First post, by Deunan
I wasn't sure if this is more software or hardware related so I'm posting here. If the question was already answered please point me to the right thread.
I want to install WfW 3.11 on a 386DX system, but I was considering using a HDD for install instead of CF card. I got a few HDDs that are rather small and DOS and possibly Win3 is the most that will fit on them. But then I also have some more modern HDDs that I like to use partially because these are still cheaper and easier to find, and quieter as well. I will use a 3Com 509B for networking, with XTIDE ROM because why not, so I'm not limited by the BIOS when it comes to HDD size.
The question is - can Windows 3.x with its 32-bit driver actually address past 504MB? Or is there any other limitation, like 8.4G. Do I need something else than the driver provided by MS? I know I could just not enable the 32-bit support and it would work through XTIDE but still want to squeeze any performance I can get since it's a slow CPU and a mechincal HDD. But if that blows up somehow and trashes the partition I will have to reformat and start all over again, I'd rather not waste that time if someone could just tell me if it's going to work or not.
And another semi-related question: Is there a difference between CL 5424 and 5429 SVGA in Win3.x? Both are VLB and the later 5429 should offer blit acceleration (and HW mouse cursor?), and again I think the 386 could use all the help. But if the difference is not noticable unless I try something graphics-heavy, which the CPU won't handle anyway, then I'd rather put the 5429 into 486 system I will build later.
Reply 1 of 8, by douglar
HD support > 512MB depends on the driver that you use. I’d review this thread : 32 Bit Disk Access drivers on a 2 GB Windows 3.1 Hard disk. The Microhouse fast FastDisk driver is recommended. Here is the last Microhouse driver. It supports LBA for drives > 8.4GB http://vogonsdrivers.com/getfile.php?fileid=2070
As for CL 5424 vs CL 5429, the 5429 has hardware for block transfers, so it should be much nicer if you have a driver that uses that feature. Try doing “dir c:\windows” in a windowed DOS session. You should see a big difference as the text scrolls. The scrolling text will be noticeablely slow and stuttering if there’s no “bitBLT” going on.
Reply 2 of 8, by rmay635703
My 1995 era Omnitec 486dx2-66 with a Micronics vlb motherboard actually detected an 8gb aftermarket HD partitioned in 4x 2.1gb without any special software which was extremely surprising . Just used dos 6.22 and fdisk.
To go larger takes the unofficial Dos 7.x or special utilities
Reply 3 of 8, by jakethompson1
As douglar mentioned, overlay software from this era tended to come bundled along with a 32-Bit Disk Access driver for Windows 3.x, too.
The WDCTRL that comes bundled is so bare-bones it doesn't even assume IDE, it would work with an old WD1003 card in a real AT.
Reply 4 of 8, by Deunan
Many thanks for the links and info. I think I'll play with this Microhouse driver sometime but not now. It turned out that one of the older HDDs I had considered for this project might be developing sticky surface, it has serious trouble spinning up (it auto retries and starts on the 2nd try though). I think I'll just use this one for the project, before it expires and becomes junk. It was a trash bin rescue anyway.
Reply 5 of 8, by wbahnassi
WfW 3.11 here on a 1GB 2-partition HDD: 256MB and 744MB. Works great and accesses both C and D without issues. I'm using 32-bit disk and file access (using WD driver).
Turbo XT 12MHz, EGA, MFM HDD
Intel 386 DX-33, Speedstar 24X, SB 1.5, 1x CD
Intel 486 DX2-66, CL5428 VLB, SBPro 2, 2x CD
IBM BlueLightning 100MHz, CL5428, SB16, 4x CD
Intel Pentium 90, Matrox Millenium 2, SB16, 4x CD
HP Z400, Xeon 3.46GHz, YMF-744, RTX2060
Reply 6 of 8, by maxtherabbit
I seem to recall that the Microhouse driver didn't play nice with the XUB when I tried it. Western Digital themselves released an updated WDCTRL (called WDCDRV) which supports big drives and *does* play nice with XUB, but it only loads with WD branded drives.
Reply 7 of 8, by Jo22
maxtherabbit wrote on 2024-07-08, 23:54:
I'm not surprised, XUB is a mess (code wise).
I once tried (failed) to compile an V20 version for my XT and it was a nightmare.
I've never seen such an amount of encapsulated code before. 🙁
In it's function, though, XUB is very good I do admit.
XT-IDE hardware is also a bit slower than my 20MB MFM/RLL HDD with its 1984 HDD controller card.
Which is a good thing, actually, because it gives authentic loading times. No kidding.
That's good for retro software development. If you write something like a video player, it's important that XTIDE isn't faster than the real thing.
That being said, I remember that my copy of XUB had issues with both OS/2 Warp and Windows 95, too.
Maybe these 32-Bit systems do expect certain things that MS-DOS doesn't need.
And to be fair, that's what XUB had been designed for in first place, to get things things working on an PC/XT.
And here it does work very well.
It also supports MS-DOS 5 and 6.x, which are the reference I think.
It's MS-DOS 6.22 compatibility that matters most. It was the last MS-DOS sold, after all.
Anyway, I think there's one more alternative to try. Or two alternatives, actually.
a) get a more modern BIOS or a patched BIOS that supports modern CF cards/HDDs
b) try one of these BIOSes found EIDE Enhancer Cards. They're similar to XUB.
Edit: I do admit that the MicroHouse driver isn't the final answer, maybe.
It's simply the most universal, maybe.
I liked the fact that the supplied Windows help file had some information about the limits of the driver.
Other drivers maybe can be patched to not check for manufacturer ID, not sure.
If they can be patched, maybe an IPS file can be made, so that other users can patch the driver without legal worries.
I'm merely thibking out loud here, it's not meant as an actual suggestion.
Reply 8 of 8, by douglar
Jo22 wrote on 2024-07-09, 01:38:
When a protected mode driver starts up, like the Win 3.11 WDCTRL, it has to take control of the storage subsystem from the real mode INT13h handler without corrupting the users data. There are lots of ways that things can get corrupt, and one that challenged the developers was when the drive geometry in use by the INT13h handler didn't match what was in the BIOS drive table. So when the protected mode drivers start, they tried to do some tests to make sure they had things under control. In the Win 3.11 days, those tests look a little arbitrary in hindsight: https://www.os2museum.com/wp/how-to-please-wdctrl/
Anyway, it is a rare thing to find protected mode drivers that understand LBA geometry before 1996. XUB can and frequently does use LBA geometry. In cases when INT13h is doing LBA, it's best if the protected mode drivers realize that they will fail and refuse to load.
