First post, by bernardthehermit
Back in the days I ended up 2 Diamond Monster 3D (Voodoo1) when I bought a new PC. With my limited knowledge of the time, I simply put both of them in my Pentium 2, and had them passthrough into each other, assuming that was what was called SLI.
Now I got a hold of them again and built another Pentium 2, however, I now have a doubt: is that doing anything, or am I simply overriding one Voodoo1 acceleration with another, but not really improving performance?
To be clear, the setup is:
VGA --> Voodoo1 --> Voodoo1 --> Screen
Reply 2 of 11, by Rwolf
The SLI setup worked for Voodoo 2 cards, not Voodoo 1.
You had each board handling half of the graphics, but the sharing connection was by the feature connector inside the PC (flat cable on top of the boards).
The pass-through cabling on the outside was for using a normal 2D card in conjunction with the 3D only Voodoo 2 cards, otherwise you would have to have two monitors, with one for 2D windows stuff and the other for the 3D Glide games, which is impractical.
Reply 3 of 11, by Shponglefan
Rwolf wrote on 2024-06-10, 00:21:
I think Voodoo1 did support SLI, just that most cards were not designed with that capability. I believe it was one of the early Quantum cards that did SLI which basically a pair of Voodoo1 cards grafted onto a single PCB.
edited to add:
Looked it up and it looks like there were two Quantum Voodoo1 SLI solutions. The first being a pair of Quantum Obsidian Pro cards, and the second (what I was thinking of originally) is the Quantum Obsidian 100SB-4440, which was two Voodoo1 cards in SLI config on a single PCB.
http://www.thedodgegarage.com/3dfx/q3d_obsidian.htm
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 4 of 11, by leileilol
That extra Voodoo is going unused. SLI works by having data synced between two cards as they both take on a line each. Having VGA chain two of them won't give them that capability.
long live PCem
FUCK "AI"
Reply 5 of 11, by progman.exe
Don't listen to any denialists, I have 5 voodoos in SLI in a decent mobo and get thousands of bungholio marks, with the order of magnitude increasing per voodoo card installed
Reply 6 of 11, by Matchstick
Diamond Monster 3D (Voodoo 1) lacks any header for doing SLI.
As others have said, passing it through accomplishes nothing, As the input signal from the first Voodoo will be literally turned off just like it was a VGA card in favor of the last voodoo in the pass through chain when the 3dfx or GL api gets triggered.
Not mention would most likely degrade performance, as you have 2 cards doing the same work and taking up CPU cycles via the PCI buses, slowing down the Bus and the cpu. And that is if the 3dfx API calls are going to both cards.
The only Voodoo 1 that can SLI outside the Obsidian PRO SB50-2400, is Anthony ZX-C64's custom STONED SHAMAN Voodoo Card
https://www.zxc64.com/shamans/0_863_stoned_sh … s_voodoo_1_sli/
Reply 7 of 11, by PD2JK
progman.exe wrote on 2024-06-10, 16:34:
Yeah quite right, with the correct driver you push them fps on a logarithmic scale.
i386 16 ⇒ i486 DX4 100 ⇒ Pentium MMX 200 ⇒ Athlon Pluto 700 ⇒ AthlonXP 1700+ ⇒ Opteron 165 ⇒ Dual Opteron 856
Reply 8 of 11, by bernardthehermit
I lived a lie
Reply 10 of 11, by bernardthehermit
Thanks for the comforting words. On the bright side: I now know I have a spare Diamond Monster 3D!
Reply 11 of 11, by darry
bernardthehermit wrote on 2024-06-12, 08:47:
And spares are never a bad thing.
