First post, by iraito
- Oldbie
When the A64 was using the stock cooler on the Asus A8N-E FM/S the idle temp was 59C that made me worried but i also thought "Meh it's stock, that must be the issue" so i went and bought a prism wraith, it fits perfectly and bought the temps to 52 idle.
The only problem? apparently a good cooler should keep the cpu at 36\38 idle , what the hell is going on? i have 2 intake 1 exhaust, everything has been optimized, the CPU cooler is tepid at best but there's good pressure after checking the paste, i even updated the BIOS for mac compatibility with the CPU in question.
Broken sensor? room temps are 30C
If you wanna check a blue ball playing retro PC games
MIDI Devices: RA-50 (modded to MT-32) SC-55
