First post, by Pibben
I have several old ISA-MFM hard drive controllers with attached hard drives that does not work. As far as I can tell DOS finds no drive. How can i diagnose this? I hear Spinrite is a good tool to diagnose drives, but as the drive is not found by DOS, it is of no use in this case. Are there any other tools that can help me?
Reply 1 of 4, by rasz_pl
Plus Development Hardcard ? Those are all dead, plastic/rubber melts inside and glues it shut.
https://github.com/raszpl/440BX Reference Design adapted to Kicad
Reply 2 of 4, by weedeewee
rasz_pl wrote on 2024-07-11, 12:52:
Open up the harddrive, clean out the goo, replace the gooified rubber stopper with a replacement like a few bits of heatshrinktubing, and close the harddrive again.
Did it a few years ago. had the drive working for a few months and then put it in storage. No idea if it's still working at the moment.
Do not ask Why !
Reply 3 of 4, by Deunan
Pibben wrote on 2024-07-11, 12:42:
That diagnosis is just not good enough. Does the HDD spin? Does it seek? Is it a problem with the HDD at all, or something more generic like the whole card doesn't seem to do anything? Photos would help as well.
Reply 4 of 4, by dionb
Also, have you low-level formatted the drives with this specific controller (Debug-Routine) or just hooked up drives and controller that have no history together?
Maybe give specs and/or pics of all relevant hardware...
