1 of 2, by lti
You can also look at the brands I listed in this other thread, but it depends on what you can get with the 3-pin connector installed.
Re: Absolute best, Most reliable fans
Evercool fans are the easiest to find where I live (almost always under the StarTech brand), but I don't know about Hungary.
Reply 2 of 2, by mmx_91
I really like Noiseblocker fans in 50mm (the ones with purple blades).
You can find them in Amazon no problem these are quite cheap also.
