First post, by kiNok
I have little problem: After I take axe in windmill, Connor will walk out windmill and then animation begins. After that scene nothing happens. I have played this game before and there should be a fight with black knight, but now they only stare each other. Music does not stop and mask stays. Is there fix for this problem?
I tried to fix problem with version 1.3 update but that did'nt help at all.
I'm using WinXP
Reply 2 of 3, by kiNok
Dosen't work. What next?
Reply 3 of 3, by Flubly
Unfortunately I had this problem too with 2 or 3 scenes when I played through the game. Unfortunately the only thing that worked for me was saving right before the act and then just restarting the game until the cutscene went all the way through.
Are you playing with a no cd patch?
