First post, by Obi Wan
I look every where for a dosbox.conf as in Windows but I can't find.
I tried to find an How To on this forum and zip.. nothing about.
Anyone knows how can I configure the dosbox on Linux ? Where are the files ?
Thanks
ASUS P5A-B AMD K6-2 500 MHz 256 Mb Diamond Viper 32 Mb Knoppix 3.9
ASUS A7S333 AMD XP 2.2 GHz 1 Gb NVIDIA GeForce 4 64 Mb WS2003Std
Reply 1 of 9, by dougdahl
Look at the README (specifically the CONFIG command used from inside dosbox)
Reply 2 of 9, by paul-donnelly
I usually use the -conf command line option to specify a .conf file.
Reply 3 of 9, by eL_PuSHeR
If you do not have any dosbox.conf file you MUST FIRST create it.
Inside DOSBox...
config -writeconf dosbox.conf
READ THE README/DOCS.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 4 of 9, by Obi Wan
Sorry people.
I use the DOSBox on a w2k pro and I find everything about the DOSBox configuraton on the README as you say.
But on Linux I find only a dosbox on \usr\bin\ and nothing more.
If I execute DOSBox the DOSBox window open with the z:\. After a dir I find a lot of .COM and a Autoexec.bat. Nothing more. I look for a readme outside and I didn't find.
I tried using the config.com but he create the .conf file on the /usr/myname/ folder. After that the DOSBox command don't find it. I not tried yet to create the .conf with the name dosbox.conf. I'll try it.
Thanks everyone.
Reply 5 of 9, by Qbix
Rank DOSBox Author
DOSBox Author
in the readme should be mentioned
that you should/could call the file
~/.dosboxrc
That way dosbox will automaticly use it.
Water flows down the stream
Reply 6 of 9, by Obi Wan
Qbix wrote:
in the readme should be mentioned that you should/could call the file ~/.dosboxrc […]
~/.dosboxrc
I know that because of my windows installation. But on my Linux distro, Debian Sarge, I don't find the DOSBox's README. I look for everywhere. I do not know the reason. The result installation give me a return code 0.
The creation of a dosconf.conf ocured on the /home/user/ directory and was recognized by the dosbox command.
Reply 8 of 9, by DosFreak
Just open up your dosbox package with a compression program and see if there's any documentation in there. If so then it should also show the path that it'll install to.
Make your games work offline
Reply 9 of 9, by Qbix
Rank DOSBox Author
DOSBox Author
/usr/share/doc/dosbox/README.gz
