First post, by Locutus
Hi.
I got this MOBO with a missing BIOS chip.
I've found 'boot diskette' with software to flash BIOS but it does not contain bios images that I can use in programmer.
https://theretroweb.com/motherboards/s/ibm-pc … 71,-pc-350-6581
The attachment IMG_8812.jpg is no longer available
Reply 1 of 13, by Horun
One of the board pictures at TRW is from GigAHerZ who is an active member here, maybe you can PM and ask for a copy of the bios....
Reply 2 of 13, by GigAHerZ
You know what! I found that i still have that bios on my desktop! 😁
A little about software engineering: https://byteaether.github.io/
Reply 3 of 13, by Locutus
Thank you !
I've programmed EEPROM chip.
The MOBO gives 'sings of live' 😉
Without RAM I get long - 3 short -long beep (memory or system board error).
Unfortunately, with memory installed, it is 'dead silent' (checked on 3 different RAM modules).
Maybe it is a matter of missing cache chips.... or there is a problem with MOBO itself.
Reply 4 of 13, by Horun
Yes the missing cache could be a problem if BIOS does not accept 0 cache. The jumpers are only for 128k or 256k...
DO you have a Diag card ? It would help...
Reply 5 of 13, by Locutus
Horun wrote on 2024-07-01, 00:28:
I do have a diag card but without the riser I can't use it 🙁
I'll try to populate cache sockets - maybe this is the only problem.
One thing with cache bothers me...
There is bank_1 with DIP28 sockets marked 32kx8 and bank_0 with DIP32 sockets marked 128kx8.
There is no 512kB cache setting in documentation.
Reply 6 of 13, by AlessandroB
This modo can work without cache for sure. i had one in the past.
Reply 7 of 13, by Locutus
AlessandroB wrote on 2024-07-01, 08:45:
Yup, the problem is not 'missing cache chips' related.
Inserting the cache did not change anything 🙁
Reply 8 of 13, by Locutus
It took me a while....
The main problem was a cold solder joint on the 82C802 chip.
I've resoldered all the pins of the above, installed the battery socket and the motherboard is working.
I also flashed the BIOS to the latest english version.
The board is picky about the BIOS chip, it worked on the AT28C010, but when I was trying to update the BIOS it reported an error about the chip being unrecognized.
Even though there was no attempt to flash the bios, a few first bytes in the flash memory were zeroed.
I've mounted Intel P28F010 and it flashes without any problems.
Thanks for the help to all participants.
The attachment PC330_486_LEJT67A.zip is no longer available
Reply 9 of 13, by Horun
Great ! Glad you were able to get it running.
Reply 10 of 13, by Taisho
Hi, are you able to share the BIOS update utility? I have the BIOS file but can't find any good links to download the Flash utility. Thanks
Reply 11 of 13, by GigAHerZ
I'm not sure you even can flash it on board. You may need to get a dedicated programmer for that.
Reply 12 of 13, by BitWrangler
Locutus wrote on 2024-07-01, 08:20:
Probably too late to be any use, but I have a suspicion, which needs to be carefully checked against contacts on the board, specifically the first 4 or so in the riser slot, that you can put an 8bit card in the riser slot, but for 16bit and VLB the indexing is off.
Reply 13 of 13, by Locutus
Hi to ALL !
BitWrangler wrote on 2024-12-06, 13:59:
The mainboard was repaired and was working fine.
"The main problem was a cold solder joint on the 82C802 chip".
GigAHerZ wrote on 2024-12-06, 13:33:
YUP - it has a flashrom onboard and BIOS can be flashed 'on board'.
I've flashed it with english BIOS and uploaded 'raw dump' for external programer:
download/file.php?id=196405
Taisho wrote on 2024-12-05, 23:21:
Sure, I'll try to do it tonight.
