First post, by JediSword
Hi. I'm trying to do universal MS-DOS boot floppy (mainly to use with LiveCD images)
CD will be mounted with:
LH=A:\DOSDRV\SHSUCDX.COM /D:BANANA /L:R
My idea is to put in autoexec bat line that run START.BAT file only if this file exists on CD.
But this:
IF EXIST R: R:\START.BAT call R:\START.BAT
gives me Abort, Retry Fail if disc is not inserted.
So is any way to detect if CD is inserted?
Thanks for advance
Reply 1 of 8, by JediSword
oh, wrong paste:
should be:
IF EXIST R:\START.BAT call R:\START.BAT
Reply 2 of 8, by JediSword
I found little tool called DREADY.COM in REMOVED:
DREADY <drive> [/W] Version 2.2 (c) 1997, Horst Schaeffer option /W tests: READY to WRITE? errorlevel 0:ready, 1:read only (/W), […]
DREADY <drive> [/W]
errorlevel 0:ready, 1:read only (/W), 2:not ready, 255:invalid
but unfortunately this code:
DREADY R:
if ERRORLEVEL 0 GOTO AUTOSTARTCD
if ERRORLEVEL 1 GOTO AUTOSTARTCD
GOTO END
:AUTOSTARTCD
echo autostart
IF EXIST R:\START.BAT call R:\START.BAT>NUL
always jumps to :AUTOSTARTCD which gives me Abort-Retry-Fail if drive not inserted
Reply 3 of 8, by DaveDDS
JediSword wrote on 2024-06-21, 14:42:
I found little tool called DREADY.COM in REMOVED: […]
DREADY <drive> [/W]
DREADY R:
GOTO END
:AUTOSTARTCD
echo autostart
if ERRORLEVEL value ....
performs ... if ERRORLEVEL is >= value
so your IF are out of order - the first one will go if ERROELVEL==1
but even that won't work - ERRORLEVEL will always be >= 0
so the GOTO will always get taken.
I think you want something like: (not tested)
DREADY R:
if ERRORLEVEL 2 goto end
echo AutoStart
if exists R:\START.BAT call R:\START.BAT
:end
Dave ::: https://dunfield.themindfactory.com ::: "Daves Old Computers"->Personal
https://dunfield.themindfactory.com ; "Daves Old Computers" ; SW dev addict best known:
ImageDisk: rd/wr ANY floppy PChw can ; Micro-C: compiler for DOS+ManySmallCPU ; DDLINK: simple/small filetransfer(w/o netSW)via Lan/Lpt/Com
Reply 5 of 8, by myne
DaveDDS wrote on 2024-06-21, 14:59:
if ERRORLEVEL value .... performs ... if ERRORLEVEL is >= value […]
DREADY <drive> [/W]
DREADY R:
GOTO END
:AUTOSTARTCD
echo autostart
DREADY R:
echo AutoStart
:end
No. The original script is correct.
The dready command just isn't working properly.
Op
Try manually from c:
Dready r:
What happens?
If it works try if errorlevel 0 echo blah
What happens?
I built:
Reply 6 of 8, by DaveDDS
Using this little program to set ERRORLEVEL: ERR.C
#include <stdio.h>
main(int argc, char *argv[])
if(argc == 2) exit(atoi(argv[1]));
and this batch file: TST.BAT
@echo OFF
ERR %1
if errorlevel 5 echo 5
if errorlevel 4 echo 4
if errorlevel 3 echo 3
if errorlevel 2 echo 2
if errorlevel 1 echo 1
if errorlevel 0 echo 0
-- I get these resulte --
R:\> TST 0
0
R:\> TST 1
1
0
R:\> TST 3
3
2
1
0
R:\> TST 5
5
4
3
2
1
0
R:\>
As you can see, "if ERRORLEVEL" works as I described, and "echo 0" is
performed in EVERY case... So I don't see how the original code:
>>>DREADY R:
could go anywhere BUT AUTOSTARTCD
Above tested under DOS5 and DosBox (same output)
Reply 7 of 8, by myne
Oh, right. I forgot how much of a pita errorlevels are.
I built:
Reply 8 of 8, by JediSword
If i write script.bat like that
@echo off
dready r:
if errorlevel 2 echo E2
if errorlevel 0 echo E0
I get:
when cd is ejected: E2 & E0
and when cd inserted: only E0
it's working correctly now, I think.
This is code I put in AUTOEXEC.BAT (on floppy image)
DREADY R:\
if ERRORLEVEL 2 GOTO END
And START.BAT can be like this (I'd like autoreboot when program exit, but keep ability to stay in DOS)
IF EXIST R:\PROGRAM.EXE call "R:\PROGRAM.EXE
ECHO Reboot in 3s (C=stay in DOS)
CHOICE /C:yc /T:y,03 /N
IF ERRORLEVEL 2 GOTO SKIP
if ERRORLEVEL 0 CALL FDAPM COLDBOOT
:SKIP
ECHO Welcome to MS-DOS
:END
FDAPM - power management tool from FreeDOS (this is only method I found to do full reboot. Other tools only restarts DOS and skips BIOS)
Also usefull with
LH=A:\DOSDRV\FDAPM.COM ADV:REG
in autoexec which limit CPU usage by DOS
Then CD can be created with ImgBurn
