First post, by artemisworks
Hi all,
Posting this in case anyone has ever had this problem before. I am running a fairly fresh install of Ubuntu 20.04 on my Dell laptop.
Up until a few days ago, everything was working fine. I was emulating the old PC game Where In Europe is Carmen Sandiego without any issues.
I've not changed anything to any config files, but I've installed the usual system updates whenever prompted. Something has now caused this issue, as whenever I start Dosbox, I get this message:
DOSBox version 0.74-3
Copyright 2002-2019 DOSBox Team, published under GNU GPL.
CONFIG:Loading primary settings from config file /home/jrong/.dosbox/dosbox-0.74-3.conf
MIXER:Got different values from SDL: freq 44100, blocksize 512
ALSA:Can't subscribe to MIDI port (65:0) nor (17:0)
MIDI:Opened device:none
Now the sound no longer works when I am running the game. Anyone know what I can do about this?
If I edit the dosbox-0.74-3.conf file and change the blocksize (under mixer settings) to 512, I get the same error message as above, except that the blocksize value is now 256.
I don't know much about Midi or audio settings but I would really like to get my sound working again - so thanks if anyone can help?
Arte
Reply 1 of 2, by dominusprog
Try DOSBox Staging.
sudo apt install libsdl2-2.0-0
sudo add-apt-repository ppa:feignint/dosbox-staging
sudo apt-get update
sudo apt install dosbox-staging
Aztech Pro16 II-3D PnP ❇ 8.4GiB Quantum Fireball ❇ Win95 OSR2 Plus!
Reply 2 of 2, by artemisworks
Thank you - DOSBox Staging worked!
Now to figure out why my Apple II emulator microM8 has also lost its sound .... 🤣.
Thanks again.
Arte
