First post, by Cursed Derp
Heyyyyyyyo,
I found a copy of Quake yesterday and when I loaded it up it seems to be the registered version 1.06. I'm confused though because the "source code" at the back of the trifold is the same as the shareware copies I've seen. If anyone knows what release of Quake this is, that would be cool.
Thanks
I am as smooth as a gravy train with flaming biscuit wheels.
Reply 2 of 8, by Cursed Derp
So is it the digipak release?
Reply 3 of 8, by feda
From redump:
Rerelease: Digipak packaging
Reply 4 of 8, by Cursed Derp
Awesome. I didn't think I would ever get a copy of Quake because they're hella overpriced, but I just happened to find one. Epic
Reply 6 of 8, by Cursed Derp
DosFreak wrote on 2024-07-08, 19:20:
Please keep your threads consolidated and titled correctly:
What an epic find, bro
OK I'll keep it in mind. This is a separate question but it's good to keep similar threads together
Reply 7 of 8, by Matchstick
Cursed Derp wrote on 2024-07-08, 17:44:
Heyyyyyyyo,
Thanks
That CD is CD # 04-12100CD: which is the Quake registered v1.06.
11-1111 Source Code on the packaging was used for both the original Big Box and shareware release.
So this came out of the original big box.
Reply 8 of 8, by Shponglefan
I have two boxed copies of Quake, the original release and a later one with Windows 95 compatibility.
The original boxed version has the "11-1111 source code" on the back of the CD case.
The Win 95 version has a single large bar code in its place.
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
