First post, by ux-3
- Oldbie
This is a SS7 mainboard (IN530). The USB onboard connector looks like this. o is pin, x is no pin.
2 4 6 8 10
o o o o x
o o o o 0
1 3 5 7 9
Later USB 2.0 connectors have the pin shifted to the bottom row.
Solved:
2: 5V
6: Data+
8: Data-
9: GND
My plan would be to check pin 1 and 2 for +5V vs 7 and 8 with power on. Or find the pins with +5V vs chassis.
Then check if 7 and 8 have 0 ohm to ground with power off.
If I reverse hook up the P+ and P- data lines, what will happen? No function?
Retro PC warning: The things you own end up owning you.
