First post, by Synersh
Recently i was working on one of our Older X-Ray Machines (C-Arm) that has an imaging system that was windows xp.
It uses a Frame Gabber card (Matrix Solios eX/xA).
I attempted to use the original MilLite 8.0 on a 32-bit version of windows 10 but it would not install the solios drivers for the card.
I then stumbled upon this thread: Re: Does anybody have drivers for matrox solios XA?
In where i was able to use a 64-bit windows version with Mil-X that was supplied.
The Grabber Card drivers finally worked but i guess i have the issue that the Program is 32-Bit. and requires Mil Library to even run.
(We used to be a supplier and manufacturer for these xray units in 2007 before they were discontinued)
Unfortunately im not able to re-write the software anymore to get it to run with 64 bit versions as all the Files were taken back to korea and probably destroyed.
The X-Ray machine is in fantastic running condition so i wanted to see if i could give the imaging system a new lease on life.
So, upon running the program it comes up with error code "0xc000007b" then the program will just close.
Searching around i did install 32-Bit versions of .Net 1.1, 2003, 2005, 2008 and Visual C++ but none of those options seemed to fix it.
I assume my issue is with the Mil-X 64 Bit Library that i found and was wondering if anyone is able to Track down a 32-bit version that still supports the Solios grabber cards?
Thank you in Advance.
